vote for FSB JBG vote for FSB performanceoiltechnology.com
Go Back   FSB Forums > For Sale/Where to Buy > Vendor Reviews
Thread Tools Display Modes
Old 04-17-2004, 05:03 AM   #1
threefiftyone
threefiftyone's Avatar
Another BAD ebay post
I recently purchased a set of 4, used 35" BFG tires and 15x10 aluminum wheels off EBAY. The seller assured me the tires were in good shape, and the wheels too. They were going to be shipped mounted and balanced. They arrived mounted, but only two tires balanced. I proceeded to get an alignment and a balance at a local tire shop. They told me the tires were crap, and could barely be balanced. It's like the seller just threw some weights on there to make the sale. So I contacted the seller, and we are still trying to settle this BS. I literally could not drive on the street, even with 16 ounces on each wheel! The tires are so bad everything shook violently while driving. I went ahead and bought a new set of BFG's, and they ride like a dream. The dealers name is "wheelnndealn," and I suggest not trusting them. Just throwing caution to the wind
Canada Sucks!
1992 Nite (rare)
8 point cage
Tube sub-frame
Sway-A-Way Coilovers
Dynatrac 60's F/R, w/Detroits
Atlas II 4:1
Jet E4OD
514 CI
Aluminum Radiator
Mastercraft seats
Sneaky Pete Nitrous
44" Boggers
threefiftyone is offline   Reply With Quote
Old 04-17-2004, 03:26 PM   #2
Bluebeast
I break chit
Bluebeast's Avatar
Bronco Info: Cooler that yours... when it runs
thanks for the heads up
Bluebeast is offline   Reply With Quote
Old 04-17-2004, 03:55 PM   #3
DrewMan187
DrewMan187's Avatar
Bronco Info: 1984 XLT, 6 inch superlift susp. lift, 3inch body lift, 37x13.5 baja claws, 4.56 gears, 351W 5.8L
could be a good reason not to buy used tires and wheels off ebay. Its fine when your buying them locally so you can inspect them frist hand but off ebay you dont know what your getting into with something like that.
1984 Bronco XLT AKA "Outlaw Bronco"
6inch superlift suspension lift w/rear springs
3inch PA Bodylift
37x13.5 Baja Claws on 15x10 AR wheels
351W 4.56 gears
1999 Dodge Ram 5.9L magnum 3inch PA Bodylift
285/75 R16 Dunlop Mud Rovers on new 16x8 Pacer Alloys
DrewMan187 is offline   Reply With Quote
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
