Water pump bolts - do any need sealant? - FSB Forums
Thread Tools Display Modes
Old 02-23-2011, 08:39 PM   #1
69SCJ
69SCJ's Avatar
Bronco Info: 1989, 5.0, auto, Eddie
Do any of the water pump bolts need sealant on them? As in do any go into water passages like a 302?
It's a 351M in my 79.
Thanks,
Tyler
No fullsize right now, but acquired an uncut I could not resist!
69SCJ is offline   Reply With Quote
Old 02-23-2011, 09:57 PM   #2
ehummelman
ehummelman's Avatar
Bronco Info: 1978 Bronco
I think just one of the timing cover bolts needed it, but not the water pump. That was on the 460 though, so I can't say for sure.
460 powered
ehummelman is offline   Reply With Quote
Old 02-23-2011, 11:09 PM   #3
plowboy
plowboy's Avatar
Bronco Info: 1979 Bronco 351M/T-18/205
I just ran a small bead of permatex around each hole when I put mine on. sealed up and never leaked.
plowboy is offline   Reply With Quote
Old 02-23-2011, 11:39 PM   #4
brothermo
Bronco Info: 1979 Bronco Custom, 400
Same here. A thin bead around all the bolt holes. I think I did this on both sides of the water pump gasket.
brothermo is offline   Reply With Quote
Old 02-24-2011, 09:19 AM   #5
69SCJ
69SCJ's Avatar
Thanks everybody.
I did the same. Just around the holes, but just wanted to make sure since two of the long bolts I took out appeared to have sealant on the threads. They could have just picked some up when they were put in last time.
Old 02-24-2011, 02:57 PM   #6
ehummelman
ehummelman's Avatar
OK, yeah I put sealant on the gaskets around the holes, but not thread sealant. I thought he was asking about thread sealant for where bolts go into the coolant passages and rust out. My bad.
460 powered
Old 02-25-2011, 10:32 AM   #7
69SCJ
69SCJ's Avatar
Just for clarity everybody, I was curious if any of the bolts went into the cooling passages like on a 302. There is a tendency for for water to seep around the threads of the if you don't use pipe sealant or RTV on those bolts.
Old 02-25-2011, 09:31 PM   #8
ehummelman
ehummelman's Avatar
Aha! I was right. You should be able to figure out which ones may hit coolant by just looking behind the pump as you slide the bolts through. I could on the 460, but I don't know about yours.
460 powered
Old 04-26-2011, 05:27 PM   #9
bigblue7879
bigblue7879's Avatar
Bronco Info: 1978 bronco lifted
always do every bolt is what ive heard
bigblue7879 is offline   Reply With Quote
Old 04-26-2011, 07:24 PM   #10
69SCJ
69SCJ's Avatar
I can confirm I have no leaks and didn't put sealant on the bolts.
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
