79 bronco 400CI Ignition Timing - FSB Forums
Thread Tools Display Modes
Old 07-15-2010, 10:37 PM   #1
RoosterMcNasty
RoosterMcNasty's Avatar
Bronco Info: 1979 Custom
Few problems here. First, Anyone have pics of what the timing marks look like on these 400s? I cannot see anything that resembles a timing mark. Also, once I find the marks, what degree/rpm do I set it at? Do I need to plug any vacuum lines?
Another question as I'm not familiar with carbs(before my time).
Do I need to adjust my carb (post a link on this info?) first, or do my timing first?
I plan on getting a new coil, plugs and wires and gapping them to .50
Any advice on getting my ignition/carb set right would be great.
Thanks in advance.
RoosterMcNasty is offline   Reply With Quote
Old 07-16-2010, 01:46 AM   #2
jopes
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
there should be a emissions sticker. autos vs manuals had different timing and I think .50 for the plugs is not going to be correct.
you need to unplug the vacuum advance to the dizzy and plug it so you do not have a vaccum leak. and at the same time I would verify TDC #1 on your piston stroke and timing marks at the same time. Balancers have been known to spin.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd, GTP38R noise maker, Stage 2 injektorz. Lotsa fun!
Let's Go Fishing.
jopes is offline   Reply With Quote
Old 07-16-2010, 08:35 AM   #3
RoosterMcNasty
Yeah there is no sticker, It came with the 351. The guy i bought it from put this 400 in it from a junkyard 77 pickup.
Old 07-16-2010, 10:38 AM   #4
UTfball
UTfball's Avatar
Bronco Info: 1979 w/400, 4" lift, 35's, 3.55's
Alright...10-12*BTDC is where manuals need to be and 12-14*BTDC is where autos need to be on a stock engine per Ford. I agree with jopes, verify TDC first...if that's sticking your finger over the #1 plug hole or pulling the passenger side valve cover and making sure that the pushrod side of both rockers on #1 are down. Then I would get it timed accordingly. As jopes said, pull the vac advance, I plug the dizzy with a golf tee. Then I'd worry about the carb. I dunno the specs on the carb if it's new or been used. Typically what I do, is set the carb's choke to factory index, then adjust the floats, then hook a vacuum gauge up to the port on the intake...and adjust the mixture screws to the highest vacuum reading. This should get you pretty close to dialed in.
Ben
UTfball is offline   Reply With Quote
Old 01-12-2011, 12:40 AM   #5
BroncoViejo
Bronco Info: 400M, Dual exhaust, C6 trans, 3.50 gear posi
here you go! 12 degrees @ 600 RPM
BroncoViejo is offline   Reply With Quote
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
