About to need a positive battery cable - FSB Forums
Thread Tools Display Modes
Old 06-15-2010, 04:49 PM   #1
077tango
077tango's Avatar
Bronco Info: 96 Bronco XLT 5.8
Question About to need a positive battery cable
My battery cables are pretty bad, installed new ends but whole assemblies need replaced. Appears my positive cable is like a mini wiring harness! Obsolete from Ford but would be around $200.00 if they could find one. Any ideas? 96 with 5.8
Thanks
077tango is offline   Reply With Quote
Old 06-15-2010, 04:56 PM   #2
Ziggy
Ziggy's Avatar
Bronco Info: 79 Bronco
Local auto parts store should be able to get a replacement cable for you for a lot less.
3G Alt. Upgrade, Duel Batteries, 351M bored .030 over with Edlebrock cam and intake, C-6 w/AO4D internals, 3" lift w/RS 9000, 33x12.50 MTR's, Saginaw PS Pump Conversion, On Board Air, Detroit Locker, Hydro Boost Brake System, Altimeter from a CH-46D, Map Light from a MH-53E.
U. S. Government - Wasting paper and keeping Lumber Jacks gainfully employed since 1776.
Ziggy is offline   Reply With Quote
Old 06-15-2010, 05:02 PM   #3
f302man
f302man's Avatar
Bronco Info: 87 f150 6'' lift s.a.s. Dana 44, shacle flip, no more blocks
i would need a pick but i like doing all the work on my truck but i bet you could go down to napa or some place and get the terminal and do it your self
f302man is offline   Reply With Quote
Old 06-15-2010, 08:21 PM   #4
jersa
jersa's Avatar
Bronco Info: 96 XLT 5.0/302 EFI
Hey Tango, My 1996 5.0 has the same problem with the battery wiring harness, and the closest thing to a solution that I've found is making one yourself, which I definitely can't do so I'd have to find someone to do it for me. But about what Ziggy said, I'd like to find out more about that, because I didn't know people made an aftermarket harness like that.
----Jeremy
jersa is offline   Reply With Quote
Old 06-15-2010, 08:40 PM   #5
Ziggy
Ziggy's Avatar
Did you try looking at LMC, Bronco Graveyard or Dennis Carpenter web sites yet to see if they might have what you need? If you have more then one wire feeding off the battery, you might have to replace just the positive cable, then put terminal rings on the other wires and attach them individually to the terminal bolt. I understand your dilema but sometimes you have to find a cheaper out that still does the job. Otherwise, you might have to hit up your local junkyard for a good replacement wiring harness.
Old 06-15-2010, 09:10 PM   #6
pfun41
pfun41's Avatar
my advance has all different styles of battery cables, id just get one there. i needed a new terminal so i was gonna replace the whole cable but it wat too much work. all you need to make your own is the terminal, cable, small torch, and solder. you could crimp it if you didnt want to solder it.
1994 Bronco 5.0 liter E4OD factory MAF_31" Bfg A/Ts_130 amp 3g, Auxillary transmission filter,cooler and temp gauge, Homemade Y pipe
my build: http://fullsizebronco.com/forum/showthread.php?t=176792
my youtube: http://www.youtube.com/user/pfun41#p/a
1990 Bronco 302/AOD stock - Sold
pfun41 is offline   Reply With Quote
Old 06-16-2010, 01:00 AM   #7
rla2005
rla2005's Avatar
Bronco Info: 2004 6.8L Excursion 4x4
Most of the online sites do not list the battery cables by the Ford part numbers. Here is a list of the positive and negative cables listed for the early 90's gas engine equipped trucks:
WC-8976 Positive Battery Cable 40” Long
WC-8980 Negative ground Strap 45” Long
If you search on the WC-XXXX numbers many of the online suppliers list them in stock. If you search by make/model you get the generic listing for cables. I found the part numbers on a Ford parts website. They are a bit pricey so shop around. Hint: RockAuto usually lists them and they are a vendor here..
rla2005 is offline   Reply With Quote
Old 06-16-2010, 09:37 AM   #8
077tango
077tango's Avatar
Cable
Thanks all, I'll keep looking around and researching. This is a double cable positive system with another harness attaching to the cable that goes to the starter. I'd say it attaches about 15 inches down from the battery. The cable that attaches to the ignition box(probably wrong terminology) has a unique end that bolts to the box. Like I said, ford says the positive cable alone was about $200.
Old 06-16-2010, 10:47 AM   #9
rla2005
rla2005's Avatar
Yes those cables are pricey from Ford, if they were available. Many sites show they are obsolete. Is this what you are looking for:
That is a photo from NAPA of their part no.CBL 718036. It's not exactly the same as the Ford, the connector on one end of the Ford cable is horseshoe shaped to fit over both side of the starter relay. This one is a single lug terminal. Oreilly Auto Parts has the WC8976 cable if you search by that number, not the vehicle make/model.
Old 06-16-2010, 11:05 AM   #10
077tango
077tango's Avatar
cable
Fairly close, my system has an additional full cable in the harness that goes from the battery to the starter. This cable has another small harness attaching to it a little way down. Not quite sure the origin of this small harness.
Old 06-16-2010, 11:45 AM   #11
rla2005
rla2005's Avatar
I did some more research at Fordparts.com. There is a newer cable assembly for the 95/96 trucks. The Motorcraft number is WC-95718. The description indicates it is the positive AND negative cable assemblies. I have not found any photos of that part yet.
Old 06-16-2010, 12:28 PM   #12
joshhath
joshhath's Avatar
Bronco Info: 95 5.0 MAF/E4OD XL
Rockauto has it for $47.79. You have to search for "Starter Cable". Look under 96 F150 (it is not listed under Bronco). MOTORCRAFT Part # WC9386 {#F6TZ14300JB} is for 96.
Thumper Heads, Moates Quarterhorse, Innovate LC-1 Wideband, Comp Cams 35-510-8, MarkVIII Fan, Tranny Cooler/Filter, 130a 3G, 31"s, 3.55 Open, Bassani Headers and Y w/ 3" exhaust, Hooker Aerochamber, Crane Hi6s, Strobes, 180Tstat - Detroit Locker in the garage
joshhath is offline   Reply With Quote
Old 06-16-2010, 10:53 PM   #13
MikE2
MikE2's Avatar
I'd just get a length of cable and the ends to solder on.
MikE2 is offline   Reply With Quote
Old 04-02-2012, 11:51 AM   #14
rocknrod
rocknrod's Avatar
Bronco Info: 1996 Eddie Bower 4x4 5.8 E40D
I just ordered one for my 96/5.8 when it comes in I will take pictures and post:
http://www.sarad.com/index.aspx?q=&y...cal&sc=&o=3888
rocknrod is offline   Reply With Quote
Old 04-02-2012, 11:56 AM   #15
cavellmc
Bronco Info: 89 302 with AOD
Ryan (fireguy50) on here has a site with probably anything you'll ever need electrical-wise. I've ordered stuff from him in the past for battery cables.
Check out http://www.rjminjectiontech.com/coll...ry-cable-parts
89 with a 302 and AOD. Completely gutted, fully rhino lined, interior and exterior. Topless, full cage and winch. riding on 35's. Used to be an Eddie Bauer...
cavellmc is offline   Reply With Quote
Old 04-02-2012, 12:24 PM   #16
Steve83
Steve83's Avatar
Click this & read the captions:
Old 04-07-2012, 10:37 AM   #17
rocknrod
rocknrod's Avatar
I got them in yesterday. They had the positive and negative battery cables with the starter connections included, all bundled in black conduit just like original. Cause they were - Ford part numbers and stickers on them. All for $48.00 Wow!
Old 06-11-2012, 05:22 PM   #18
CajunMedic
Will the WC-95718 work on both 5.0L and 5.8L trucks?
CajunMedic is offline   Reply With Quote
Old 06-11-2012, 07:51 PM   #19
Steve83
Steve83's Avatar
Those engines use the same starter/battery wiring harness.
Old 06-12-2012, 07:27 AM   #20
Ewgoetz
Ewgoetz's Avatar
Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs,172,000Miles
+1 on this.
"hold my beer and watch this"
Hydroboost walkthrought
My Build Thread!! II
My Build Thread!! - retired
Ewgoetz is offline   Reply With Quote
You may not post replies
Forum Jump
