#1 |
iTrader: (0) Bronco Info: 95 Ford Bronco,White Ext,Blue Int,5.8L 351. 18'' Chrome Wheels,33'' Nitto Terra Grapler A/T And More
rear seat, fold down?
is the rear bench seat in my 95 fsb supposed to fold down or does it just unlatch at the rear and pivot up?
"JUICE" |
| Sponsored Links | |||
Advertisement | |||
#2 |
![]() Join Date: Jan 2007
iTrader: (4) Bronco Info: 96 xlt 5.8 (blk) e40d
should fold on its self back to bottom than bottom up onto the floor. should be a release on one of the sides and than the one on the floor in the bed
black 96 5.8 xlt sport, e40d, edelbrock intake, bassani y-pipe, bilstien shocks, 32"bfg's azure blue 03 mach1 4.6 dohc "Sorry - no matches. Please try some different terms." |
#3 |
is there any other lever than the one in the rear?
"JUICE" |
#4 |
should be two. follow the side of the seat. there should be one that folds the back down. i would post a pic, but mine is in storage
black 96 5.8 xlt sport, e40d, edelbrock intake, bassani y-pipe, bilstien shocks, 32"bfg's azure blue 03 mach1 4.6 dohc "Sorry - no matches. Please try some different terms." Last edited by c-dub; 01-08-2011 at 07:42 PM. |
#6 |
ok yeah i found it, never knew it was there, is it supposed to go flush down to the floor?
"JUICE" |
#8 |
nah, going to take up the floor space behind the front seats
#9 |
ok thanks guys, i feel stupid, but that lever is barely visible, it blends in with the seat tracks, so what was the point of this, to give extra room to put 2x4's and stuff in there or what?
"JUICE" |
#10 |
give you an extra 2 feet of space. while still keeping the stuff in the back, well in the back. still not enough for 2x4's i think it only gives you 5'
#11 | |
"JUICE" |
#12 |
iTrader: (0) Bronco Info: '89 Eddie Bauer Ford Bronco 4X4
Plenty space for my wheeling gear, cooler, tools, bicycles.....shall I go on?
1989 "Eddie Bronco" 4X4 Mostly Stock "Just be patient, I'm a work in progress"
#14 |
iTrader: (0) Bronco Info: 1995 XLT 351W 3.55 33x12.5
If you need more room pull the seats out, just pull out the cotter pins and remove the kingpins on each side, I just had mine out to power wash the carpet, and man is it heavy and akward to move by yourself, a friend would be helpful
#15 |
Age. Fac ut gaudeam
iTrader: (2) Bronco Info: 1989 Bronco Custom 4.9/M5OD EFI
It's awesome, extra room I need for anything I ever haul.
1991 Ford Bronco XLT 5.0/E4OD EFI 1996 Ford Bronco Eddie Bauer 5.8/E4OD EFI 1990 Pontiac Formula Firebird 5.7/T5 TPI 1991 Ford F150 Custom 4.9/M5OD EFI 1993 Ford Mustang Convertible 2.3/AOD EFI |
#18 |
I used to know this stuff
yo, If you need more info on thsi & a lot of other stuff and you don't have the Owners Guide (Manual)
Get it for any Bronco/Ford truck & other Ford vehicles, free download for 96 to current year; (96 is = to 92 to 95 with just some minor additions such as the Overhead Console that came out in 94, I believe....) register to view w/VIN; includes Scheduled Maintenance Guide Source: by Ford via fleet.ford.com For ther Seat (I can't copy & paste the Images here) "Rear Flip Fold Seat To fold the seat forward: 1. The seat back latch is at the lower rear right hand side of the seat. Lift the latch handle to unlock the seat back. 2. Fold the seat back over the seat cushion until it locks into place. 3. Unlock the seat from the floor striker by lifting the seat latch handle at the center rear edge of the seat. 4. Lift the seat and fold forward. To remove and reinstall the rear flip-fold seat: 1. Remove the torque rod by releasing it from the right hand floor bracket (by pushing forward and up). 2. Remove the pin spring retainers and the pins from both the floor brackets. 3. Remove the seat assembly from your Bronco. Reverse this procedure to install the rear flip-fold seat. NOTE: It is important that you do not damage the seat belt hardware while removing or installing the rear flip-fold seat." A Mounting & Parts Break-Out Diagram in 92-96 by Ford via Steve83
96 XL 5.0 E4OD, Man Xfer/Hubs USN (Ret) & MIL/DoD Contingency Planner (ret) THANKS to ALL WHO SERVE! my broncolinks.com was "disturbed"; but some sections are archived @ http://web.archive.org/web/201209211....com/index.php Last edited by miesk5; 01-09-2011 at 01:03 PM. Reason: spAllAng |
#19 |
iTrader: (0) Bronco Info: 1992 5.8 XLT Rear LSD 3.55 E4OD 6" 27's
You rock once again miesk5 (and Steve83). I had the back seat out for a week for the first time and I couldn't remember how that torsion bar went. It IS friggin heavy! To make things more interesting I had to take out the seat through the passenger door to clean the carpet and seat (mold was closing my throat) so I could repair the back window motor. A week of drying and airing out and I forgot.
One dollar to piss away: McDouble or 92 5.8 ex-West Tisbury MA (Martha's Vineyard) police Bronco? Hmmm. |
#20 | |
Owned 17yrs, now for 20
![]() Join Date: Jun 2003
iTrader: (16) Bronco Info: 95XLT351 E4OD SAS 44/ARB/Alloy shafts-joints. D60 rear/Detroit. 4wheel disc,37" MTR Kevlar, 4.56etc.
The back seat is very clumsy and weighs in about 80lbs.
______________________ Click my supermotors link for tech on TCase, SAS, OBA, Soft Top, Overhead Console, Stock bumper Winch install, much more..: http://www.supermotors.net/registry/628 |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
