4" lift 37" tires - FSB Forums
Thread Tools Display Modes
Old 12-13-2010, 07:03 AM   #1
Venumus1
Bronco Info: 90 EB 6" lift 35x11.5x17 BFG comp racing tires <*RIP*) 78 with 429 and soon custom 4" lift with 35
4" lift 37" tires
Hey guys i was wondering if I could tuck a 37" tire with a 4" lift I knw u can run 35 s stock with out rubbing or trimming under normal use and was wondering if any1 has put 37s on a 4"
Venumus1 is offline   Reply With Quote
Old 12-13-2010, 07:59 AM   #2
Robs79BBbronco
Robs79BBbronco's Avatar
Bronco Info: 79 Ranger XLT-460,NP435,NP205,stock axles/3.50's,2.5"RC lift,33"trxxs mt's,72 impala horn(best mod)
what....on the '78? probably.........but every truck is different.
Robs79BBbronco is offline   Reply With Quote
Old 12-13-2010, 08:26 AM   #3
Venumus1
Yeah I apologise for the 78 I feel like 6" lift with 37s might be to big to do the kinda rigging I do but I'm unsure if I should just man up and do the 6 like I originally planned with 37x13.5x16.5 on military humvee rubber with Lincoln locker in my 9"
Old 12-13-2010, 09:22 AM   #4
LarryP
Thanks 351w500
LarryP's Avatar
Location: Northcentral,CA.Twain Harte, up here in the mountains
Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
Yes 37's will fit no problem with a 4" lift.
I take Prayer Requests. God Bless
LarryP is offline   Reply With Quote
Old 12-13-2010, 09:52 PM   #5
s8c2
s8c2's Avatar
Bronco Info: 95 xlt, 302, 36's, 4.56's, dents, spray paint, usually a broken mirror or two
and you know humvee tires suck in the mud right? and i assumed they'll be in a lot of mud since you're planning on lincoln locking the rear. they just sound cool cuz they have the word "humvee" before them. i was an army truck driver for 6 years
i heard that if i use this space to tell you what kinda plug wires i use ill get bonus cool points
s8c2 is offline   Reply With Quote
Old 12-14-2010, 09:19 AM   #6
offroad ford
Bronco Info: 88' f150
And they also suck on asphalt, concrete, rock, and just about any other earthly surface. Why else would the government spend millions on them:)
88' f150 5.0 c-6 trans conversion 6' skyjacker full kit extended rad. arms 38.5 tsl's on eaton beed locks, currently with 8.8, 44ttb, 4:56 detroits front-rear. in the build stages Dana 60 hp 4:88 arb front 14 bolt spooled rear with custom three link and full hydro steering. 1356\1356 doubler on the list.
offroad ford is offline   Reply With Quote
Old 12-14-2010, 10:08 AM   #7
TopGunn
TopGunn's Avatar
Bronco Info: 1996 Bronco EB
Anybody have pics of this? Both my buddy and I are putting 4" lifts on our Bronco's, hes going with 35's I was thinking about going with 36" tires. We don't wheel hard and when we do wheel its mostly mud/water so the stock drive-train shouldn't have to much trouble with the slightly larger tire. Just looking to see if they look "TOO BIG" for a 4" lift.
TopGunn is offline   Reply With Quote
Old 12-14-2010, 10:45 AM   #8
LarryP
Thanks 351w500
LarryP's Avatar
My 78 4" lift with 35" tires.
Old 12-14-2010, 01:01 PM   #9
s8c2
s8c2's Avatar
they'll fit on a 96... whether or not you can steer without fender trimming is another question though
Old 12-14-2010, 01:17 PM   #10
Shane C.
Shane C.'s Avatar
Bronco Info: 78 Bronco, FI 460/1995 RIP
The ability for any given Bronco to accept large tires based on a specific lift size is dependent on the year. This is an excellent thread for the 80-96 model years: http://www.fullsizebronco.com/forum/...ad.php?t=17022
I have a 4 inch lift and 35s and I added an additional half inch to the front and still had to slightly trim the fenders and bumper. If you go 37s on a 4 inch lift, you will have to cut the fenders substantially and will quickly discover other issues running that large a tire on a TTB as well (parts wear out quickly, or bend or ??).
IMO, 4 incher and 35s is perfect...
My other car has doors.
Shane C. is online now   Reply With Quote
Old 12-14-2010, 02:06 PM   #11
Smok3y
FSB's Dirty Jersian
Smok3y's Avatar
Bronco Info: 89 EB, 91 Silver Anniv, 91 F250, 79 F250
I know this pic is small, but this is a 79 bronco 4" lift on 35's
Definitely will tuck 36's and prob 37's. I know on 6" lift its recommended for 38"s but you could probably tuck 40's, and i'm on 9" of lift, they recommend 42's, but I could definitely stuff 44's.
89 Eddie Bauer - 6" RC Lift, 35" KO's, 302/c6 swap, Ford 9"
79 F250 Ranger Lariat - 9" Lift, 40" Ground Hawgs, 400/435/205, D60/D70 LOCKED
Originally Posted by SigEpBlue
All I want people to do is STOP, THINK, and SEARCH. Only post if those three fail after thoroughly repeating.
Smok3y is offline   Reply With Quote
Old 12-14-2010, 04:35 PM   #12
Joe S.
sawzalls are your friend!
i like em as low as possible and dont mind cutting as long as it is my wheeler and not DD... if i get a little mud in the cab, its ok. that is why they make water.
Joe S.
Central MS
offroader1994 at yahoo dot com
Joe S. is offline   Reply With Quote
Old 12-14-2010, 05:31 PM   #13
LarryP
Thanks 351w500
LarryP's Avatar
We are talking 78/79 broncos here. Tire fitment and lift size is way different the the 80-96 broncos.
Old 12-15-2010, 01:41 AM   #14
TBIAgent69
Bronco Info: 1992 Bronco EB
When I got my bronco it had 37's on it. Granted, it's a 92 so I can't tell you how they'd fit on yours, but I must strongly urge you to make sure you have the proper gearing or you will hate your life. I couldn't drive faster than 50 because the truck was just sooooooooo gutless.
1992 Eddie Bauer. Needs one of everything except for water pump, ps pump, heater core, transmission, starter and alternator. 3G 130A (First and best upgrade so far) Optima red top.
TBIAgent69 is offline   Reply With Quote
You may not post replies
Forum Jump
