how long does a 351m last? - FSB Forums
Thread Tools Display Modes
Old 12-27-2009, 11:47 PM   #1
imonfireagain94
imonfireagain94's Avatar
Bronco Info: 1979 ford bronco 351m 4 speed 37 inch boggers, sitting on a 4 inch lift with 2 broken leaf springs
I have a 351m with 130,340 miles on it, and im just curious on how long other peoples have lasted. Mine was pretty much untouched until i got a hold of it. Im going to college soon and im just wondering if its gonna die soon or if i have some good running years ahead of me.
imonfireagain94 is offline   Reply With Quote
Old 12-28-2009, 12:05 AM   #2
bronc_17113
bronc_17113's Avatar
Bronco Info: 77 f250 highboy, 77 f250 highboy crew, 78 f150,78 bronco, 69f100
300k plus and still going
http://www.warriorsoutdoors.com
bronc_17113 is offline   Reply With Quote
Old 12-28-2009, 12:06 AM   #3
imonfireagain94
Sweet! Never rebuilt???
Old 12-28-2009, 12:21 AM   #4
351w500
MARBLE GARGLER!
351w500's Avatar
Bronco Info: '90 xlt 351w E40D Truetrac I GOT ROLLER ROCKERS !
...until you pop the valve head offa the 2 piece valve and total the motor.
351w500 is offline   Reply With Quote
Old 12-28-2009, 12:49 AM   #5
bigbronco44
bigbronco44's Avatar
Bronco Info: 1991 silver anniversary
Same 300K and still going 1 qrt every 4 weeks and thats it ..The Tranny went first ...Motor still going strong
1991 Silver Anniversary
bigbronco44 is offline   Reply With Quote
Old 12-28-2009, 01:16 AM   #6
Nates78
Nates78's Avatar
Bronco Info: 1978 Ranger XLT goodies with holley TBI
I replaced mine at 190,000. It was working fine, I just thought it was tired and needed an upgrade.
Nates78 is offline   Reply With Quote
Old 12-28-2009, 01:39 AM   #7
78'460
Im scared of jopes
78'460's Avatar
Bronco Info: 78' 4spd 460 38's
When I bought mine it had the 351m, It was tired but ran strong. I asked the PO how many kilometers it had and he said it had probably been around the clock quite a few times, When I tore it apart. It was a un touched engine and had never been apart before. So alot of miles. And dont let the little oil pressure scare you they run without none for a long time.
78'460 is offline   Reply With Quote
Old 12-28-2009, 08:31 AM   #8
Robs79BBbronco
Robs79BBbronco's Avatar
Bronco Info: 79 Ranger XLT-460,NP435,NP205,stock axles/3.50's,2.5"RC lift,33"trxxs mt's,72 impala horn(best mod)
might last 30k......might last 300k.a lot depends on how it was used and cared for over the years,.
Robs79BBbronco is offline   Reply With Quote
Old 12-28-2009, 11:56 PM   #9
mustangman65_79
mustangman65_79's Avatar
Bronco Info: 1978 Bronco 351M
mine has 160k+ miles, and was treated like crap. No oil changes in who knows how long before I go it. The oil was so caked in the valve covers, I didn't know how it ran. It has a slight rod knock, and wrist pin noise, but it does run. (PS, doing a motor swap soon)
'84 Mustang GT Turbo 2.3 Turbo
'85 Ford LTD
'91 F-150
'78 Bronco XLT 351M
mustangman65_79 is offline   Reply With Quote
Old 12-29-2009, 07:51 AM   #10
imonfireagain94
Yea mine was the same. When i first got it, the oil hadnt been changed in a long long long long long long time. Lotta shit under the valve covers. In fact when i put new valve covers on, i didnt think it was gonna be worth it because i thought my engine was gonna die soon. But ive changed the oil a couple times since then, and the last time i had the valve cover off it didnt seem as bad as it was before.
Old 12-30-2009, 09:45 PM   #11
BigWheelz
Bronco Info: 1978 Bronco, 466 EFI
Mine had the original 351m from 1978 when I got it, she still had 1978 date coded ford bearings and all! God only knows how many miles were on it....probably 300k +
The old 351m leaked oil at the rate of a quart every 30 miles, and what it did not leak out it burned thanks to two cylinders being down on compression. Further, I thought the oil pressure gage was broke when I bought it....come to find out it just did not make much oil pressure. But the old 351m did still run, and it ran well enough to get to 70 mph without much drama!
Opportunity is missed by most people because it is dressed in overalls and looks like work- Thomas A Edison
BigWheelz is offline   Reply With Quote
Old 12-30-2009, 11:09 PM   #12
shadowcaster
shadowcaster's Avatar
About 1 1/2 yrs with virtually no oil pressure until it throws a rod into the oil pan. Ask me how I know.........
If it ain't broke, keep trying to fix it!!!!
shadowcaster is offline   Reply With Quote
Old 12-30-2009, 11:17 PM   #13
imonfireagain94
Hey bigwheelz, mine was leaking the exact same amount of oil. haha. Then i changed the rear main seal and its been good ever since.
Old 12-30-2009, 11:38 PM   #14
Ned
Ned's Avatar
Bronco Info: 1979 Bronco Custom, 351M with headers and full dual exhaust, MSD "Street Fire" ignition upgrade.
Well that's a good question.
Mine originally came from BC Canada and now resides in Ontario Canada, the second owner drove it all the way from BC to Ontario about 6 years ago.
He sold it to me because I think he couldn't handle the gas mileage he new the original owner who died then he bought it off his son.
He tells me the engine has never been apart, if that's true and I have no reason to doubt the man mine if you add the two dash Odometers together(I changed mine to one that I started at zero) I get 347+ kilometers in miles about 260'000.
Poor fella had not given the Bronco a tune up for 15 years, I did a tune up and ignition up grade and I get 2 and half times better mileage than he did.
Rick.
3G 135 amp alternator install
Griffin All Aluminum Rad installed
Custom nerf bars installed
Next MSD TB Fuel Injection install.
Ned is offline   Reply With Quote
Old 12-31-2009, 12:10 AM   #15
jopes
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
I had a 351m that was in sad shape, I was building a 400 so I didn't care. I tried to blow it up out wheeling on it's last trip. I would hold the accelerator on the floor and push the clutch in and let it back out repeatedly trying to pull someone out. it had about 7 psi of oil pressure @ 5500 rpms.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd, GTP38R noise maker, Stage 2 injektorz. Lotsa fun!
Let's Go Fishing.
jopes is offline   Reply With Quote
Old 12-31-2009, 02:35 PM   #16
BigWheelz
Did it blow? I was not able to destroy mine....and I tried for fun right before I replaced the engine.
Old 12-31-2009, 08:34 PM   #17
jopes
gone fish'n
jopes's Avatar
no it did not. I ended up driving it home and putting in the 400.
Let's Go Fishing.
Old 01-01-2010, 07:01 AM   #18
meoran
mine had the original 351m with over 300k went ahead replaced the rear main and it is still running strong in my friends bronco. Who knows how many miles it has on it now.
meoran is offline   Reply With Quote
Old 01-01-2010, 07:27 PM   #19
Brian in MI
Brian in MI's Avatar
Bronco Info: '78 Bronco Ranger XLT Factory: 4:11 gears, A/C, HD suspension 460 SEFI (In progress)
mine had 130,000 miles when I pulled it to put in a 460. sold it to a friend he lapped the valves,
still going strong that was 10 years ago.
Brian in MI is offline   Reply With Quote
Old 01-17-2011, 04:03 AM   #20
platypus101
dude as long as you take care of it will last a while. i have 96 bronco with a 351 with 235,000 miles and running strong. just recently replaced timing chain. solid engines
platypus101 is offline   Reply With Quote
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
