smog/air pump - FSB Forums
Thread Tools Display Modes
Old 01-07-2011, 10:13 PM   #1
Rushcanuck
Bronco Info: 1995 Bronco XLT
smog/air pump
I just completed a rebuild on my 95 Bronk's 351 I found my smog/air pump was seized solid, I gotta breaker bar trying to free it but its a no go, could I just get a shorter belt and just run it a be fine, I went to the auto parts store and they said it would be $200 for a new one, Im not too keen on that number, maybe I'll try a auto wrecker. and if it wont run fine what would be the symptoms Im really quite interested on what they would be so
thanks
RC
Rushcanuck is offline   Reply With Quote
Old 01-07-2011, 10:46 PM   #2
chakakan
chakakan's Avatar
Bronco Info: 79 XLT 351M (sold) 1978 FSB 351M (sold) 1995 FSB OJ edition (sold) current 1995 SPORT 5.0 now
smog pump
IIDK if you being in Canada is the issue. I"m about to buy a new one (bearing whining) and have checked Rockauto.com and advanced auto parts. They both have them listed for around $100.00 U.S.. With exchange rate and int. shipping I would not expect it to double the cost.
chakakan is offline   Reply With Quote
Old 01-07-2011, 11:00 PM   #3
vmirmow
vmirmow's Avatar
Bronco Info: 1979 351M 4BBL C6 Ranger XLT converted NP203 35 inch Maxxis Bighorns
The air pump is used to inject fresh air into the exhaust stream before the cat to facilitate a reaction to cut down on emissions. If you disconnect it without removing the cat I think the converter will clog up, resulting in a serious compromise in performance, choking and restricting your exhaust.
vmirmow is offline   Reply With Quote
Old 01-08-2011, 12:01 AM   #4
Andrew James
Age. Fac ut gaudeam
Andrew James's Avatar
Bronco Info: 1989 Bronco Custom 4.9/M5OD EFI
What he said..^---^
Either gut/remove the cats to suit or fix the pump. But yeah, it's not crucial for engine operation.
1991 Ford Bronco XLT 5.0/E4OD EFI
1996 Ford Bronco Eddie Bauer 5.8/E4OD EFI
1990 Pontiac Formula Firebird 5.7/T5 TPI
1991 Ford F150 Custom 4.9/M5OD EFI
1993 Ford Mustang Convertible 2.3/AOD EFI
Andrew James is online now   Reply With Quote
Old 01-08-2011, 01:24 AM   #5
Rushcanuck
oh I already have the cats removed
Old 01-08-2011, 02:29 AM   #6
Andrew James
Age. Fac ut gaudeam
Then by all means, either replace it, or remove it.
Old 01-08-2011, 06:33 AM   #7
miesk5
I used to know this stuff
miesk5's Avatar
yo,
In case you want to restore this system; and help prevent S. CALIF type SMOG conditions from forming in your neck of da woods...
To help save you some hard-earned $$$$;
Rebuild
Rebuild (but the pump failed again) - Great Info Though!
Source: by RickyB at FSB
USN (Ret) & MIL/DoD Contingency Planner (ret)
THANKS to ALL WHO SERVE!
my broncolinks.com was "disturbed"; but some sections are archived @ http://web.archive.org/web/201209211....com/index.php
Last edited by miesk5; 01-08-2011 at 06:35 AM. Reason: added semi-colon because I AM ANAL
Old 01-08-2011, 09:17 AM   #8
f1fiddy
f1fiddy's Avatar
Bronco Info: 89 Bronco EB 5.0L AOD, 35" Mud Country's, 4'' Rancho,Ford 9" w/Aussie locker and 4.11 gears
I thought there was emissions testing in BC, or do you know a guy kinda thing. If you don't run the air pump you can really clean up the passenger side of the engine bay.
Custom front and rear bumpers
12K Tabor winch
Custom T-case skid plate
2 Pro Comp 130watt Lights
Custom Air Box with Dual K&N
f1fiddy is offline   Reply With Quote
Old 01-08-2011, 02:45 PM   #9
Rushcanuck
there is emissions testing in BC but only in the vancouver area where I am not so at the moment I dont need to worry bout passing them. I'll look into un-seizing my airpump tho, I'll just unbolt it and start playing around with it hopefully I can free it if not oh well. thanks for all the help.
Old 01-25-2013, 11:22 PM   #10
Tcmi3
If my air pump were disconnected in a '96 5.0 xlt, would it cause a trouble code?
Tcmi3 is offline   Reply With Quote
Old 01-26-2013, 12:11 AM   #11
Steve83
Steve83's Avatar
Yes.
http://www.fourdoorbronco.com/board/...ssions-Systems
Old 01-26-2013, 12:38 AM   #12
4x4_mafia_jon
i sell shit wrong
4x4_mafia_jon's Avatar
Bronco Info: 1989 bronco xlt. 302, AOD. Dana 44 SAS. ruffstuff "y" steering deaver coils,
Get me ur address and ill sell u the one I have sitting in my shed..
Sent from my LG-E739 using AutoGuide.Com Free App
just another FSB cover up
http:/dustycrawlers.com/index.php
4x4_mafia_jon is online now   Reply With Quote
Old 01-28-2013, 02:57 PM   #13
Americandan
Americandan's Avatar
Bronco Info: 95 5.0 XLT
I went to O'Reilly's to get a belt but I forgot where I saw the length for a 95 5.0 needed to this so I came to do a search and found this. Now i question if I should do this seeing how it can clog up the cat. Not that emissions counts for me but MPG/performance is and a clogged cat isn't going to work out that way. Maybe gutting the cat? If so, my truck is already loud, this is going to make it scream which is what I DON'T want to do. guess it's time to trade the 3" straight for a muffler and gut the cat.
I'm not racist, I'm just culturally insensitive...
Americandan is offline   Reply With Quote
Old 01-28-2013, 03:18 PM   #14
OL' HANK
THE GHETTO VAQUERO
OL' HANK's Avatar
Bronco Info: 1992 Eddie Bauer Bronco, 351w, E4OD, 4" Rancho lift, everything elses is stock.
Just had this problem this morning. Took it to my mechanic and we just took off the pulley and ran a shorter belt. Said I shouldn't have any troubles. Except when I go to do emissions, but other than that I should be fine. Found one at my local jy for $20 so I will head over there probably on Friday and grab it real quick. FYI the belt was only like 1" shorter than stock, I have a '92 with a 351. Didn't get a part number though. Sorry.
OL' HANK is online now   Reply With Quote
You may not post replies
Forum Jump
