265/75R15 vs. 31x10.5R15 - FSB Forums
Thread Tools Display Modes
Old 02-07-2011, 02:20 PM   #1
OJ-Runner
Are they the same tires and will both fit my stock 15 inches rims? I am looking at 4 that came off a Jeep Wrangler. I know Wrangler bolt pattern is not the same as FSB but wonder if the tires are the same. I need some good used tires at good price.
Additionally, if tires are stored indoor, will they have problem with dry rot? What can I do to keep them fresh and good?
OJ-Runner is offline   Reply With Quote
Old 02-07-2011, 03:00 PM   #2
ROCKZILLA
ROCKZILLA's Avatar
They are pretty close to the same size. They should be just fine on your stock wheels. Even stored inside they could have dry rot, if so theres nothing you can do. If not try to keep the sun off them and out of the weather as much as possible, like in a garage when not in use.
ROCKZILLA is offline   Reply With Quote
Old 02-07-2011, 03:23 PM   #3
offroadkarter
U jelly of my
offroadkarter's Avatar
265/75 is a 30" tire
1996 Ford Bronco Eddie Bauer
12 yards long, 2 lanes wide, 65 tons of American pride!
>>>super slow build thread<<<
2004 Mercury Marauder 1985 BMW 745i
offroadkarter is offline   Reply With Quote
Old 02-07-2011, 03:44 PM   #4
OJ-Runner
I just check..the tires are already mounted on stock ranger rims. I have no clue what that means. Assuming they are stock rims from Ford Ranger, they are probably useless for FSB, correct? By the way, it is stupid that there is no standard for lug nut pattern.
Old 02-07-2011, 04:10 PM   #5
ROCKZILLA
ROCKZILLA's Avatar
There is a standard for lug patterns.....hundreds of them depending on the vehicle
Old 02-07-2011, 05:20 PM   #6
BigRed93
BigRed93's Avatar
Bronco Info: 1993 Bko Xlt 302 E4OD 4.56's -33" BFG Km2s-Aussie locked
The Bolt pattern for a Ford Ranger is 4.5 not 5.5 like most your full size fords' five lug applications. The wheels are the correct size and all, but the backspacing is less agressive, and the center hub is smaller. As the Ranger uses the 7.5 rear, and something like a Dana 35 front. Hope that clears that up for ya. And what you're looking at for Tires are only about an inch off. You'll get basically the same tire though. 1 inch isn't huge, but it's something you might wanna consider. I dunno, which ever set is more agressive ( I guess if you're comparing two sets, rather than just two sizes), and w/e gives you the best bang per buck.
BigRed93 is offline   Reply With Quote
Old 02-07-2011, 05:29 PM   #7
AbandonedBronco
Big Six
AbandonedBronco's Avatar
Bronco Info: 1981 300ci 6cyl w/4bbl conversion. 4spd manual
265 75R15 = 30.6" x 10.4"
Most 31" tires are usually 30.5" - 30.8"
They're virtually identical. I think the main reasoning behind the different size ratings is the 265 75R15 is usually more of a street oriented tire whereas the 31x10.5" has a more "truck" oriented tread.
1981 & 1984. Both w/ 300 I6. Holley 465 / 600 4bbls. 31x10.5" tires. NP-435 trans. 2.5" Exhaust.
Supermotors Pics
AbandonedBronco is offline   Reply With Quote
Old 02-07-2011, 05:31 PM   #8
Redwagon
rolling Rolling ROLLING....
Bronco Info: 93 Cherokee
simple,
tires will fit
rims will not.
Tim
Newest token Jeep owner....
Redwagon is offline   Reply With Quote
Old 02-08-2011, 10:17 AM   #9
ottergt
Bronco Info: 96 Eddie Bauer, E4OD, 5.8, E303 cam, S/S headers, 3" Aerochamber exhaust, K&N, 8.8" 3.55 TrueTrac
Exactly. Optional Original Equipment was a P265/75/15 (P for Passenger Car). That was the size on my Bronco when I got it, and I just put on 31x10.5x15LT tires. No problem.
Just don't mix and match them.
--Otter
ottergt is offline   Reply With Quote
Old 02-10-2011, 03:18 PM   #10
BEAR5OH
BEAR5OH's Avatar
Bronco Info: 1994 Bronco XLT
--Otter
And the LT stands for Light Truck.
B.
"Pain heals. Chicks dig scars. Glory...lasts forever."
BEAR5OH is offline   Reply With Quote
  FSB Forums > Bronco Discussions > Wheels/Tires
You may not post replies
Forum Jump
