Harmonic Balancer Removal 302 - FSB Forums
Thread Tools Display Modes
Old 11-30-2010, 11:57 AM   #1
MikeW
In Front of Jopes
MikeW's Avatar
I have a 1996 302 in a Bronco. Do I need to place a strap on the pulley or will I be able to free the nut with a breaker bar without rachet strap?
Right hand or left hand threads? I do have a puller after all bolts are romoved.
MikeW is offline   Reply With Quote
Old 11-30-2010, 01:31 PM   #2
milan65
Bronco Info: 1995 5.8L 6", 35BF Mud, K&N, 3G 130A, Sagn, York, Magnaflow, Flowmaster, Flowtech, Deaver, SAS
Hi, it's regular right hand (to tie it down) bolt. The strap on pullye will not be enough. You need to put a clamp around the pulley and use breaker bar with a pipe on it. Or use big size pipe wrench if you have one. I did mine last weekend. It took a lot of power to loose that bolt. I killed one of my clamps (from Habour Freight) doing it. Yes you need to use puller to take it out. the one form Autozone works fine but the bolts supplied with the puller are useless. Milan
milan65 is offline   Reply With Quote
Old 11-30-2010, 05:44 PM   #3
sackman9975
sackman9975's Avatar
Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
Getting the front bolt out can be tricky. My method is to put the 15/16 socket and ratchet on the bolt. Have a pipe handy and position the ratchet on the drivers side to unloosen. Slip pipe onto the ratchet and rest it on the floor. Then just bump the starter. The bolt will then be loose. Make sure to remove the washer as well that's with the bolt. Not doing so, and you'll break the balancer.
~ Scott ~
~My Exhaust clip on YouTube ~ 204k on the odometer and no longer a daily driver. ~
~ Bronco owner/Driver/Mechanic/Enthusiast for 21 years ~
sackman9975 is online now   Reply With Quote
Old 11-30-2010, 09:41 PM   #4
95F1504x4EB
95F1504x4EB's Avatar
Bronco Info: 1995, F150, MAF 5.0L, 4R70W, BW 1356, 3.31 gears, 31x10.50s, Eddie Bauer Edition
This method works like butter.
I removed the balancer pulley before doing this, so I could see better. I also removed the coil wire to ensure the engine would not start.
95F1504x4EB is online now   Reply With Quote
Old 11-30-2010, 11:05 PM   #5
3speed
Bronco Info: 1996 Bronco XLT 351W
To remove the balancer...you'll need a simple cheap puller. I had a flywheel puller for small engines that worked perfectly.
On the big bolt...to remove I just used my 3/8 impact gun and it came right loose. To retighten...I installed two long bolts in the tapped holes and used a decent sized Napa pry bar (with handle) between the two. Then torqued using my trusty torque wrench.
1996 Bronco XLT
351W E4OD
Blue/White, Stock
3speed is offline   Reply With Quote
You may not post replies
Forum Jump
