how to diagnose bad trans vs transfercase - FSB Forums
Thread Tools Display Modes
Old 02-19-2011, 06:14 PM   #1
paintballdude902
si vis pacem, para bellum
paintballdude902's Avatar
Bronco Info: 1989 Incendiary Device XLT 5.0 32x11.50 AOD
alright guys
the bronco was acting up and making some bad noises when i began cruising. so i flushed the transfer case hoping that was the problems.
today i went for a test drive it acted fine for about 3 miles then on my way home the transmission began spinning. by spinning i mean i was giving it gas but noting happened, RPMs went up and speed was going down. i ended up coasting home and pushing it around the block to park it.
i had my transfer case break off last year (PO had over torqed the bolts when he had the trans rebuilt and cracked the bolts) and it gave me the exact same symptoms that it is today. i checked the trans fluid and it was a little light colored (redish pink vs just red) but not burned.
im gonna drop the pan on the AOD tomorrow and check for any ball bearings or anything. the last fluid change was about 20k ago.
whats the best way to tell if its the trans vs the transfer case.
i really only need it to run for 60 days till i ship out for basic
I'm willing to die trying to keep them; Are you willing to die trying to take them?
Originally Posted by BRONCONUT View Post
I told my wife she would be more likely to leave before my bko.
USAF ballistically integrated tactical cargo handler
Originally Posted by c-dub View Post
If I had to pick a lord and savior it would be John Moses Browning .
paintballdude902 is offline   Reply With Quote
Old 02-19-2011, 07:46 PM   #2
Andrew James
Age. Fac ut gaudeam
Andrew James's Avatar
Bronco Info: 1978 Ford Bronco RangerXLT 400/C6
Try shifting into 4-low, and 4-hi.
Drop the pan, super easy thing to do and see if there's any shavings/chunks.
EDIT: My vote is on trans though.
1996 Ford Bronco Eddie Bauer 5.8/E4OD EFI
1978 Ford Bronco Ranger XLT 6.6/C6
2004 Jeep Liberty 3.7/42r
2000 Hyundai Tiburon 2.0/5speed
2002 Honda Shadow Spirit 1100
Andrew James is offline   Reply With Quote
Old 02-19-2011, 08:04 PM   #3
magnumpi
Wrenching for a Livin'
magnumpi's Avatar
Bronco Info: '85 Ford Bronco XLT.
if it was the transfer case it would have either jumped into neutral or something would have snapped/made noise/grinded.
Probably the trans. The AOD is kind of known for kicking the bucket. The TV cable didn't break did it? (cable that goes from the throttle down to the trans)
My SuperFord
'85 Bronco......
Welded 14 bolt, HPKingpin D60 w/ lockright, ZF5, NP205, 4.88 gears, SMPFI 393 w/ EDIS(gufx strat), Chevy 52s Front, Inboarded Chevy 63s Rear, DOM heim steering, DOM cage, Saginaw pump, 3/8" fuel system, 200amp 3G Alternator....
ASE Master Automotive Technician
ASE Master Medium/Heavy Truck Technician
magnumpi is offline   Reply With Quote
Old 02-19-2011, 11:32 PM   #4
paintballdude902
i had a grinding noise about 5 mins prior to losing power.
Old 02-19-2011, 11:47 PM   #5
Dustball
shibby
Dustball's Avatar
Is the transmission parking position holding the the truck? If yes- the t-case isn't the problem.
Does this "free-wheeling" happen in every gear position including reverse? If yes- you may have a broken flex plate or a screwed up torque converter. If the starter still turns over the engine, you can rule out the flex plate. I've had a broken flex plate and a broken torque converter on separate occasions.
Dustball is offline   Reply With Quote
Old 02-20-2011, 12:36 AM   #6
Andrew James
Age. Fac ut gaudeam
This is exactly what happened to my E4OD, drop it now before it gets worse.
Old 02-20-2011, 02:24 AM   #7
paintballdude902
park makes it stay still. explain to me how that rules it out, if you would be so kind. havent tried it in reverse... didnt feel like pushing it any more LOL.
Old 02-20-2011, 11:04 AM   #8
Dustball
shibby
Dustball's Avatar
The parking pawl is in the transmission. If the t-case was freewheeling (like putting it in neutral)- there wouldn't be anything preventing the truck from rolling.
You may not post replies
Forum Jump
