TAB, TAD, and EGR solenoid removal. - FSB Forums
Thread Tools Display Modes
Old 02-11-2010, 05:45 PM   #1
plug ugly
Master Bater
plug ugly's Avatar
Bronco Info: 4 wheels, 4 sticks and 3 pedals
ok, Im real close to starting up the new lightening motor, but the harness and computer need the the TAD,TAB,EGR sols hooked up.
Can I just clip the fittings, close the loops on the wire and call it good? Meaning, take the respeective red wires and respoective brown or wh/pink wires, and wire them together? Will that send the signal to the computer that I need?
No need to mount sensors to the motor if I am not using them, so hopefully I can just wire them together and call it good.
Stupid is as Stupid does
mostly a 94 Bronco
wt4wheeling
plug ugly is offline   Reply With Quote
Old 02-11-2010, 08:28 PM   #2
slim68
slim68's Avatar
Bronco Info: 86 Bronco - 5.0efi - aod - 3g alt - upgraded ignition
You do not want to just short the wires together, the solenoids act as the loads, using the current. No load and the current goes straight to ground shorting out the system and causing lots of probs. I don't know what would work, just leaving them disconnected would probably throw codes. For the EGR, there are adapter plugs that trick the pcm into thinking there is one attached.
slim68 is offline   Reply With Quote
Old 02-11-2010, 11:07 PM   #3
jopes
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
I know the resistor works for the EGR. it might work as well for the others. or a tuner and you can turn them all off.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd, GTP38R noise maker, Stage 2 injektorz. Lotsa fun!
Let's Go Fishing.
jopes is offline   Reply With Quote
Old 02-11-2010, 11:21 PM   #4
plug ugly
Master Bater
plug ugly's Avatar
how does the resistor mount? Do you just sodder it to either wire and and the resistance fools the computer to think it works?
mostly a 94 Bronco
wt4wheeling
Old 02-11-2010, 11:32 PM   #5
jopes
gone fish'n
jopes's Avatar
http://rjminjectiontech.com/?p=9
you can either buy a resistor or buy the one ryan or others make. he also lists a pack of resistors to eliminate the other things your looking to remove.
Let's Go Fishing.
Old 02-12-2010, 03:21 PM   #6
RC Dan
Bronco Info: '94 5.8 dd, '93 project truck
Or do it yourself. 75ohm resistors for the EGR, TAB and TAD solenoids. The EVP is also important. Get an eliminator for that or make one yourself, too. I'm not sure I can post the picture for the EVP resistor values as RJM took it off their site.
RC Dan is offline   Reply With Quote
Old 02-12-2010, 03:25 PM   #7
SigEpBlue
Satyr of the Midwest
SigEpBlue's Avatar
Location: Ida & Grand Rapids, Michigan, a.k.a The Unemployment Capital of America
Bronco Info: 1993 EB, 5.8L, BIO0 MAF, GT40Ps, Mustang cam, GT40 Intake, Custom Headers, Moates QuarterHorse
There's no sense in lying to the PCM. If things aren't there, leave them open until you've fixed it properly.
SigEpBlue
Wheelin' across Michigan from Ida to Grand Rapids, baby!
Nemo nisi per amicitiam cognoscitur -- No one learns except by friendship.
Originally Posted by Adlai Stevenson
Isn't it conceivable to you that an intelligent person could harbor two opposing ideas in his mind?
SigEpBlue is offline   Reply With Quote
Old 02-12-2010, 06:36 PM   #8
plug ugly
Master Bater
plug ugly's Avatar
they wont be fixed properly. This thing is going into a 61 scout after this season, so all smog has been pulled for easier install when I went to the GT40 intakes. I no longer have the smog pump or diverters. As a result, i dont need the solenoids. I would rather not have to worry about mounting them, and just bypass them so I can start this thing and run it for three months, before it gets mustang FI.
mostly a 94 Bronco
wt4wheeling
Old 02-12-2010, 07:46 PM   #9
RC Dan
Heres the resistor values and a diagram for deleting the EVP.
I've done this to a few trucks and it works great. The engine runs like it should and it doesn't throw codes(except for insufficient EGR flow). So the above along with resistors to replace the vacuum solenoids and you should be set.
Edit: BTW, putting the resistors in just gives the computer a constant "closed" signal. So it thinks everything is closed and off. This is important for it to adjust the fuel and spark curve correctly. If you did nothing and just unplugged it all, the computer will still adjust as if its there.
Old 02-12-2010, 09:24 PM   #10
plug ugly
Master Bater
plug ugly's Avatar
I actually have on of the EGR elims from Ryan. I should have said EVP, TAB, and TAD
mostly a 94 Bronco
wt4wheeling
Old 06-21-2010, 06:26 PM   #11
kemicalburns
Never Done
kemicalburns's Avatar
Plug did you ever get the evp and TAB/TAD taken care of? i am considering this also and could use some help.
For Sale - 94 XLT 357/E4OD Trans-go stage II
6" Stage II ProComp,35" BFG/AT 4.88 f (aussie) / r (open) / Custom Sliders, Custom bumper Warn HS9500, Edelbrock truck upper/lower,JBA headers,Custom Y pipe hi flow cat & Full 3"
kemicalburns is offline   Reply With Quote
You may not post replies
Forum Jump
