| Sponsored Links | |||
Advertisement | |||
#3 |
![]() Join Date: Dec 2007
iTrader: (41) Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
Use the mustang distributor, and the truck intake, wire it up and that's it. All there is to it.
~ Scott ~ ~My Exhaust clip on YouTube ~ 204k on the odometer and no longer a daily driver. ~ ~ Bronco owner/Driver/Mechanic/Enthusiast for 21 years ~
#5 |
![]() Join Date: Nov 2006
iTrader: (0) Bronco Info: 89 Bronco EB 5.0L AOD, 35" Mud Country's, 4'' Rancho,Ford 9" w/Aussie locker and 4.11 gears
So the Bronco computer will work? I thought the Mustangs were already MAF by this point or does that not matter.
12K Tabor winch Custom T-case skid plate 2 Pro Comp 130watt Lights Custom Air Box with Dual K&N |
#6 |
iTrader: (0) Bronco Info: '92 EB 5.8 conversion, edel heads, comp cam
'89 mustangs were mass air. Would one be able to perform a mustang 5.0HO using a pre '89 mustang motor with out rewireing or reprograming a Bronco(92) harrness?
#7 | |
I personally years ago took a 92 302 HO motor and dropped it into my 86. Put my intake on it and fired it up. No need to change computers, or worry about converting over to MAF to make it work.
#9 |
There "Might" be some mild differences, I honestly know nothing about that gen mustang though. The timing cover and lower intake on my rebuilt '90 Bronco engine was different than my EFI '86. Wasn't a big deal, just needed to be swapped out.
'86 Eddie Bauer, '99 F350 Lariat, '75 Corvette Stingray. It's got safety tubes, but I ain't scared, Brakes are good, tires fair... "Hot rod Bronco" ![]() My truck http://www.supermotors.net/registry/3868 |
#10 |
correct distributor gear for hardened camshaft ,and fireing order, mustang distributor is tfi module if truck dist is tfi you can use the stang dist in its place,you should be able to change gear on truck distributor and reuse the distributor HO motor is rated at 225 hp about 300 tq forged pistons e7 heads ,ithink the truck 302 is not a roller cam and rated about 175 hp thats 50horsies, definitely cant use mechanical fuel pump no lobe to drive pump witch was an issue on my 77 swap i did, reuse injectors from mustang i believe they are higher lbs than truck if you can use the stang intake do it better flow and long runners (another can of worms), speed density on 87/88 stang actually ran stronger than mass air setup on 89 cali cars and up but did not take well to modifications mass air did. i would swap a 90 HO into my 94 inplace of the 5.8
in a heart beat my 77 had 410 gears 35's locker in rear and posi in front granny 4 and would get flat out stupid on dirt but i carbed it with edl 600 and performer intake its hard to forsee the small shit untill you get into the swap this is only my experience and may not count for much that is my 2 cents and that may be all its worth
94' black Eddie 5.8 auto 88' ranger ext cab 4x4 5-speed |
#11 |
![]() Join Date: Jan 2010
iTrader: (1) Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs,172,000Miles
The Cam will will be different as well. I have a 94 mustang and a member of a few mustang forms and have seen people askin about putting in a explore motor into a mustnag and the differnece is the cam as well as the other items listed above. May wana look into finding a explore motor with the GT heads in it. Think the 96 explores to the 04 explores has gt heads. a few have the GTp heads witch are aluminum but those heads use a different header as than a reg 302 stock head.
#12 | |||||
Knuckles, thats one long @ss sentence you got going on, almost gave me a headache this morning................. Quote:
![]() Quote:
GTP heads are still cast, not aluminum. But yes they do require a special header. Last edited by sackman9975; 01-30-2010 at 09:13 AM. |
#14 |
No, just stating FACTS.
No info is better than wrong info
#16 | |
To the op, basically don't worry about it and get that 5.0HO in there, Sackman knows his chit!!
#17 |
iTrader: (0) Bronco Info: 1987 bronco, 3" body lift, 2" suspension lift.
Hey, not overly mechanically inclined but I try. I just swapped an 88 mustang 302 into my 87 bronco. I have fuel, spark, and it turns over, but will not fire. I have been told it is a computer issue, so I have been thinking about just switching it to carburated. In lamans terms can anyone tell me what the actual issue is? If it is I am completely inept at wiring/electronics. Would it be an advantage or disadvantage to switch it over.
#18 | |
Fuel and spark, sounds like timing. Make sure your using the mustang distributor also because of the steel roller cam.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
