Wont start after running for a while. - FSB Forums
Thread Tools Display Modes
Old 07-27-2010, 05:01 PM   #1
LuckySkull13
LuckySkull13's Avatar
Bronco Info: 1990 Bronco XLT 351w
So I took the rig on a short drive, everything was fine. I stopped to get something to eat...apon leaving I put her in reverse and then she died...shifted to park and turned the key...the engine turns over but no start...After looking at it for a while and trying to start it over and over I was smelling gas in the engine area...tells me that the pump is good and working I'm just not getting a spark. The distibutor cap and spark plug wires were replaced reciently so...I am stuck...
Any ideas?
LuckySkull13 is offline   Reply With Quote
Old 07-27-2010, 10:49 PM   #2
Wicked Pete
Wicked Pete's Avatar
Bronco Info: 1989 Custom & Eddie Bauer
Take a spark plug wire off a plug and put a screwdriver (something insulated) in the wire. Have someone crank it over while you hold the screwdriver close (1/4") to some metal. Be careful, this can shock like hell if you touch it. There should be a little arc to the metal. If there is no spark it could be: Coil, loose wire, broken wire from ignition switch to coil, ignition module, distributor...list goes on. Once I had to have mine towed home, it was the coil wire not pushed all the way into the coil.
You need a Volt-Ohm meter to check voltages. I used to use a 12v bulb on a couple clippy wires, ground the negative and poke around to find if the voltage to coil stops somewhere.
Sometimes smelling gas doesn't mean that the pumps are working properly. I have had mine not start when hot, it was the "in tank" fuel pump getting weak. Had gas at the rails, but not enough pressure. There is a gauge that is used for pressure testing.
Do you have a code reader? This might tell you if a (?) sensor is bad. Won't tell you if a wire is loose or broken. Good Luck.
Wicked Pete is offline   Reply With Quote
Old 07-28-2010, 02:38 PM   #3
Thumbs2457
Thumbs2457's Avatar
Bronco Info: '92 Nite 302/e4od 4" RC lift on BFG 33's.
first pull codes. Self test with a paper clip. instructions below
http://fullsizebronco.com/forum/showthread.php?t=161185
Thumbs2457 is offline   Reply With Quote
Old 07-28-2010, 02:55 PM   #4
LarryP
Thanks 351w500
LarryP's Avatar
Location: Northcentral,CA.Twain Harte, up here in the mountains
Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
More then likely it is going to be your (ignition module) When they go out its all of a sudden with no warning. But pull codes first, it will tell you. But it wouldn't hurt to get one anyway just to have in the glove box. And you need the lil tool to for it.
I take Prayer Requests. God Bless
LarryP is offline   Reply With Quote
Old 07-28-2010, 05:10 PM   #5
Wicked Pete
LuckySkull13: I hope he comes back and let us know what he found.
Old 07-28-2010, 05:38 PM   #6
LuckySkull13
Ok. So I pulled the codes. The only code I got was 56 (Mass Air Flow sensor fault).
Still lost.
Old 07-28-2010, 11:39 PM   #7
LarryP
Thanks 351w500
LarryP's Avatar
Did you see if you had any spark at all???? The mass air flow fault Is cause the bronco Is not running during the test IIR???
Old 07-29-2010, 05:06 AM   #8
galvinm6
Bronco Info: 89 Ford Bronco 302
Sounds notoriously like an ignition module.
Your not getting spark sooooo
Check where your not getting spark from
Coil
Cap
Rotor
Wires
If all of those have no spark then that module is bad in most cases
They test them at parts stores
galvinm6 is offline   Reply With Quote
Old 07-29-2010, 07:10 AM   #9
LuckySkull13
Thanks alot guys. I have not had the time to test spark. First thing tomorrow afternoon, I'll get right on this and let you know.
Old 07-29-2010, 07:30 PM   #10
LuckySkull13
So I replaced the coil and the Ignition Module and the spark plugs; it's as if nothing has changed. still just turns over with no start.
Old 07-29-2010, 07:40 PM   #11
zippome
zippome's Avatar
did you try this yet?
My SAS build thread.
zippome is offline   Reply With Quote
Old 07-29-2010, 07:50 PM   #12
LuckySkull13
Yes just did. It's getting a spark. So does that mean it's the fuel pump? How hard is it to replace and does it cost alot??
Old 07-29-2010, 08:01 PM   #13
zippome
zippome's Avatar
well if your getting spark to your plugs and you said that you just replaced the plugs, then yeah it does sound like it could be the fuel pump. about $60 for a brand new one. and its inside the gas tank.
Old 07-29-2010, 08:21 PM   #14
LuckySkull13
Is it possible that it's just the fuel filter and it's not getting enough pressure? If this is the case I hear that you need a special tool to replace the fuel filter?
Old 07-29-2010, 08:49 PM   #15
slawson2000
slawson2000's Avatar
Bronco Info: '87 Bronco/'96 front clip & '94 Centurion C350
No special tools are required as far as I remember, but first I would find out what the problem is before replacing items. After cranking the engine, are the plugs wet or dry?
You can't fix stupid...
slawson2000 is offline   Reply With Quote
Old 07-29-2010, 11:01 PM   #16
LuckySkull13
Plugs are dry, but smell like gass.
Old 07-30-2010, 01:36 PM   #17
LuckySkull13
I just tested the fuel pressure, it's at about 25-30 psi (a little on the low side but not too bad). I'm going to replace the fuel filter today and see if that does anything.
Is it possible for that little pressure (25-30 compare to 35-45) to be a difference in the rig not being able to start?
Old 07-30-2010, 01:43 PM   #18
theramsey3
#1 Asshole
theramsey3's Avatar
Bronco Info: 90 5.0 H.O. E4OD BW1356 3.54 3L55 32/11.50R15 Black not the one in the pic ^^^
Dont forget the reservior filter it isnt listed for the truck anymore but it is acdelco gf750, purolator f50126, napa/wix 33268 or autozone ff616
Gotta get going again soon. my supermotors for before and after.
Originally Posted by ford_munky_man View Post
I was always taught u got to lube it up before you stick it in. My friends said the teacher yesterday said that too.
theramsey3 is offline   Reply With Quote
Old 07-30-2010, 03:41 PM   #19
LuckySkull13
Where's the reservior filter? Have pictures??
Old 07-30-2010, 03:49 PM   #20
theramsey3
#1 Asshole
theramsey3's Avatar
check out this thread http://www.fullsizebronco.com/forum/...ht=fuel+filter it has alot of good info in it about the reservior filter and here is a pic from that thread the reservior filter is just directly before the forward fuel pump
http://www.supermotors.net/getfile/7...uel-filter.jpg check this out too http://www.supermotors.net/registry/2742/66025
You may not post replies
Forum Jump
