Seam Sealer Vs Bathroom Caulk/Silicon - FSB Forums
Thread Tools Display Modes
Old 04-13-2011, 12:42 PM   #1
Habitual
Bronco Info: 1996 XLT w/ 351 & E4OD
As I do my rebuild I know I will need to seal up the seams int he sheet metal I am replacing. After doing some research I can't seem to find a good compairative of these.
So...
3M Seam Sealer ~20.00 online
3M Automotive (MMM8361) 3M Ultrapro Urethane Seam Sealer, Gray, 310 mL Foil Pack
Product Description
High solids seam sealer ideal for sealing interior and exterior automotive and RV seams and joints
Adheres well to primed metal and paintable surfaces
Can be smoothed to a featheredge and/or brushed
Tack free and paintable in 30 minutes
Will not shrink or crack, and can be baked at higher temperatures than ordinary seam sealers
Flexible, damage resistant foil package allows virtually 100% usage. More economical than conventional cartridges. Specifically designed applicator gun, part number 08398, provides professional results. Duplicates OEM sealer appearance.
or
Silicone Caulk ~7.00
Dap 08640 Bathroom Silicone Rubber Caulk 10.1-Ounce White
Technical Details
All purpose bathroom caulk
Seals nonporous surfaces around ceramic tile and plumbing fixtures with 100-Percent silicone rubber
Meets requirements of FDA regulation number 21 CFR 177 2600
White
10.3 fl-Ounce
Product Description
From the Manufacturer
Superior quality, multi-purpose sealant. Offers long-lasting flexibility and excellent adhesion. Provide a weatherproof, watertight seal. Resists cracking, crumbling and chalking. Interior/exterior use. 50 Year Durability Guarantee. Meets Federal Specification TT-S-001543A, Class A.
100% silicone rubber with mildicide. Excellent for sealing around ceramic tiles and plumbing fixtures. Won't crack, crumble, or dry out. White. No. 00680: 3 oz. squeeze tube No. 08640: 10 oz. cartridge
Has anyone had any issues with using the caulk? Has anyone used both and do they have pros/cons vs one another?
"One original thought is worth a thousand mindless quotings." - Diogenes of Sinope
I'd lock this thread, but it's just too much fun to keep reading.
"I became insane, with long intervals of horrible sanity.." - Edgar Allen Poe
Habitual is offline   Reply With Quote
Old 04-13-2011, 01:21 PM   #2
miesk5
miesk5's Avatar
Roof/Drip Rail Seam Sealing Directions; 3M™ Ultrapro™ Autobody Sealant; as cited in TSB 95-09-05
Source: by 3m.com
Wait to dry before applying paint over the sealer. Thicker beads of seam sealer will take longer to
cure before painting. The stated dry time before painting is based on a 1/4" bead at 70 deg F
Body Repair Adhesives Guide
Source: by Ford Motorcraft® fcsdchemicalsandlubricants.com
Seam Sealer
Fast-curing
Permanently flexible
Excellent bond strength
Paintable in 10 minutes
Will not shrink, crack or peel
Bonds to all primed or painted metals, and most automotive plastics
Heavy bodied, non-sag formula
Immediately bakeable
Typical applications include: Duplicating factory look on: standing cosmetic seams, truck bed seams, tooled door skin seams, floor pans, core supports. Anywhere a non-sag, cosmetic seam sealer is required.
Available in 10.3 fl. oz. (305 ml) aluminum caulk tubes
Part Number TA-2
Specification Number N/A
Size 10.3 fluid oz.
FIR No. 181251
Unit Pack 1
Ford Body Repair Adhesives Guide
& Ford's Entire Body Repair Products;
Anti-Corrosion Coating
Isopropanol Cleaning Kit
Manual Dual Cartridge Applicator Gun
Metal Bonding Adhesive
Metal Surface Prep
Plastic Bonding Adhesive
Pneumatic Dual Cartridge Applicator Gun
Premium Undercoating
Rust Inhibitor
Seam Sealer
DAP® Kitchen and Bath 100% Silicone Sealant Technical Bulletin by DAPNot paintable. Paint surfaces before sealing.
USN & DoD Planner (ret)
THANKS to ALL WHO SERVE!
Old 04-13-2011, 01:21 PM   #3
miesk5
miesk5's Avatar
Source: by 3m.com
Seam Sealer
Fast-curing
Part Number TA-2
Size 10.3 fluid oz.
FIR No. 181251
Unit Pack 1
Metal Surface Prep
Rust Inhibitor
Seam Sealer
Old 04-13-2011, 01:27 PM   #4
Mikey350
Bronco Info: '96 Black 302 XLT - '94 Green 351 E. B. both are E4OD, 3.55 axles, 31 10.50x15
You might look at a caulk that is paintable, usually the bathroom caulk is not paintable. DAP makes a variety of external use caulk, like for windows, that supposedly adheres to metal (like aluminum window frames?), and has a 20yr life (again supposedly). Just my 2 cents, good luck.
(Damn, meisk5 beat me by 5 minutes)
Mikey350 is offline   Reply With Quote
Old 04-13-2011, 03:45 PM   #5
Bigun
Bronco Info: 1980 Bronco 6.6L 400 Auto C6 NP208 Transfercase 32x11.50 Mud claws
meisk5 is the man.
Bigun is offline   Reply With Quote
Old 04-13-2011, 03:48 PM   #6
slinker
slinker's Avatar
Bronco Info: 1989 xlt 1994 xlt
Indeed miesk5 seems to be a veritable cornucopia of information
slinker is offline   Reply With Quote
Old 04-13-2011, 04:10 PM   #7
Gacknar
The Anti Yam!
Gacknar's Avatar
Bronco Info: 86 Bronco XLT 357w/AOD
Seam sealer is made to fill seams and to some extent bond metal parts together, (but is not a replacement to body adhesive in that respect) on a vehicles that are constantly moving, and contracting and expanding due to flex and temperature change.
Bathroom Calk is made to stop water from going between two objects that never move, flex, or see extreme changes in temperature, it has almost no adhesion ability and a very low shear strength.
Which one do you think would work better?
86 Bronco - 357W/AOD - 6" suspension lift, 3" body lift - 38" TSL Radials - 456:1 Gears
Sequential Multiport Mass-Air Fuel Injection from a 93 Mustang GT
My SuperMotors Site - My Engine
The Greatest Thread on FSB
Gacknar is offline   Reply With Quote
Old 04-13-2011, 04:31 PM   #8
Habitual
Product Description
As you can see the above particular product information was why I asked. They seem very similar. Looking over what people have posted I think I am going to go with the seam sealer.
You may not post replies
Forum Jump
