Mack Truck Axles - FSB Forums
Thread Tools Display Modes
Old 12-13-2009, 06:47 PM   #1
Crawdaddy
Crawdaddy's Avatar
Bronco Info: 82 Ford Bronco 302, stock, electrical horror show
Mack Truck Axles
I've noticed that Mack big trucks, specifically Mack dump trucks, seem to have top-loading axles, similar to the Rockwells. Are they using some variant of a Rockwell axle, or does Mack just happen to use a proprietary top-load axle that appears to be similar to the Rockwells? And no, I have no intention of using one for any application, I'm just curious.
Thanks!
Crawdaddy
82 Bronco XLT, 302,C6,NP208, MileMarker hubs, otherwise stock
Originally Posted by Shadofax View Post
Wanna know every piece that went into the build of the space shuttle? Want the assembly instructions as well? It's likely right here at FSB
Crawdaddy is offline   Reply With Quote
Old 12-13-2009, 07:45 PM   #2
The Dude
The Dude's Avatar
Bronco Info: 1989 Bronco, 302, M5OD-R2, 3" exhaust, limited slip diffs
I know that some semi's run rockwell axles. I'm not sure if they are built different than ones that you would see on a 2 1/2 ton truck. But I have rebuilt (years ago) a few axles from semi's that were top loading rockwells.
The Dude is offline   Reply With Quote
Old 12-14-2009, 01:18 PM   #3
mudshovel74
mudshovel74's Avatar
Bronco Info: 79 bronco 400m c6 stock axles
mack rears are very similar in design to rockwells, however they are a stand alone design. And toploaders are all that macks run.
Originally Posted by JohnMcD348 View Post
Why Do You drive such a Big Truck??"
"Because I have a very small Penis."
Originally Posted by FTA Boy View Post
no.... Full Bronco doesn't make sense..could it be, Fat Bronco...no how about Fast Bronco? ...ridiculous. perhaps its Ford Bronco! ..nah that's crazy talk. You're right, Its probably is Full Bronco.
mudshovel74 is offline   Reply With Quote
Old 12-14-2009, 01:34 PM   #4
The Ric
MORTAL KOMBAAAAAAATTT!!!!
The Ric's Avatar
Bronco Info: 88 EB custom dents, and rust.
I work on one everyday..well almost everyday. They are I think a 10ton axle, I'd have to check to make sure, but they are just about completely different since they are set up for 10 lug, and slack adjusters for the brakes and brake spring diaphrams.
Not to sure what to put in my signature anymore.
1988 Ford Bronco EB - 2010 Chevy Malibu - 2009 Cannondale Six5 - 2013 FELT F75X
The Ric is offline   Reply With Quote
Old 12-15-2009, 09:57 AM   #5
Crawdaddy
Crawdaddy's Avatar
Cool. Something told me that they weren't Rockwells, but it'd be pretty neat if Mack did use them.
Crawdaddy
Old 12-15-2009, 10:13 AM   #6
Robs79BBbronco
Robs79BBbronco's Avatar
Bronco Info: 79 Ranger XLT-460,NP435,NP205,stock axles/3.50's,2.5"RC lift,33"trxxs mt's,72 impala horn(best mod)
i know some of the old mack's had 2 speed rears.........wouldn't that be cool in an old f-100 or something.
Robs79BBbronco is offline   Reply With Quote
  FSB Forums > Other Forums > Anything Else
You may not post replies
Forum Jump
