Connecting rod installation - FSB Forums
Thread Tools Display Modes
Old 03-26-2011, 09:09 AM   #1
gocx
gocx's Avatar
Bronco Info: 94 Bronco XLT, 408w, E40D, Warn Hubs, 2 1/2 dual exhaust, 4 inch lift
Hello, i was about to install my pistons and connecting rods on my 351w stroker and i noticed that there are no marking on the rods except for the bearing notches. I was just wondering which way the notches should face. i couldnt find any information and the shop is closed today that i ordered the kit from. Any information will be appreciated. Thanks
gocx is offline   Reply With Quote
Old 03-26-2011, 09:52 AM   #2
B-ronco 79
B-ronco 79's Avatar
Bronco Info: '89 Eddie Bauer Ford Bronco 4X4
Most engine manufacturers and aftermarket guys will mark the outside of the rod. But if they didnt the simple rule of thumb is to put the bearing notches facing one another. Both the cap and rod should have only one notch to them and they are mated pairs. Keep each cap and rod together and line them up when putting them on and youll be fine. I always number them before taking them apart so as not to lose track. Be sure to use a paint marker or something so as to be sure not to deform the rod or cap like many have done with number stamp punches.
1989 "Eddie Bronco" 4X4 Mostly Stock
"Just be patient, I'm a work in progress"
B-ronco 79 is offline   Reply With Quote
Old 03-26-2011, 10:18 AM   #3
gocx
gocx's Avatar
Upon closer inspection of the rods. i noticed faded markings (the ones that were not ground for balancing) on the side of the rod with the bearing notches. The caps are already bolted onto the rod in the correct position. So does the marked side of the rod face away from the block or towards the block, or does it not matter as long as all the rods are assembled correctly and the bearing notches are all facing the same direction? I just want to make sure I do everything the right way because this engine will be seeing 6500 rpms easy. Thank you for the detailed response
Old 03-26-2011, 10:37 AM   #4
Kenny's 94
Kenny's 94's Avatar
Bronco Info: 5.0,e40d,9" 4:11,locker AR-23's,BFG 33's,K&N, 5" lift,Bassani headers/Y pipe,BBK 56mm, sliders
Most pistons have an arrow or a notch on the face of the piston. The notch faces the front of the engine.
Kenny
Kenny's 94 is offline   Reply With Quote
Old 03-26-2011, 11:25 AM   #5
gocx
gocx's Avatar
figured it out, thanks. i just looked at the rods again and noticed a chamfered side that goes against the crankshaft. I have dish pistons so they can only go one way. thank you all again for your help.
Old 03-26-2011, 04:45 PM   #6
Richo
Richo's Avatar
Bronco Info: 1995 Bronco EB 16" Lift
Yep, the crank has a little fillet at the corner where the rod/bearing are chamfered to fit against each other. In the good old days with custom cranks and rods, you had to use a bearing scraper to get the correct clearance. Those were not good days doing crap like that.....
Richo is offline   Reply With Quote
You may not post replies
Forum Jump
