ford 9 inch rear disc brake conversion??? - FSB Forums
Thread Tools Display Modes
Old 01-20-2010, 12:32 AM   #1
project-79bronco
Bronco Info: 79 bronco
so does anybody know of a cheap way to do a rear disc brake conversion on a ford 9 inch for a 79 ford bronco
project-79bronco is offline   Reply With Quote
Old 01-20-2010, 08:47 AM   #2
Brian in MI
Brian in MI's Avatar
Bronco Info: '78 Bronco Ranger XLT Factory: 4:11 gears, A/C, HD suspension 460 SEFI (In progress)
Yeah,
Use mid 70's Lincoln Versallis parts. Direct bolt on, will have to use J@@p rotors and upgrade the front
calipers to mid 70's full size car, LTD, T Bird etc. They have bigger pistons, depending your year Bronco.'78 or '79
add that year F350 MC and Booster. It will stop on a dime and give a nickles change back.
I did this to my '78, best mod I have done, and that includes the 460.
Brian in MI is offline   Reply With Quote
Old 01-20-2010, 04:13 PM   #3
Mud-Nut
Mud-Nut's Avatar
Bronco Info: '79 F150
We used calipers, rotors, and caliper brackets from a '79 D44 on my brother's Ranger.
Here's how we modified the brackets. Made them the same shape as the flange on the 9".
Had to get the inside of the rotor machined down just a tad.... Almost any shop that deals with brakes can do this for you.
And welded the bracket onto the axle (just tacked on in these pics).
Sorry... I can't find any pics with the caliper bolted on. But they do work great.
2001 F250 Superduty
- 7.3L Powerstroke, ZF6 Swap, 5.5" Lift, 37" BFG's, and TW Tuned!
1979 Ford F150 - 14B FF, HP D60, Custom R/A, 460BBF, C6, 39.5" Boggers, and so on...
My Build Thread/Wheeling Pics! - GouletFilms.com
Mud-Nut is offline   Reply With Quote
Old 01-20-2010, 05:41 PM   #4
MUDDOG7375
MUDDOG7375's Avatar
Search under my name... Iv posted links on how to to do it for under $100... Its a pirate4x4.com thread
MUDDOG7375 is offline   Reply With Quote
Old 01-20-2010, 10:23 PM   #5
pfeffer1728
pfeffer1728's Avatar
Bronco Info: 79 Bronco Ranger XLT/400/Auto/37" tires
can you post a link? im apparently not that great at searching
pfeffer1728 is offline   Reply With Quote
Old 01-20-2010, 11:41 PM   #6
MUDDOG7375
MUDDOG7375's Avatar
My gawd... I have to do everything around here...
http://www.pirate4x4.com/forum/showthread.php?t=229934
http://pirate4x4.com/forum/showthrea...ight=rear+disc
Old 01-21-2010, 09:15 AM   #7
harrison94
harrison94's Avatar
Bronco Info: '79 XLT 400CI 4spd Edelbrock carb/intake 2000 Ford PS Lariat
OK MUDDOG That's a Bad attutude you have! But i like it! Thanks for the links!
Torque it down till it strips...Then back it off a quarter-turn!
harrison94 is offline   Reply With Quote
Old 01-21-2010, 09:54 AM   #8
pfeffer1728
haha thanks mud
Old 01-21-2010, 05:36 PM   #9
79F150
Dictator/Tyrant
79F150's Avatar
Bronco Info: 1979 F-150 400/NP 435/NP 205/D60/10.25
Originally Posted by Brian in MI View Post
Yeah,
If I had one of these axles I wouldn't waste it on a Bronco. They are selling to mustang guys for like $1200.00 for the rear end. For that kind of money you can buy an after market set up and pocket $800.
79F150 is offline   Reply With Quote
Old 01-21-2010, 08:34 PM   #10
Brian in MI
How do you figure a mid size car axle wil fit a Bronco? I said use the parts off of it, they are cheap here. None of the mustang guys here want to mess with 30+ year old technology. Especially when the aftermarket will blow the lincoln stuff out of the water.
Old 01-21-2010, 08:41 PM   #11
79F150
Dictator/Tyrant
79F150's Avatar
I didn't say it would fit but buy your post you said you would use the parts from a mid size car axle. What I said was I wouldn't scrap an axle I could sell for $1200 to put disc brakes on a Bronco.
They still sell here I had a guy try to buy my Continental axle for his until he realized it was a 5x5 lug pattern and to wide.
Old 01-21-2010, 08:49 PM   #12
79F150
Dictator/Tyrant
79F150's Avatar
Here..
http://www.mustangsplus.com/tech/versaill/index.htm
Here is an add but he is to cheap.
http://atlanta.craigslist.org/sat/pts/1562987148.html
http://www.mustangmonthly.com/techar...wap/index.html
http://www.ford-trucks.com/forums/76...lles-axle.html
http://www.stangnet.com/mustang-foru...-info-faq.html
Yeah no one would want to do that..
Basically it is a bolt in to a mid 60's mustang and converts the 8" to a 9".
Old 01-21-2010, 09:25 PM   #13
Brian in MI
The Mustang axle used the small bearing retainer on the end of the tubes, Correct? The Lincoln used the larger truck bearing retainer, I don't see how it is a direct swap. 3rd member ok, but don't see how the brake parts swap over. Is there two different size Versallies/Monarch axle bearings?
Old 01-21-2010, 09:53 PM   #14
79F150
Dictator/Tyrant
79F150's Avatar
No they didn't just swap just the brakes. The whole axle is a swap into a Mustang. You take out the old 8" rear and install a Lincoln 9" in its place.
Old 01-21-2010, 10:12 PM   #15
colobronco
colobronco's Avatar
Bronco Info: 79 Ranger XLT 400CID C6 2" Lift on 33's
Your avatar is creepy.
Originally Posted by InfoFord View Post
if you still can't figure it out put it back together and take it to a mechanic
"Under my plan electricity prices would necessarily skyrocket" BHO
Truck was stolen & sold for parts Wheat Ridge Colo Black with Red 2 tone. About $20K in the truck. VIN U15HLEC0170
colobronco is offline   Reply With Quote
Old 01-21-2010, 10:27 PM   #16
79F150
Dictator/Tyrant
79F150's Avatar
Thanks its all me..
Old 01-22-2010, 12:47 AM   #17
project-79bronco
thank you guys alot
Old 01-22-2010, 03:21 AM   #18
MUDDOG7375
MUDDOG7375's Avatar
Not a Bad attutude... just the question is asked almost every day... Someone sticky the bitch.....
Old 01-22-2010, 08:24 PM   #19
ChaseTruck754
Mustang guys do dig the versilles axles as they are 5x4.5 lug pattern - but what they don't know is that they are 28 spline and they are also expensive to buy brake parts for.
For the bronco 9" many ways have been posted to convert them but I figured I'd add a little.
In the past I have used the front rotors off a 82 CJ-5 jeep 4wd and then chevy calipers with weld on brackets.
Rear disk brakes can be done for $100 or so.
ChaseTruck754 is offline   Reply With Quote
Old 01-22-2010, 08:49 PM   #20
Brian in MI
79F150
Here in Michigan there hasn't been a 9 inch with disc brakes in a junk yard for 20 years.
Weather it is a Versallies, Monarch, etc those cars are non existant here,
especially when scrap was high a few years ago, so the disc brake stuff is cheap.
I got the Versallies brakes for free because the Mustang guy was going with a late model Mustang brake parts.
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
