Neutral Safety Switch install question - FSB Forums
Thread Tools Display Modes
Old 06-03-2010, 01:57 AM   #1
SoCal1989Bronco
SoCal1989Bronco's Avatar
Bronco Info: 1989 XLT 351 C6 Bronco, Stock at the moment cause im broke at the moment
i have a question about the install the main thing i have a concern is about the pin, after i remove the pin i have to put the transmission in neutral and then put the pin in is that correct?
SoCal1989Bronco is offline   Reply With Quote
Old 06-03-2010, 10:09 AM   #2
jermil01
Charlie doesn't surf!!
jermil01's Avatar
Bronco Info: 1992 xlt, 351EFI, .040, E4OD, D44 SAS w/Trutrac,Detroit locked 8.8, MAF conv, Tweecer tuned
I'm sure someone who has a C6 will chime in here, but do you have a Haynes manual? If not, I'd go out an get one, it describes that process for the C6 in detail..
Vote 4 Top 4x4 Site!!!
jermil01 is offline   Reply With Quote
Old 06-03-2010, 10:38 AM   #3
miesk5
miesk5's Avatar
yo, SoCal,
We all replied to your Other POST on the C6 NSS here; http://fullsizebronco.com/forum/showthread.php?t=175484
Some Excerpts from that Thread
Neutral Safety Switch Adjustment
Source: by Tim O (RED WAGON, redwagon) at http://fullsizebronco.com/forum/showthread.php?t=149087
Tim Wrote; "...Place transmission manual lever in neutral position, then insert a .091 inch gauge pin through gauge pin holes, Fig. 8.
Tighten switch attaching bolts, then remove gauge pin..."
-- and-------
Neutral Safety Switch (also referred to as Back-Up Switch) Installation & pics in an 89; "...It probably took me a total of 5 minutes to change this part. As you can see in the pic it has two bolts holding it on and one nut holding on the downshift lever. the hardest part is the downshift lever has to be immobilized while you loosen the nut. You can do this with a screwdriver like me or the book says to use a guage rod or something. You can get to it on the drivers side of the tranny. Here is a pic of it installed..."
Source: by Mad Dog Tannen http://fullsizebronco.com/forum/show...=173118&page=2
Neutral Safety Switch Wiring Color Codes in an 89
Source: by Uncle_Monkey at http://fullsizebronco.com/forum/showthread.php?t=173356
USN & DoD Planner (ret)
THANKS to ALL WHO SERVE!
Old 06-03-2010, 02:39 PM   #4
SoCal1989Bronco
thnkxs thats all i really need to know.
Old 06-03-2010, 05:02 PM   #5
miesk5
miesk5's Avatar
yw,
Also can you check the connector for color codes on it?
and confirm colors; and snap a few pics of the NSS and connector if you can; here is the other NSS C6 thread http://fullsizebronco.com/forum/showthread.php?t=173356
You may not post replies
Forum Jump
