vote for FSB JBG vote for FSB performanceoiltechnology.com
Go Back   FSB Forums > Bronco Discussions > 1980-'96 Bronco Tech
Thread Tools Display Modes
Old 11-03-2009, 06:14 PM   #1
stephen martin
Bronco Info: 1989 Bronco
trans with no fluid
I have put a new c6 transmission in the bronco about a year ago. It drives fine with no problems, but in the process of me putting the transmission in i had to cut the oil cooler line. I put a rubber hose on were i cut it at. Every once in a while the hose will come off wile i'm driving and fluid will go every were and of course the transmission will slip. This has happend to me about 8 times. I am tired of this happening, so today i am getting a all steel hose to put on. My question is how bad do you think it hurts the transmission when the fluid runs out?
stephen martin is offline   Reply With Quote
Old 11-03-2009, 06:16 PM   #2
bratcop
Bronco Info: 1988 Bronco XLT 351W 69K original
guess that depends on how far you drive it, but I would imagine no distance without fluid would be a good distance...
bratcop is offline   Reply With Quote
Old 11-03-2009, 06:43 PM   #3
stephen martin
I have never driven it more than 500 feet then ill will pull over, It will rev like it will slip then immediatly i will pull over.
Old 11-03-2009, 07:35 PM   #4
justin
justin's Avatar
Bronco Info: 96 XLT/5.0/E4OD
It would depend on how fast that fluid is pouring out.
Put the new steel line on it ASAP.
Life isn't fair
Originally Posted by HardyHar View Post
I shook it and a tiny bit of the white crap came out with a few more droplets.
justin is offline   Reply With Quote
Old 11-03-2009, 07:50 PM   #5
treader
Bronco Info: '96 Bronco XLT, 5.0 liter
If you can't get a new line right away, use a flaring tool and flare the ends of the tubes a little. The flare along with a hose clamp, will keep the hose from slipping off.
treader is offline   Reply With Quote
Old 11-03-2009, 09:22 PM   #6
351w500
Bronco Info: '90 XLT 351w E40D Truetrac 32" TSL's 32" all terrains lotsa stuff-
8 freekin times !!! You are a better man than me... or worse man.... cause i woulda fixed it after the first, If it happens on a turn you could create a "self pwning" situation.
351w500 is offline   Reply With Quote
Old 11-03-2009, 09:26 PM   #7
stangmata
The Stang-o-matic Baby
stangmata's Avatar
Bronco Info: 1995 Bronco 302 E4OD XLT
Mine has been on for three years or so now.
You are probably fine. The C6 is a stout tranny and can really take some abuse. You likely didn't do it any favors, but I wouldn't worry too much.
stangmata is offline   Reply With Quote
Old 11-04-2009, 12:03 AM   #8
bratcop
for the time being just run a short line between the input and output, use screw-in 90 degree elbows in the C6 that are made to accept hose and clamp the hose on to them. Then get a line bender when u can and bend up some lines. I just did mine and it wasn't that bad. A little tip, use a straightened metal hanger as a template, then bend your lines to match your template. I also used a 8 inch piece of rubber tranny line to connect the the lines from the cooler to the lines from the trans. I used a pipe cutter to score the unflared ends 3x to give the rubber hosing some traction when it is clamped on. Good Luck.
Old 11-04-2009, 12:40 AM   #9
351w500
If the line is already cut you could get compresion to barb fittings and install an auxillary transmission cooler.... that would be cooler.
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
