bronco 8 lug TTB - FSB Forums
Thread Tools Display Modes
Old 11-10-2009, 10:29 PM   #1
jado
bronco 8 lug TTB
Is it possible to put a f250 TTB into a bronco? If not how can i convert it to 8 lug?
jado is offline   Reply With Quote
Old 11-10-2009, 10:31 PM   #2
rhauf
rhauf's Avatar
Bronco Info: 82 bronco 408w 4" lift 35's, 88 bronco 351w all stock on 31s
Anything is possible, so yes that would work.. i would not want to give up the coil springs though. also you can convert parts of the f-250 ttb onto the bronco ttb to do a sort of hybrid, i looked into it at one point when i was thinking of upgrading my rear, but ended up beefing up the 9" instead and haven't had a problem since.
why do you want 8 lug? to match another rear?
-Ryan
Check out my youtube page. Many bronco videos.
http://www.youtube.com/user/rhauf1
rhauf is offline   Reply With Quote
Old 11-10-2009, 10:35 PM   #3
jopes
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
everything I have heard the frames are different and more of a pita than just using chevy parts.
search on here for it. many have done it
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd, GTP38R noise maker, Stage 2 injektorz. Lotsa fun!
Let's Go Fishing.
jopes is offline   Reply With Quote
Old 11-10-2009, 10:37 PM   #4
rhauf
rhauf's Avatar
Ahh yeah that's it.. the Chevy d44 axle parts bolt to you're beams.... (search for details) ok im done
-Ryan
Old 11-11-2009, 02:16 AM   #5
kf4amu
Try it now!!
kf4amu's Avatar
Location: hotels, Charlotte, Roanoke VA, the cockpit...time split equally between all of them.
Bronco Info: 1989 460 EFI/C6/BW1356 electric/6 inch Rough Country lift/York OBA/Warn hubs/electric fans/14 bolt
F250 parts will be so hard to make work tha it's not worth it.
I used Chevy 10 bolt parts and it works great
-Will
064 tlx 98
http://www.supermotors.org/registry/...ail.php?id=819
The best electric fan writeup out there
http://fullsizebronco.com/forum/showthread.php?t=40564
kf4amu is online now   Reply With Quote
Old 11-12-2009, 02:22 PM   #6
jado
I want to do what kf4amu did. I have 37 inch MTRs on 16.5 hummer beadlocks. The front looks simple enough, but what about the rear?
Old 11-12-2009, 02:39 PM   #7
Redwagon
rolling Rolling ROLLING....
Bronco Info: 93 Cherokee
What year is your bronco?....most guys just switch the rear axle out to an 8 lug, such as a chevy 14bolt...just depends if you need the sensor or not.
Tim
Newest token Jeep owner....
Redwagon is offline   Reply With Quote
Old 11-12-2009, 03:29 PM   #8
kf4amu
Try it now!!
kf4amu's Avatar
My rear is a 14bolt. I got it from a junkyard for 70 bucks. I did a disk brake conversion so it ended up costing a lot more than it could have, but rear end swaps can be pretty cheap.
-Will
064 tlx 98
Old 11-12-2009, 08:01 PM   #9
Dustball
shibby
Dustball's Avatar
Why isn't there an 8-lug swap FAQ as a sticky? It's been asked so many times that there should be one.
Dustball is offline   Reply With Quote
Old 11-12-2009, 09:19 PM   #10
jopes
gone fish'n
jopes's Avatar
pm me a link to a good one and I will sticky it. and link it in the tech sticky in the tech forum.
Let's Go Fishing.
Old 11-12-2009, 09:46 PM   #11
kf4amu
Try it now!!
kf4amu's Avatar
http://www.off-road.com/trucks4x4/ar....jsp?id=198393
This is the one Dustin wrote, and what I used to do my swap, which is what the OP said he wanted to copy.
Consider putting this one as a sticky as well, since this question gets posted once every week or two...How to Fix an Electric Shift BW1356
http://ylobronc.users.superford.org/...6/elec1356.htm
-Will
064 tlx 98
Old 11-12-2009, 09:57 PM   #12
jopes
gone fish'n
jopes's Avatar
added to this thread
http://www.fullsizebronco.com/forum/...ad.php?t=74471
Let's Go Fishing.
You may not post replies
Forum Jump
