Fan rubbing shroud - problem? - FSB Forums
Thread Tools Display Modes
Old 02-27-2010, 07:34 PM   #1
Kith
Bronco Info: '94 - 5.0
Hey all,
Lots of great info here, just got turned on to this place by a someone at an unrelated forum.
I searched through a lot of what was here, and ran a search to see if this question was answered, but only thing it came back with was advice on broken motor mounts - my mechanic says they are fine.
Forgive me for not being as savvy of the right terms or names for things that I should be, messing with vehicles is something I do sometimes without any real training or whatever.
I have a 1994 Bronco 5.0
The fan that's in front of the radiator, it has a plastic piece that sits around it attached to the front of the engine compartment. I think it's called the shroud?
Sometimes the fan rubs against the plastic piece, with a quick repetitive clacking sound.
This only happens when the vehicle is not sitting flat, like if one of the front wheels is on a curb and the other 3 are on the street, or very rarely when i'm turning.
Once when I had a wheel on the curb and it kept making that sound, I threw it in park and popped the hood. Looking underneath, I could see that the fan was hitting the plastic cover, and tracked this down as the source of the noise.
Seems to me like it's not really anything to worry about directly, but it does have me a little concerned about a possible bigger problem.
If it only happens when one wheel is higher then the others in front, or sometimes when i'm turning, does this mean I might have a problem with the frame of my truck?
I'm worried that there is extra give and flex in the body of my truck, letting it deform enough to cause the rubbing.
My mechanic says my motor mounts are fine, and it doesn't happen during acceleration or braking, only when one front corner of the truck is higher then the other, or sometimes when I'm turning.
I have 33 inch tires on it, and no lift if that plays a part in the diagnosis. Have never had a problem with rubbing tires.
I routinely ask more of this truck then it has any right to give, overloading it hauling scrap, construction materials, yard waste, etc... Should I be concerned about taxing the vehicle too much?
I also take it camping a lot and carry all our gear to off-road camping sites. Usually we take a second vehicle for the people since the Bronco can easily transport the weight of everything we take.
I don't tow often, but sometimes i'll drag around trailers of various sizes, never pulled a huge one though and I don't own one myself, so it's only a sometimes thing.
I do, however, make it my mission to pull out cars that get stuck in the snow when it happens. Doesn't usually snow enough for this, but just two nights ago I pulled 3 vehicles back onto the road over in New Jersey on route 55 who slid into the downhill grassy median.
I mention this stuff so you can get a handle on the stresses I put the truck through, so you can better judge if I have a problem or not. Long and short of it is that I use the truck for what it can do, and not as just transportation.
Built Ford tough absolutely applies to the Bronco, and I love this truck and what it's proven to me it can do, so I don't wanna go and break it if there was a problem I should fix.
So should I be worried about this, or is it no big deal?
If you need more info I can probably describe it more in-depth if necessary.
Thanks for the advice!
Kith is offline   Reply With Quote
Old 02-27-2010, 07:58 PM   #2
Dustball
shibby
Dustball's Avatar
How are your body mounts?
Dustball is offline   Reply With Quote
Old 02-27-2010, 08:46 PM   #3
justin
BRONCO WIZARD
justin's Avatar
Bronco Info: 96 XLT/5.0/E4OD
Take a look at your front core support mounts and bushings.
You have enemies? Good. That means you've stood up for something, sometime in your life.
-Winston Churchill
justin is offline   Reply With Quote
Old 02-27-2010, 09:53 PM   #4
KLAKEBRONCO
KLAKEBRONCO's Avatar
Bronco Info: 95 Bronco XL-302/E40D
Body mounts or engine mounts.
Make sure the shroud is still fastened securely.
95 Bronco XL. 302
Originally Posted by CJREX View Post
No matter how much it's washed, it's still a butt HOLE.
Originally Posted by pfun41 View Post
just wanted to see if any pictures of women came up while i had it in.
WANTED: Sterling aftermarket diff cover, install kit, 3/4 Chevy Calipers, 4.88 gears, 1350 yoke.
KLAKEBRONCO is offline   Reply With Quote
Old 02-27-2010, 10:01 PM   #5
Ranger429
Moderator
Bronco Info: 79 Bronco, 47 Binder
Engine mounts are the same as motor mounts.
Ranger429 is offline   Reply With Quote
Old 02-27-2010, 10:17 PM   #6
KLAKEBRONCO
Really
I would still check them. When someone says "mechanic" I automatically think....You better check that for yourself instead of taking the "mechanics" word for it.
That's been my experience though. Maybe there are some good ones.
95 Bronco XL. 302
Old 02-27-2010, 10:49 PM   #7
jeffb
jeffb's Avatar
Bronco Info: 94 Eddie Bauer, 6" Superlift, 35x12.50x15 BFGoodwrench MT KM2, 140000miles, 351 V8
I had the same thing and it was the motor mounts.
jeffb is offline   Reply With Quote
Old 02-28-2010, 03:04 AM   #8
Seattle FSB
Seattle FSB's Avatar
Bronco Info: 1990 EB FSB, MAF, 6.7L, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
Kith, the first thing that I would do is crawl under the front of your truck and look at the base of the shroud. There should be 2 clips that secure the shroud to the base radiator support. If they are missing or not connected the shroud can move or become oval in shape causing it to come in contact with the fan with centrifical or gravitational force. If the shroud has 4 points securely fastened, then look elsewhere. I just dealt with this issue and adequately securing the base attachment clips cured my out-of-round shroud that was very close to the fan on one side.
1990 Bronco, MAF, 408 Stroker, Level 10 E4OD, Currie F9+, Electric Boost Brakes, lots more...
Seattle FSB is offline   Reply With Quote
Old 02-28-2010, 12:51 PM   #9
bronco1
Bronco Info: 90 Bronco
Where on the shrould is the fan hitting-bottom,top or sides.If the fan is hitting on the bottom,the motor mounts may be collapsed or the rad may not be sitting properly on the lower mounts.If the fan hits the top of the shrould,then there may be a problem with the rad support-rusted out or bent,rad support mounts-collapsed,split or missing,the lower rad mounts-bent,rad mount rubber pads-collapsed,missing.The motor mounts not sitting all the way down in the frame brackets on one side or both sides.If the fan hits on the sides,the shrould may be out of round,sitting of to one side on the rad,the rad sitting to one side.There may be more that can be added,but this is a good start.
bronco1 is offline   Reply With Quote
Old 03-03-2010, 12:36 AM   #10
Kith
Thanks for the replies!
I've been busy the last few days and haven't had time to really check up on it, but I did a quick cursory check with a flashlight a few minutes ago (in the rain no less...)
Looks like the clips are all there, and the shroud doesn't look like it's out of shape.
I haven't checked the radiator yet, but i'll do that on my day off tomorow during daylight.
I'm kinda hoping now that my radiator isn't seated correctly, because i'd hate for it to be a motor mount.
i've been using my mechanic since i've been driving for 9 years now, and my dad used him for a long time before that. He's a friend of the family, and the people in his shop do good work and have been the same people for as long as I can remember.
I've been through just over a dozen vehicles. Some were totalled, some weren't worth fixing after a certain point, one was stolen, but I am hard on a vehicle. I've had my bronco for a little over a year and a half now, and not only have I had it longer then any other but it's the first one strong enough to take the abuse I put it through.
I busted two motor mounts on an oldsmobile I had once, and my mechanic picked it up during inspection. I didn't even know. His shop has gotten a lot of business through me over the years, and I was always happy with the work.
He told me specifically they were fine, but that was a long time ago and before I noticed the sound now that I think about it, so the possibilty is there that it could be the problem.
I really hope not though.
Where are the motor mounts located, and how many are there?
Old 03-03-2010, 12:54 AM   #11
JLHollowy
JLHollowy's Avatar
Bronco Info: Focus zx4 ST
If its the driver side motor mount one trick ive heard used is to unbolt the mount, have a buddy rev the truck up and slide it out. Then same then and drop the new one in.
JLHollowy is offline   Reply With Quote
Old 03-03-2010, 01:49 PM   #12
bigblueford
bigblueford's Avatar
Bronco Info: 90 302/AOD * 96 302/E4OD * 96 302/M5OD
The passenger front body mount is rusted off on my wife's 1990 - causes the fan to hit the shroud (or vice versa). Easy to check - just look at the mount, then pull up and down on the fender to see any movement.
302, 5 speed manual, 4" JBG lift, 35" BFG M/T
bigblueford is offline   Reply With Quote
Old 03-03-2010, 02:37 PM   #13
wileec
wileec's Avatar
Bronco Info: 95 302 ZF5 4.56 w/Detroit in the back 33" tires, Sag swap, warn winch and Custom Soft Top
Since this is happening when the truck is flexed but not on engine stress I would point to the core supports (on the front of the frame near the radiator not the motor mount (there are 2).
OMGyou did not just recommend trying to replace a mount this way. There are a whole bunch of reasons why this is a real bad idea!
Always topless
wileec is offline   Reply With Quote
Old 03-03-2010, 03:06 PM   #14
Acatucci
Motor mounts.
I had the same problem with my 5.0 Mustang. When my fan rubbed against my shroud, it started wearing the fan down slowely. I replaced with solid motor mounts from Brother's Performance. Relatively cheap and easy to install. I went with solid and it was an everyday driver, gave a little more torque as long as your tranny mount isn't solid (room for give) you'll be ok. I went as far as removing the shroud altogether, but not needed due to the fact that has your coolant overflow container is attached to it. If you go that route, make sure you have a brand new radiator cap to insure that it won't continuesly overflow when a little warm.
Acatucci is offline   Reply With Quote
Old 11-13-2012, 10:48 PM   #15
The Lox
Bronco Info: 94 EB
I have just discovered that I have the same problem going on. Once I get another daily driver I will start addressing these little items that are popping up.
The Lox is offline   Reply With Quote
Old 11-13-2012, 11:16 PM   #16
I6 Bronco
Bronco Info: 300 I6, 79 bronco Frame 84 F150 cab
ARE YOU RETARDED? NO SERIOUSLY, ARE YOU A RETARD?
I6 Bronco is offline   Reply With Quote
Old 11-13-2012, 11:26 PM   #17
CS79bronco
Bronco Info: Red/White '79 Custom-400, 435, 205. '86 EB beater, 302, 435, 208 stock on 35's, '95 XLT, 302, 5spd.
He might have been, couple years ago.
man... the things I've learned on this site simply boggle the minds of everyone I talk too. (Biker Pepe)
CS79bronco is offline   Reply With Quote
Old 11-13-2012, 11:58 PM   #18
BRONCONUT
Local # 40 Boilermakers
BRONCONUT's Avatar
Bronco Info: transforming...
BRONCONUT is offline   Reply With Quote
You may not post replies
Forum Jump
