How to take apart a leaf spring - FSB Forums
Thread Tools Display Modes
Old 04-13-2011, 02:21 PM   #1
Bron-go
Bronco Info: 95 Bronco EB
I have to replace the the bottom leaf on the right rear of my Bronco, my question is - How do they come apart, is there a center bolt that holds the 4 leafs together, if so should I replace the center bolt after I take it apart or can I reuse it. I know I have to replace the 2 "U" bolts. Any other advice on how to go about this would be great. Thanks for any help you can give me.
Bron-go is offline   Reply With Quote
Old 04-13-2011, 05:46 PM   #2
broncobeast66
Bronco Info: 1992 XLT 5.0 Auto
I have always used a couple c clamps to hold the springs together when you remove the tie bolt. I would go ahead and get new bolts also, there cheap.
broncobeast66 is offline   Reply With Quote
Old 04-13-2011, 08:49 PM   #3
Bron-go
Thanks, I will use 2 clamps when I take the center bolt out. Thanks for the info.
Old 04-13-2011, 09:03 PM   #4
f1fiddy
f1fiddy's Avatar
Bronco Info: 89 Bronco EB 5.0L AOD, 35" Mud Country's, 4'' Rancho,Ford 9" w/Aussie locker and 4.11 gears
Since your replacing them, you can just cut them with a grinder and the same goes for the ubolts.This saves time and energy.
Custom front and rear bumpers
12K Tabor winch
Custom T-case skid plate
2 Pro Comp 130watt Lights
Custom Air Box with Dual K&N
f1fiddy is offline   Reply With Quote
Old 04-14-2011, 07:26 AM   #5
Bron-go
Thanks , I will do that .It should save alot of time doing it that way.
You may not post replies
Forum Jump
