79 - 1 Ton 4X4 Dually - Diesel - FSB Forums
Thread Tools Display Modes
Old 03-09-2011, 08:45 PM   #1
natesms
Bronco Info: 1979
I know this isn't a Bronco, but I thought I would share some pics of my buddy's truck he's getting close to finishing up. He helped me build my Bronco and has done many other trucks, but this one is taking it to the next level. He never takes pics so I felt I had to share.
Some info:
Sitting on a 76 Highboy Frame.
91 Cummins mated to the Dodge 6 speed. Used the same motor mount kit as American Thunder. Also went through and replaced all the gaskets, put in the killer dowel pin kit, and a few other odds and ends. Thanks to the highboy frame and the divorced transfer case it made getting the drive line in not "all" that bad.
The front cross members had to be cut quite a bit to clear the motor and then new ones were fabbed up to keep everything reinforced. The Motor really does fit better in this truck than it did the Dodge. He did some fabrication to the pedals and a mount for the hydraulic clutch just next to the brake booster.
With the narrower highboy frame he was able to roll the rear axle off a 74 1 ton and springs directly under the frame with no spring perch modifications so all and all that was really easy.
Used the Dana 60 out of a 78 1 Ton for the front axle, and I missed all of that, but some work went into getting everything lined up and the steering to work the way he wanted. Steering box mounts were fabbed up and converted to "the non-sucky steering", not sure what that means exactly but it works well.
Lowered the transmission cross member and the TCase down just a bit, few custom drive shafts, and some linkage work and done. (It makes it all sound so easy)
He went through a TON of work finding quality parts for the cab, trim, grill, etc. I know of at least 6 parts truck to build this one. Everything that should have been rebuilt or replaced was (brakes, bearings, etc.)
The most impressive part to me, was he sold his 2001 Super Duty to build this and make it his daily driver
1979 4" Rough Country Lift. 400. 35" Pro Comp Mud Terrains
natesms is offline   Reply With Quote
Old 03-09-2011, 08:53 PM   #2
InfoFord
InfoFord's Avatar
Bronco Info: Picador 4 door bronco EFI 460 E4OD electric shift 1356 Tcase 3.55 10.25 rear, 3.54 Dana 44 front
good looking truck I am partial to duallys
is he going to put the correct dually hubs on that front axle to have the correct rims?
Trent
NORTH COUNTRY SPECIALTIES
Picador (1979 4door Bronco)
79 Ford CrewCab 4X4(My Dually Project)
79 Ford Bronco and My Boat
InfoFord is offline   Reply With Quote
Old 03-09-2011, 09:21 PM   #3
adrianspeeder
USAF C-17 Avionics
adrianspeeder's Avatar
Bronco Info: '94, '92, '88, and '84 Broncos
Nice! I love homemade dually's myself....
I also prefer the look of the SRW front end. Haven't found it to be too big of a deal to carry two spares.
Adrianspeeder
adrianspeeder is offline   Reply With Quote
Old 03-09-2011, 09:39 PM   #4
willys
Bronco Info: 1979bronco xlt ranger
very cool indeed.excellent job.
willys is offline   Reply With Quote
Old 03-09-2011, 10:09 PM   #5
natesms
Bronco Info: 1979
He's stickin to that look.
Old 03-10-2011, 01:46 AM   #6
colobronco
colobronco's Avatar
Bronco Info: 79 Ranger XLT 400CID C6 2" Lift on 33's
The best color combo - well after Jade/white.
if you still can't figure it out put it back together and take it to a mechanic
"Under my plan electricity prices would necessarily skyrocket" BHO
Truck was stolen & sold for parts Wheat Ridge Colo Black with Red 2 tone. About $20K in the truck. VIN U15HLEC0170
colobronco is offline   Reply With Quote
Old 03-10-2011, 06:21 AM   #7
Bigblew79
Bigblew79's Avatar
Bronco Info: 69,72,74,79 & 93
Great looking truck and like the color combo as well.
You should own something older than you!!! and cougars don't count!!!
Bigblew79 is offline   Reply With Quote
Old 03-10-2011, 09:21 AM   #8
4wheelcustoms
FSB Vendor
truck
Nice work fellas...
Chris Darnell
4 Wheel Customs, Inc.
www.4wheelcustoms.com
4wheelcustoms is offline   Reply With Quote
Old 03-10-2011, 09:37 AM   #9
Ranger429
Moderator
Bronco Info: 79 Bronco, 47 Binder
Looks like it already has brand new rubber and rims up front Trent.
Personally I prefer this look over the dually rim for the front.
Can't wait to see this finished. I also spot what looks to be a factory CB antenna, nice.
Originally Posted by 351w500 View Post
My sister in law is 3 months pregnant and next week I'm gonna shove a loaded .357 up her coochie just to familiarize the kid with weapons !
Ranger429 is offline   Reply With Quote
Old 03-10-2011, 09:41 AM   #10
SourMashII
SourMashII's Avatar
Bronco Info: 2004 LR DiscoII It's pronounced "Fjord"......
Beautiful.. I agree with Trent, it needs dually rims up front.. but aside from that, very nice.
All purpose rig under construction.. stay tuned!
SourMashII is offline   Reply With Quote
Old 03-10-2011, 11:16 AM   #11
Smok3y
FSB's Dirty Jersian
Smok3y's Avatar
Bronco Info: 89 EB, 91 Silver Anniv, 91 F250, 79 F250
I was going to say there is a guy around here with a great dually conversion build but its this guy ^^^ lol.
Please keep us updated. I'm always interested in new/different projects. Not too often you see a dually 79 rolling around.
89 Eddie Bauer - 6" RC Lift, 35" KO's, 302/c6 swap, Ford 9"
79 F250 Ranger Lariat - 9" Lift, 40" Ground Hawgs, 400/435/205, D60/D70 LOCKED
Originally Posted by SigEpBlue
All I want people to do is STOP, THINK, and SEARCH. Only post if those three fail after thoroughly repeating.
Smok3y is offline   Reply With Quote
Old 03-10-2011, 01:01 PM   #12
78-79FordMan
Ford Hoarder
78-79FordMan's Avatar
Bronco Info: 7 of them 1978-79's and 1 of the 1991's and 1 of them 1986's
i guess its going to have a flat bed . because a a dually fendered bed will not work with that rear. with out spacers.
and the only thing i don't like about not running dually wheels on the front . its hard to find a wheel that matches the rear dually ones. so lets seee a side shot or of the wheels. looks good . i am fixen to start on mine . but it will stay a 400 ford and have coil spring front and a dually bed with fenders. that i have.
Ford It Man
78-79FordMan is offline   Reply With Quote
Old 03-10-2011, 01:37 PM   #13
'95 Bronco
Bronco Info: 1995 Ford Bronco 351W all stock 195+k miles
Im just subscribing to see how this looks when it is finished. That truck is beautiful! I want one like it ha
'95 Bronco is offline   Reply With Quote
Old 03-10-2011, 04:25 PM   #14
natesms
Bronco Info: 1979
Originally Posted by Ranger429 View Post
: I also spot what looks to be a factory CB antenna, nice.
He didn't even know that's what he had! I emailed him a link to a thread Ranger and a few others had going. I already convinced him to put the 2 knob style after market stereo in there so he didn't have to chop up the dash (I chopped mine because tunes are a requirement, but REALLY wish I would have spent the coin for the knob style ones). I'm determined to get the factory CB in there if possible.
Yes, a flatbed is going on it. It would be sweet to get a dually bed on there, but this truck is going to be used on the farm and the flatbed will work a lot better for what it needs to do.
I'll keep updating pics.
Old 03-10-2011, 04:35 PM   #15
Ranger429
Moderator
Good luck finding an antenna Nate.
What is the coating he used on the hinges?
Old 03-10-2011, 04:43 PM   #16
Smok3y
FSB's Dirty Jersian
Smok3y's Avatar
What bed would you be talking about fitting? there were no dually's with beds made in 78-79, so you'd either have to make one custom anyway, or retro fit a newer bed...
The only dually's made back then were "DRW Chassis" and did not include a bed with the cab.
Old 03-10-2011, 04:51 PM   #17
natesms
Bronco Info: 1979
Brand new hinges from LMC. He said $60.00 a piece.
We are really lucky to be a 25 minute drive from the LMC warehouse...
Old 03-10-2011, 06:02 PM   #18
Mikes79Bronco
yes
Mikes79Bronco's Avatar
Bronco Info: 79, 460, 6.5" lift, 38" TSL Super Swampers < Thats the old...check my sig for progress thread
Looking good. When will the flat bed be on it?
1979 Bronco - In progress
Build Thread
Eating chevys and shitting hemis
Mikes79Bronco is offline   Reply With Quote
Old 03-10-2011, 06:40 PM   #19
InfoFord
InfoFord's Avatar
don't mean nothing that he has new rubber on those rims for all we know he has more then one set of wheels and was using a couple until he finished that front axle
to me that look with the singles on the front gives it a incomplete look or half converted and lost interest and don't care anymore look but that is just me plus I prefer carrying only one spare 100 pounds of uneeded weight carrying two
Trent
Old 03-10-2011, 07:57 PM   #20
78-79FordMan
Ford Hoarder
ya i know but they made dually kits for them back then . that was fenders and special wheels which i have . because in 1978 my dad bought a new 1978 f350 2 wheel drive and had them put the kit on it before it ever left the dealer ship. had to have special wheels to widen it. but i am only going to use the dually fenders. because i am using a wide dually rear end from a newer truck. and going to use the cab and front clip from the '78 f350 2 wheel drive. but shes going to become a 4x4. what he should have bought back then.
but this thread makes me want to pretty up my '77 dually flat bed . but its hard for me to because then it mite get a scratch. and ya i still have never got around to dually wheel'en the front yet.
Ford It Man
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
