vote for FSB JBG vote for FSB performanceoiltechnology.com
Go Back   FSB Forums > Bronco Discussions > 1980-'96 Bronco Tech
Thread Tools Display Modes
Old 11-05-2009, 09:55 PM   #1
shawn1648
Bronco Info: 1992 FSB 5.8L
Fuel pressure and Vacuum test
I got one of those fuel pressure testers today at the auto store because I didn't have one and one of the first questions you guys always ask me is...have you tested the FP? I want to be able to have an answer to that from now on.
I also got a vacuum tester for the same reason.
Can someone walk me through how to use them? They are both by Actron. I searched and didn't find anything clear after about 20 minutes.
shawn1648 is offline   Reply With Quote
Old 11-05-2009, 09:57 PM   #2
jopes
balls deep with my
jopes's Avatar
Bronco Info: pile of parts
http://www.secondchancegarage.com/public/186.cfm
the vacuum guage should have came with instructions.
the fuel guage goes on the fuel rail. turn the key to on watch the guage. it should go up. then you can start it, with the vacuum line off you should have 39.5psi per ford.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd.
Originally Posted by Ranger429 View Post
Nothing better than a piece of dark meat with some sauce on it.
Originally Posted by 95thebroncoman351 View Post
played with one of my buddies... its sick
jopes is offline   Reply With Quote
Old 11-05-2009, 10:11 PM   #3
shawn1648
Thank you!
It does. But which hook up location for the vac guage will give me the best results? Should I also try multiple locations?
Old 11-05-2009, 10:11 PM   #4
jopes
balls deep with my
jopes's Avatar
between the heads and thottle body. you want full manifold vacuum.
Old 11-05-2009, 10:15 PM   #5
shawn1648
So I should hook it to the place where the brake booster line goes into the intake?
Old 11-05-2009, 10:18 PM   #6
SigEpBlue
Satyr of the Midwest
SigEpBlue's Avatar
Location: Ida & Grand Rapids, Michigan, a.k.a The Unemployment Capital of America
Bronco Info: 1993 EB, 5.8L, BIO0 MAF, GT40Ps, Mustang cam, GT40 Intake, Custom Headers, Moates QuarterHorse
It doesn't matter. For all practical diagnostic purposes, manifold pressure is the same throughout the entire manifold.
SigEpBlue
Wheelin' across Michigan from Ida to Grand Rapids, baby!
Originally Posted by Nicola Tesla
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
Originally Posted by Adlai Stevenson
Isn't it conceivable to you that an intelligent person could harbor two opposing ideas in his mind?
SigEpBlue is offline   Reply With Quote
Old 11-06-2009, 08:54 PM   #7
shawn1648
Fuel pressure is reading 31psi at idle.
I'm not sure if I did it right. I unscrewed the cap on the shrader valve. Screwed on the adapter. Screwed in the fuel gauge and hose assembly and placed the tube in a container. I turned the key so the fuel pump turned on, checked the gauge, it wasn't reading anything. I started the truck and the fuel pressure gauge went up to just a hair over 31. Let it idle for awhile, no change. I turned off the truck and the gauge dropped back down to zero. No fuel in the tube or container. No leaks around the valve or brass fittings.
Old 11-06-2009, 08:59 PM   #8
SigEpBlue
SigEpBlue's Avatar
Pull the vacuum line off of the fuel pressure regulator (it'll be a red line with a 90° rubber elbow on the end going into the regulator) and stick a golf tee or similar object into the rubber connector to plug it. With the engine running, and that vacuum line plugged, your gauge should read ~39psig. 31psig @ idle sounds about right.
Old 11-07-2009, 09:24 AM   #9
shawn1648
FP is 41.5 with the vac line plugged.
Old 11-07-2009, 01:14 PM   #10
SigEpBlue
SigEpBlue's Avatar
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
