vote for FSB JBG vote for FSB performanceoiltechnology.com
Go Back   FSB Forums > Bronco Discussions > 1980-'96 Bronco Tech
Thread Tools Display Modes
Old 11-07-2009, 02:01 AM   #1
rhauf
rhauf's Avatar
Bronco Info: 82 bronco 408w 4" lift 35's, 88 bronco 351w all stock on 31s
AOD and 4r70w torque converter swapable?
so i'll be going to the JY tomorrow to pull an AOD for my explorer build.. but i got to thinking, that there's no way i'm going to get the torque converter off the (cfc) seized/destroyed engine.... so i'm wondering if i can use the torque converter thats already on the engine (from the 4r70w trans) with the AOD transmission? i've heard the 4r70w is an electronically controlled slightly modified AOD (different gearing and VB is all?) so i thought maybe it's possible.
my other question is, where is the torque converter lock up clutch located? in the torque converter or the transmission?
-Ryan
82 bronco.. 4" lifted and some other things
rhauf is offline   Reply With Quote
Old 11-07-2009, 08:02 AM   #2
sdstriper
sdstriper's Avatar
Bronco Info: 86' FSB, 351HO, C6, D44 Quad Shocked, 9" rear, 3.50 R&P's, BFG A/T 30 x 9.50
I am no expert but it is my understanding that the AOD is more of a mechanical lockup within the transmission compared to a torque converter clutch lockup like the 4r70 and other overdrive automatic transmissions Ford has.
sdstriper is offline   Reply With Quote
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
