Proper way to bypass the rear window switch - FSB Forums
Thread Tools Display Modes
Old 05-01-2004, 09:16 PM   #1
dedejong
Bronco Info: 1993 FORD BRONCO XLT, 5.8 2.5" LIFT, 33-12.50-15
Ok tailgate is on but same problem as with others, motor works direct to a battery but not with the switch up front. Being the sick person that I am, I decided "we don't need no stinking latch switch" So to bypass it I found that the switch up front was working properly back at the tail light. Up gave power to 1 pink wire and down gave power to the other. This is probably completely wrong but I spliced the 2 pink wires directly to the 2 yellow & red wires off the motor. (seperately of course) However it still don't work. I would think there needs to be a ground somewhere doesn't there? Anyway how is the proper way to bypass the system. I don't even want the key to work just the front switch.
dedejong is offline   Reply With Quote
Old 05-01-2004, 10:04 PM   #2
blueoval78
Building gold from crap
blueoval78's Avatar
you can get a new switch if you think its blown, jeffs has them
someday............
blueoval78 is offline   Reply With Quote
Old 05-02-2004, 01:23 PM   #3
TTBlows
TTB Hater of course
The dash switch is always grounded, and so is one side of the motor. To go one way, the switch just applies power to the other motor wire. But to go the other way, it interrupts the constant ground and grounds the other wire, then applies power to the wire which is normally grounded ft.
This might at least get you going in the right direction.
Totally Twisted and Broke makes me a saaaad Panda
"You can almost see the dismay on Phil, Paul & Bob's faces when Trautwig is talking....and the pause in their voices after he stops....after which they pick-up the pieces of his non-sensical commentary and continue with their telling of the story that is the Tour de France! "
TTBlows is offline   Reply With Quote
Old 05-02-2004, 04:21 PM   #4
dedejong
Ok, thanks guys I think one of the biggest problems is woos motor that works the window. Wonder if it's possible to get more power out of it?
Old 05-02-2004, 05:58 PM   #5
stangmata
WTF,O
stangmata's Avatar
Bronco Info: Bronco-less
Bypass the switch by bridging a wire across it. That easy...
stangmata is offline   Reply With Quote
Old 05-02-2004, 06:38 PM   #6
IWant1
any pics??
i've tried to hack this business, but i can't find the switch. It's hard to work inside the tail gate. I know there's a whole wire harness thing in the tailgate, but what does the switch look like, and where is it attached? I can't wait to get my rear window working....
Thanks, tim
IWant1 is offline   Reply With Quote
Old 05-02-2004, 08:03 PM   #7
miesk5
I used to know this stuff
miesk5's Avatar
yo, Tailgate Harness detailed pic by Ryan M (Fireguy50) at fordfuelinjection.com
Replacement (many photos) by Dustin S (Mellow Yellow, Mr. Laser Boy)
constant power by ttb blows/Chis B
more t gate pics/articles Linked below in my site, Part 2, under Body.
USN (Ret) & MIL/DoD Contingency Planner (ret)
THANKS to ALL WHO SERVE!
my broncolinks.com was "disturbed"; but some sections are archived @ http://web.archive.org/web/201209211....com/index.php
Old 05-02-2004, 10:19 PM   #8
stangmata
WTF,O
stangmata's Avatar
If you need any further pics then what was just provided then let me know. I can take pics of the tailgate tomm night if needed.
You may not post replies
Forum Jump
