How can you tell if your catalytic converter is bad? - FSB Forums
Thread Tools Display Modes
Old 08-22-2010, 12:45 AM   #1
rhauf
rhauf's Avatar
Bronco Info: 82 bronco 408w 4" lift 35's, 88 bronco 351w all stock on 31s
Does anyone know if its possible to tell a bad cat from a good one?
i have my exhaust cut apart and they look fine inside.. (normal honey comb looking stuff, not falling out, rotted or clogged) so i'm wondering if they are good or bad?
reason i suspect them, is because it barely passed smog last time (year ago) and the smog tech thought it was the cats going bad. but they look fine.
can they be worn out and still "look" good?
-Ryan
Check out my youtube page. Many bronco videos.
http://www.youtube.com/user/rhauf1
rhauf is offline   Reply With Quote
Old 08-22-2010, 08:59 AM   #2
Jayrus
Bronco Info: 88 Bronco,4.9l,T18 4 speed,never finished
The only true way to test a converter that appears fine physically is with an o2 sensor before and after cat.The primary job of the cat is to convert the harmful emissions from the engine to a cleaner exhaust out the tail pipe.The ability of the cat to "light off" and store and release oxygen does deteriorate over time.The only way to check its ability to do so is with a second o2 after the cat or a tailpipe test.If you are certain the engine is mechanically running correct but the emissions reading is high there is a good possibility the cat is going bad.In older vehicles without the second o2 to trip the dreaded 420,421,430,or 431 codes (cat efficiency codes)a good indicator is an elevated NOX reading.
Jayrus is offline   Reply With Quote
Old 08-22-2010, 02:04 PM   #3
lazerz69
Bronco Info: 1995 EB / 1995 XLT 5.8 stock 31s
Your rig will also give symptoms if the cat is clogged. You can jump on the gas and your rig will bogg down, you will not be able to go over a certain speed. Also the cat will get extremely hot after running the rig.
lazerz69 is offline   Reply With Quote
Old 08-23-2010, 12:02 AM   #4
snowman86
Bronco Info: 86' mild build 302 currently putting it back together
yeah your exhaust will get very very hot and you'll most likely have lack of power problems when going more than 75 % throttle. pending on if its clogged. On some the element will break and rattle inside them even. Also when a cat goes bad you can most of the time smell them. Id say cut it out and replace with a straight pipe and pop in a few 02 simulators. but thats just me haha. Im not sure if the element can just wear out though in your case.
snowman86 is offline   Reply With Quote
Old 08-23-2010, 12:57 AM   #5
pfun41
pfun41's Avatar
i think my cats either clogged or bad, it seemed really hot last time i was under there and i only drove it like 2-5 minutes. also it doesnt liek to rev, higher rpm power isnt good.
Say no to Brodozers!
pfun41 is offline   Reply With Quote
Old 08-23-2010, 10:03 PM   #6
garys b.b.b.
garys b.b.b.'s Avatar
Bronco Info: 93'XLT 302 v8 e40d 4" rc lift 35x12.5x15 bfg at
hi guys I'm new here just got my 93 bronco from crigslist i was happy to find this site after buying it...ok down to the ? its got 220k on the original motor and the exhaust looks bad, motor starts good and runs good for being that old but feels sluggish ..so the cat has this tube coming out from it an heading back up toards the motor its steel and rusted off or broke some how,
this set up is new to me so i don't under stand why its there or how bad it is to have it broke off the cat must be leaking ...im thinking of just replacing the whole exaust from the heads back ..does a cat get clogged up after 220k miles? thanks i know I'm all over the place
garys b.b.b. is offline   Reply With Quote
Old 08-24-2010, 08:08 AM   #7
KM81
Bronco Info: 87 Bronco (The Plow Truck) 89 Bronco (The Parts Truck) 90 Bronco (Frame Off Resto Truck)
220k is a lot for an original cat! And that tube is your EGR Tube
KM81 is offline   Reply With Quote
Old 08-24-2010, 12:53 PM   #8
pfun41
pfun41's Avatar
the egr tube takes exhaust from the manifold on the engine. what hes talking about is the AIR tube for the smog. if thats not working the cat prolly wont get up to temperature and itll clog.
Old 08-24-2010, 01:04 PM   #9
Smok3y
FSB's Dirty Jersian
Smok3y's Avatar
Bronco Info: 89 EB, 91 Silver Anniv, 91 F250, 79 F250
your cats will turn red hot like a cigarette lighter, and most often times you'll smell a rotten egg smell from the car behind you. Lack of power is another big sign. Its pretty hard to tell if they're bad unless they get totally clogged, or unless you have an 02 sensor. I always recommend replacing them before you need too. every 65-100k miles is a good marker. My dad owned a 78 caprice (beautiful car, it was pristine) and my mom took it over to philly to pick up hard to find presents for my little sister in 2002. Cat was clogged and the car ended up lighting on fire on the bridge, and my mom didn't even know it. someone ended up pulling in front of her and stopping. As soon as she got out, she said the seat lit on fire.
So just a little story for you guys. I know its rare, but just something to think about ya know...
89 Eddie Bauer - 6" RC Lift, 35" KO's, 302/c6 swap, Ford 9"
79 F250 Ranger Lariat - 9" Lift, 40" Ground Hawgs, 400/435/205, D60/D70 LOCKED
Originally Posted by SigEpBlue
All I want people to do is STOP, THINK, and SEARCH. Only post if those three fail after thoroughly repeating.
Smok3y is offline   Reply With Quote
Old 08-24-2010, 01:08 PM   #10
pfun41
pfun41's Avatar
sounds a but frequent dont ya think?
Old 08-24-2010, 01:18 PM   #11
Smok3y
FSB's Dirty Jersian
Smok3y's Avatar
maybe. I mean I usually do it every 100k. My dad had a pretty new exhaust system on the car when it burnt up, so its always been a scary thought in my head. Plus my exhaust system gets changed often on my vehicles. Maybe I exaggerated a bit at 65 that'd be ridiculous, but again, that thought of the car burning up will stay with me forever. She said had she gotten out of the car 30 seconds later she would have been burnt badly. I'll see if i can find the pictures my mom took of it on fire.
Old 08-24-2010, 01:23 PM   #12
JfB_93
The "Dim"olitioner....
JfB_93's Avatar
Bronco Info: 1986 Bronco XLT 2bbl 351w, c6, Np208, 3.50 gears front and rear, front quad shocks, factory tach.
My 88' would bog down, backfire, and idle rough and be really hard to get up to speed even when mashing the gas pedal to the floor, cut both cats off(Cali truck) and now it Idles and gets up to speed just fine.
Ken
<----- Clicky.
You gonna pull those Pistols or whistle Dixie?
My Gallery.
"Oh, I wish I was in the land of cotton, Cinnamon seed and sandy bottom, Look away, look away, look away Dixie Land."
JfB_93 is offline   Reply With Quote
Old 08-24-2010, 01:26 PM   #13
pfun41
pfun41's Avatar
i wonder if hi flow cats last longer.
Old 08-24-2010, 01:56 PM   #14
Vannnce
Too poor for FSM
Vannnce's Avatar
Bronco Info: '89XLT 351w w/C6. 6.5" lift SAS's 44. K&N, 3" Exhaust. 2002 f350 7.3 with some goods
I got a question because i think mine is bad. (High speeds theres noo power)
Im worried i replace the one closest to the rear, and nothing happens because its the one in the y pipe itself. Is it common that the y pipe clogs or should i be good with replacing the one closest to the rear?
Vance
www.FourEyedPride.com 79-89 Fox body mustangs/Capris
Vannnce is offline   Reply With Quote
Old 08-24-2010, 01:56 PM   #15
Vannnce
Too poor for FSM
Vannnce's Avatar
Woops double post
Vance
Old 08-24-2010, 10:11 PM   #16
garys b.b.b.
thanks ill check to see if it gets red for sure! about that tube it flows air back to the heads ?just asking so when i fix it im sure the aouther end that it connects to is just as bad. so you would u say i should just plan on replacing it since that tube is toast? ive seen this magnaflow high flow cat direct fit for like 200 bucks any addvice or better choice out there ?
Old 08-24-2010, 11:07 PM   #17
pfun41
pfun41's Avatar
think of it this way, the farther the trub gets from the exhaust the less heat and corrosive elements it experiences, so the less damage it will see.any decent metal pipe will work though and you can use high temp tubing to splice it in.
Old 12-08-2014, 10:07 PM   #18
Symbotik
no catalyic converter
Please help...I have read through the thread and My 88 Bronco is showing all symptomsof a clogged or bad catalyic converter...I looked under the rig and I don't see it anywhere...may have been bypassed already....what other things could causethe same ssymptoms...EGR maybe....exaust smells rich with fuel. please help I need to get my bronco running...family car is dying and the bronco iis only other mode of transport
Symbotik is offline   Reply With Quote
Old 12-08-2014, 10:38 PM   #19
jopes
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
Starting your own thread in newbie tech will be more helpful than bumping a thread that is 4 years old.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd, GTP38R noise maker, Stage 2 injektorz. Lotsa fun!
Let's Go Fishing.
jopes is offline   Reply With Quote
Old 12-11-2014, 08:42 AM   #20
JohnMcD348
JohnMcD348's Avatar
Bronco Info: 92 Factory Original 300 I6 M5OD Manual Custom. 3 seats, AC and a radio and all vinyl interior.
I've been wondering about that since I replaced my entire exhaust system. I used a newer, single catalytic converter instead of using the dual units. I did keep the Air tube style and have it plumbed into the AIR system on my 92 4.9L. Prior to replacing the exhaust, I smelled a fuel smell, like it may be running rich. After the replacement, I get that Rotten Egg smell.
I went up to a 2" factory style replacement using Walker stainless components. It's not like I went with Super High Flow, Super Loud, Free Flow everything. I tried to keep it slightly better than stock.
Any ideas where I should really start looking at my emissions to see where the issue could be? I ran codes awhile back and it did come up with one, the SPOUT failure or something like that. I don't remember the exact code but it was the one regarding the SPOUT.
JTMcD.
We sleep Peaceful in our beds because Rough Men stand ready in the night to visit violence upon those who would do us harm............George Orwell
The object of life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting, 'Holy Shit, What a Ride!!! -- Mavis Leyrer
MY A/C Vacuum leak repair http://fullsizebronco.com/forum/showthread.php?t=175808
JohnMcD348 is offline   Reply With Quote
You may not post replies
Forum Jump
