302/5.0 efi to carb swap - FSB Forums
Thread Tools Display Modes
Old 12-30-2010, 11:18 PM   #1
67galax
67galax's Avatar
Bronco Info: 1996 XLT 5.0/E4OD 6" Lift, 35's 1996 F150 4x4, 5.8L 33's and plenty of rust
first off, i would have put this in the 80-96 tech section, but i don't have enough posts to do so. also, i've done a VERY quick search and didn't see anything like what i'm thinking about. so here goes...
has anyone ever considered doing an EFI to carb swap on a 5.0 motor, but keep the lower EFI intake? what i'm thinking is, custom build an upper intake with ports to match the lower efi intake, but adapt it to fit a 4bbl or 2bbl carb? i know that i'd have to have a fuel pressure regulator inline to turn down the psi on the fuel, and i'd probably need all types of electrical rerouting to get around the computer (trans, ignition, etc).
what i'm looking for is a reversible way to have a carbed 5.0 motor in my bronco, without really tearing into any 'wet' gaskets, and be able to swap it back to EFI once a year whenever emissions inspection comes calling, or if there were ever an event where my stock computer was fried and i needed the good old-fashioned carb to get my motor to run.
please don't beat me up too bad on this. just wondering if anyone has ever had a similar thought.
67galax is online now   Reply With Quote
Old 12-31-2010, 01:41 AM   #2
92Custom
92Custom's Avatar
Bronco Info: 1992 Bronco Custom, 302/5 speed/4x4. pretty much stock.
What do you have to gain? Like, what on earth do you have to gain?
SEFI(what you have)>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>>>>Speed Density EFI(what my 92 has)>>>>>>>>>>>>>>>>>>>>>>>TBI(primitive, crappy EFI)>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>carburettor.
Carbs suck. They use more fuel, pollute more, make less power, are a total bitch to start when it's -10*F out, and need to be tuned. EFI uses less fuel, pollutes less, makes more power, more easily, starts like a charm no matter the weather, and you NEVER have to tune it.
Why go carb?
1988 Thunderbird Turbo Coupe, 2.3 OHC with turbocharger and intercooler/5 speed, time warp late 80's high speed road trip car/police magnet....
1992 Bronco Custom, 302/5 speed, lots of new stuff
1993 Tempo GL 2-door, 2.3 HSC/5 speed, my first car, probably giving to girlfriend to drive so I can justify keeping it around
92Custom is offline   Reply With Quote
Old 12-31-2010, 02:14 AM   #3
67galax
67galax's Avatar
OK, lincoln, you obviously don't get it. i'm asking if anyone has ever tried efi to carb, not what you think about this particular idea.
if TSHTF, and my computer didn't work, would anyone have a setup ready to run without a computer, without having to change the lower intake to make your bronco run.
if anyone understands and wants to comment, i'm all ears.
Old 12-31-2010, 03:13 AM   #4
Andrew James
Age. Fac ut gaudeam
Andrew James's Avatar
Bronco Info: 1978 Ford Bronco RangerXLT 400/C6
That's actually pretty cool idea. Pretty ingenious concept. When TSHTF and we get an EMT strike, were all fawked because of the hordes of electrical bullshit in these rigs...
1996 Ford Bronco Eddie Bauer 5.8/E4OD EFI
1978 Ford Bronco Ranger XLT 6.6/C6
2008 Jeep Liberty 3.7/42r
2002 Honda Shadow Spirit 1100
Andrew James is offline   Reply With Quote
Old 12-31-2010, 03:22 AM   #5
92Custom
92Custom's Avatar
That electrical bullshit also controls the ignition, but I have yet to see someone go back to mechanical ignition in one of these trucks. Most realized decades ago that it's just not as good.
Old 12-31-2010, 03:23 AM   #6
TheUnforgiven
Huh Huh vanzercool
TheUnforgiven's Avatar
Bronco Info: 2005 Chevrolet Venture, 1997 Acura TL
this isn't fawking zombieland dude.
2005 Chevy Venture. 1997 Acura TL. $500 beater.
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 12-31-2010, 03:33 AM   #7
92Custom
92Custom's Avatar
Honestly? Go to a junkyard and pull a computer. How much is a decent carb, like $700? You can get BRAND NEW computers at rockauto.com for like $150 shipped!
Old 12-31-2010, 09:43 AM   #8
Madcat455
Madcat455's Avatar
Bronco Info: 89 XLT daily driver
Not easiely possible... It'd be easier, cheaper, and more practical for you to keep 5 computers in the back, before you attempt this.
First, nobody makes an upper that'll bolt to your lower for easy EFI to Carb swap. So you'll have to get wet by swapping the whole intake.
Second, you trans is controlled by your computer... if your ECM's fried, you're not shifting either. So you'd have to swap your trans for a C6, AOD, or stick.
Madcat455 is offline   Reply With Quote
Old 12-31-2010, 10:35 AM   #9
jopes
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
I moved it for you. And going EFI to Carb is not worth it. you will spend 1,000's to do so, then your talking about putting all the EFI stuff back on to pass emissions. Totally not worth it.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd, GTP38R noise maker, Stage 2 injektorz. Lotsa fun!
Let's Go Fishing.
jopes is offline   Reply With Quote
Old 12-31-2010, 10:49 AM   #10
hav24wheel
is hazardous to others
hav24wheel's Avatar
Bronco Info: Wagoneer, 351M, C6, upside down 205
I've thought about useing a EFI lower intake and making my own upper for a multi carb setup... It would be a nice high rise compaired to any carb intake...
But mine would be for a 302 goin into a 37 Ford pickup that I'm making a rat rod out of.. I have all these extra parts I can fit together so might as well lol
Wagoneer, Ford powered.
Excursion, V10
hav24wheel is offline   Reply With Quote
Old 12-31-2010, 12:47 PM   #11
broncoflorida
Bronco Info: 87FSB, 302 020 over ,3g alt, GT40 heads, Exp intake , Bassani Exhaust and 24" Magnaflow muffler
Very cool. I knew a guy who did just that with a early Ford PU ( 39 iirc ) setup as a NA drag truck, but he use a inglese manifold and stuck some weber carbs on it. A bitch to syncronize the linkage, but it ran like a bitch when it was tunned correctly.
I think he spent like 2K in carbs alone and the manifold was way over 900 dollars and are rare.
broncoflorida is offline   Reply With Quote
Old 12-31-2010, 11:37 PM   #12
seawalkersee
seawalkersee's Avatar
Bronco Info: 84 FSB with a 6.9 diesel/zf 5, supercharger, and 33s.
Why go carb?
Hmmmm...make less power, has to be tuned, hard to start? Hmmmm...once it is tuned correctly, there is no problem. None the less, even with me liking the carbs, I think this is a REALLY bad idea. Get it fixed right.
SWS
After Midnight Project music. Subscribe and see how good they are, and how good you will feel.
http://www.youtube.com/watch?v=1HPBejDwWVI
seawalkersee is offline   Reply With Quote
Old 01-01-2011, 10:54 AM   #13
ProBronco
ProBronco's Avatar
Bronco Info: 80 Bronco XLT 302 4sp, 4"lift on 35" Factory LS F&R
I will add is this:
With SOM much HELP and INFO on the THIS site and web EFI is easy as pie to fix/tune compared to years ago.
Fireguy50 has some killer tech on there site, so get reading.
ProBronco is offline   Reply With Quote
Old 01-01-2011, 03:45 PM   #14
92Custom
92Custom's Avatar
SWS
Around here the annual temperature range can be from -10*F to 110*F. If you want to make a road trip west and through the rockies, watch the elevation climb quite dramatically. Elevation and temperature changes are things EFI can compensate for as it happens. Carbs...not so much.
Old 01-01-2011, 03:59 PM   #15
cptafw163
it would cost more for you to get this running from EFI to carb, than it would cost for chevy guys to switch from TBI to MPFI.
Get a new computer for 150 and be done. If you want more power, get in touch with some good SCT retailers who also offer some good canned tunes.
cptafw163 is offline   Reply With Quote
Old 01-01-2011, 04:41 PM   #16
huggyb1972
I did all for the Nookie
huggyb1972's Avatar
Bronco Info: 89' Bronco 5.8l Variable Speed V8, Forward, Rev, Turns left, right, stops, and everything.
I talked myself out of this route but you could fab up a box that the carb could bolt to. A new carb is gonna be around $400 with electric choke but I am under the impression that the old Q-jet works pretty good off-road so that could be cheaper, you could drop in a GM hei Ford conversion distrubutor or make a little duraspark distributor pack. In your particular case your still screwed because you have the E4OD so you'll need a controller for it. Like others have said your just throwing good money at an easy fix that is already capable of being reliable most of the time. Finding good ignition parts is the key to happiness on mine because everthing else seems to work just fine. Good luck
351W, ZF5-47, BW1356, 10.25/D60
FOTM DEC. 2011
"Quando Omni Flunkus, Moritati,"
When all else fails roll over and play dead.
huggyb1972 is offline   Reply With Quote
Old 08-20-2014, 11:29 PM   #17
devja71
"Carbs suck. They use more fuel, pollute more, make less power, are a total bitch to start when it's -10*F out, and need to be tuned. EFI uses less fuel, pollutes less, makes more power, more easily, starts like a charm no matter the weather, and you NEVER have to tune it."
-funny. I have NEVER been so miserable since 5.0 truck efi came out. Simple Motorcraft 2 barrels with manual choke and even my old quadrajunks where world's better than these things. Yes efi starts better yes. -but- Carbs use more gas? Pheh. My old '71 f100 302/C4 revving it's guts out at 60mph didn't use as much gas as my 89 bronco does when idling in park. Nor did my 1981 305 chev.
(And I'm not one to brag about overrated gm anymore. My magazine reading child years are over) someone needs to offer a very stripped-down sefi maf kit to retrofit and these s.d batch fire hunks o crap. Get rid of all that unnecessary wiring sensors etc. Better throttle-response, less idle-down hang time, far better mpg, and a neat clean appreance under the hood is a good place to start with these MILLIONS of trucks driving around the last couple decades
devja71 is offline   Reply With Quote
Old 08-20-2014, 11:36 PM   #18
devja71
-I can't remember where but I did read in an fte forum somewhere that someone ripped all the efi off his 89 pickup and installed an edelbrock 600/performer with a ford duraspark ignition and said the result was peppier and better mpg. That's all I remember reading. Take that as you may. I can sure believe it tho. Likely not as nice to start in the winter but if the carb is tuned good I could believe it. Just 2cents
Old 08-21-2014, 12:10 PM   #19
kemicalburns
Never Done
kemicalburns's Avatar
Being OBD-II and your e4od computer controlled this poses a great deal of time and effort. If you have both of those including the fab skills to build this box by all means give it a try.
your year bronco is probably the most complicated efi setup vs previous years. like mentioned you wont gain anything by doing this. it would be easier, cheaper to find an early 80's carb bronco or even a 78/79 bronco then doing what your asking. it would also drive better.
For Sale - 94 XLT 357/E4OD Trans-go stage II
6" Stage II ProComp,35" BFG/AT 4.88 f (aussie) / r (open) / Custom Sliders, Custom bumper Warn HS9500, Edelbrock truck upper/lower,JBA headers,Custom Y pipe hi flow cat & Full 3"
kemicalburns is offline   Reply With Quote
You may not post replies
Forum Jump
