Spark Plug Gap. - FSB Forums
Thread Tools Display Modes
Old 01-06-2011, 03:02 PM   #1
earles113
earles113's Avatar
Bronco Info: 1995 Bronco XLT 351W
Spark Plug Gap.
I've done everything on the ignition upgrade, including 9mm Ford Racing plug wires, motorcraft platinum plugs, Motorcraft cap and rotor, and ignition coil.
I haven't done the 10* bump on the timing, and I probably won't. Not anytime soon. So what should I gap my plugs to? I know .55 is for the complete Six Litre tune up, but what should mine be? The same?
Help is greatly needed.
1983 Mustang 5.0
kept playing with it til it finally went in all the way.
earles113 is offline   Reply With Quote
Old 01-06-2011, 03:03 PM   #2
TheUnforgiven
Huh Huh vanzercool
TheUnforgiven's Avatar
Bronco Info: 2005 Chevrolet Venture, 1997 Acura TL
gap them to .55, the larger gap is to make the coil work harder to produce a better spark.
2005 Chevy Venture. 1997 Acura TL. $500 beater.
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 01-06-2011, 03:12 PM   #3
95F1504x4EB
95F1504x4EB's Avatar
Bronco Info: 1995, F150, MAF 5.0L, 4R70W, BW 1356, 3.31 gears, 31x10.50s, 130A 3G, Saginaw, Eddie Bauer Edition
Yeah, go ahead and gap your plugs to .55" and see what happens.
No really, gap them to .055" and you should be good.
95F1504x4EB is offline   Reply With Quote
Old 01-06-2011, 03:15 PM   #4
TheUnforgiven
Huh Huh vanzercool
lmao, asshat.
Old 01-06-2011, 03:31 PM   #5
earles113
earles113's Avatar
Alright, thanks guys.
1983 Mustang 5.0
Old 01-06-2011, 04:04 PM   #6
jermil01
Charlie doesn't surf!!
jermil01's Avatar
Bronco Info: 1992 xlt, 351EFI, .040, E4OD, D44 SAS w/Trutrac,Detroit locked 8.8, MAF conv, Tweecer tuned
so why not bump the timing to take full advantage of the tune up??
Vote 4 Top 4x4 Site!!!
jermil01 is offline   Reply With Quote
Old 01-06-2011, 04:50 PM   #7
earles113
earles113's Avatar
Update
I have no possible way of doing it.
No timing gun, and no knowledge of how too.
Anyways, the plugs were gapped at .047, and all are now .055. I'm about to take it around the block a few times, should I be able to feel a difference?
1983 Mustang 5.0
Old 01-06-2011, 05:19 PM   #8
weasel-like animal
weasel-like animal's Avatar
Bronco Info: 1994 XLT 302/E4OD, manual xfer case and hubs, quad shocks
Go find out and post!
weasel-like animal is offline   Reply With Quote
Old 01-06-2011, 06:55 PM   #9
alan.cassidy
Bronco Info: 1996 Bronco EB 351W JBA Headers, Gibson cat back exhaust, K&N FIPK Air Filter, Accel 300+ ignition
I used to have a 1990 351 with a Jacobs Ignition pack and gapped the plugs at .55" and it failed emissions so I had to reduce the gap once a year.
alan.cassidy is offline   Reply With Quote
Old 01-06-2011, 07:39 PM   #10
earles113
earles113's Avatar
Maybe its because I was near a 1/4 tank of gas or that the gaping did something, but she hauled some serious butt down the street.
I have a little bit of an exhaust noise change, aslo.
I dunno, but I hope all of this did something, because I replaced a lot of stuff that wasn't broke. Old, but not broke.
1983 Mustang 5.0
Old 01-06-2011, 08:09 PM   #11
Seattle FSB
Seattle FSB's Avatar
Bronco Info: 1990 EB FSB, MAF, 6.7L, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
With all due respect, Earle, you were probably in need of a tune-up anyway and your replacement of secondary ignition parts is probably the best thing you can do to improve performance. Ignition components do not have to be "broke" to cause problems, just worn and less conductive.
Specific factory spark plug gap for a 1995 5.0L is .052 to .056 and for a 5.8L is .042 to .046, both at 10 degrees BTDC. Be advised that opening your 5.8L gap from factory recommendations will stress your ignition system causing increased wear of parts.
Ford increased the 5.0L spark plug gap in 1992, probably to increase the performance of the 5.0L. IMHO, opening the spark plug gap and bumping the timing in a 5.8L may or may not add a minor amount of pep, but at the cost of efficiency.
1990 Bronco, MAF, 408 Stroker, Level 10 E4OD, Currie F9+, Electric Boost Brakes, lots more...
Seattle FSB is offline   Reply With Quote
Old 01-06-2011, 08:14 PM   #12
justimm
justimm's Avatar
Bronco Info: 1990 Eddie Baur rebuilt 302 2" leveling kit w/32x12.5 Buckshot Mudders
did mine today too! didnt change the timing yet, but new wires, coil, plugs at .55, air filter, fuel filter.....my truck ran like an absolute BEAST afterwords!! Doesnt even drive like the same truck. 2 of the plugs i took out didnt even have the ceramic on them!! I can tell a HUGE difference gapping the mat .55 in stead of the .45 or so they were at!!
"If you aint first, you're last!" ~ Ricky Bobby
justimm is offline   Reply With Quote
Old 01-08-2011, 06:13 PM   #13
SPDY900
Bronco Info: BLUE 96 XL W/351, E4OD, 205K MI.
I bought some bosch platinum plugs today and was told the gap should be .40. The old plugs were set at .44, it still runs like poop.
SPDY900 is offline   Reply With Quote
Old 01-08-2011, 06:26 PM   #14
fordbronco1995
fordbronco1995's Avatar
Bronco Info: 95 Ford Bronco,White Ext,Blue Int,5.8L 351. 18'' Chrome Wheels,33'' Nitto Terra Grapler A/T And More
Spark Plug Gap 1.07-1.17 mm (0.042-0.046 inch) factory spec.
"JUICE"
fordbronco1995 is offline   Reply With Quote
Old 01-08-2011, 07:51 PM   #15
Seattle FSB
Guys, guys, the best spark plugs for your Bronco 5.0L/5.8L is the cheapest copper spark plugs you can find, such as Autolite.
Platinum is a precious and rare metal which is used in spark plugs due to it's high corrosion resistance and longevity. On the other hand, Copper is by far a much better electrical conductor and, at about a buck apiece, you can afford to change them four to five times as often.
I wonder why Air Flow Research (AFR) recommends Autolite 3924 Copper Core Spark Plugs ($1.50 each) for my performance heads?
I am confident that your gaps of .44 and .55 are simple typos (thats about half an inch!) instead of the factory recommended .044 (forty four one-thousanths of an inch).
Old 01-08-2011, 07:59 PM   #16
fordbronco1995
I wonder why Air Flow Research (AFR) recommends Autolite 3924 copper Core Spark Plugs ($1.50 each) for my performance heads?
i run motorcraft spark plugs, just like what came factory.
"JUICE"
You may not post replies
Forum Jump
