351M CAM CHANGE? - FSB Forums
Thread Tools Display Modes
Old 01-14-2011, 10:57 AM   #1
THUNDERBUGGY72
Bronco Info: 72 bronco 347 roush heads lockers front n rear 78 Bronco Ranger XLT new toy.
351M CAM CHANGE?
Hey fellas. I just bought a 78 Bronco RangerXLT. My first question...IS there such a thing as a RangerXLT Bronco? I should have done my research first i guess. Second Question....It smokes a bit(a lot) after it warms up and also makes a little noise in the timing chain area. Do I need to go back with a stock timing set or can I install a set with some advance without changing the cam? I am thinking of changing the valve seals as well to try and stop the smoking problem. I really don't want to put alot of money in this motor because I am building a 400 but I do want to drive it w/o cropdusting the entire area.
THUNDERBUGGY72 is offline   Reply With Quote
Old 01-14-2011, 11:17 AM   #2
joseph69
joseph69's Avatar
The stock timing chain was retarded by 4 degrees, so no, get one that has 0 degrees timing. Usually bad valve seals make it smoke only on start up and when shifting gears, so it may not be the seals making it smoke. Ranger and XLT are trim packages, so it may have been produced but I don't know, someone else know?
joseph69 is offline   Reply With Quote
Old 01-14-2011, 11:48 AM   #3
Scoop
Scoop's Avatar
Bronco Info: 78 Custom, 84 Custom, 69 Half Cab, 74 Ranger - stock, 76 Trail Rig
Yes, ALL 78-79 Broncos other than Customs were Ranger/XLTs. I believe you could only get separate "Ranger" or "XLT" packages in pick ups those years.
Round headlights are COOL (on '78's!)
September 2012 F.O.T.M.
78 Custom EFI Build Thread
84 300 I6 Build Thread
Scoop is offline   Reply With Quote
Old 01-14-2011, 12:05 PM   #4
bdevr
bdevr's Avatar
Bronco Info: 78, 406, 5:13's, 37" Toyos, 6"lift, ZERO RUST!
This thread explains all of the different trimpkgs for your year.
http://fullsizebronco.com/forum/showthread.php?t=106384
Somedays new cars with their stupid computers, little weenie engines & big payments just don't sound so bad..
"They are a big deal if you smoke or have a Tiki bar"
bdevr is offline   Reply With Quote
You may not post replies
Forum Jump
