Vista Pro Radiators any good? - FSB Forums
Thread Tools Display Modes
Old 05-16-2011, 08:07 PM   #1
koren04
koren04's Avatar
Bronco Info: 89 XLT 351W. 6" lift, 2" body,JBA Shorties, ARB lockers front and back, full cage, C6
I need to replace my rusted out radiator. I found Vista Pro radiators on Summit and Rock Auto. Does anyone have any feedback on the quality of these radiators? I am moving from California to Arizona and am on a tight budget. Are these radiators worth the money? I was looking at the HD/Max cooling setup.
http://www.summitracing.com/parts/PLI-432183/
Loosers make excuses, Champions make adjustments.
koren04 is offline   Reply With Quote
Old 05-16-2011, 11:18 PM   #2
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
Betcha it's a good one. :)
Everything I've gotten from Rockauto and Summit have been good quality.
They have to pay shipping back to -themselves- if it's junk or don't fit! LOL :)
Alvin guessing his ass off in AZ
Alvin in AZ is offline   Reply With Quote
Old 05-17-2011, 02:47 AM   #3
YaKnow
Bronco Info: 1996 5.8L Eddie Bauer, 4" Rancho with 33's
I have been looking at the same brand at Summit. I need to get one soon. I don't know anything about them however if I can offer any input/advice, I would get the four row for less than $100 more than the 2 row. If you are going to be in AZ much and plan on keeping the Bronco a while, I would definitely recommend a 4 row.
Again, I understand a budget and all but money well spent IMO.
YaKnow is offline   Reply With Quote
Old 05-17-2011, 02:48 AM   #4
YaKnow
Not meaning to get off topic, but where in AZ are you moving to?
Old 05-17-2011, 02:51 AM   #5
koren04
koren04's Avatar
Scottsdale. It aught to be a hella of a change! Im a Nor Cal guy born and raised. I hope the Phonenix area has an OHV area that can rival Hollister Hills or Carnegie (as long as i can get my BKO wokring right)!
Old 05-17-2011, 03:14 AM   #6
Alvin in AZ
AKA: Butthead
x2 :)
The Phoenix area is like the worst in the country to tax your cooling system.
Got A/C too?
Butthead in higher, cooler and with less traffic SE AZ
Old 05-17-2011, 11:57 AM   #7
YaKnow
There are quite a few OHV's but I have no idea how they compare to the ones in CA. I am in the southeast valley so if you need any help, info, etc. let me know and I will try to help/answer.
Old 05-17-2011, 02:03 PM   #8
JKossarides
JKossarides's Avatar
Bronco Info: 1986 Bronco XLT 4x4 -AOD -Warn Hubs, NEW stock 302EFI, MSD cap, rotor, 48kv coil, 9mm FMSR wires
I just put in a new radiator myself very recently using a link from an FSB member, www.radiatorbarn.com - 2 row, aluminum center core with plastic tanks for $117.92 no tax, no shipping charge probably delivered in 3-5 days etc.....
Now I did manage to negotiate price with an O'Reillys store manager locally by bringing in the printed price sheet and got the exact same price luckily, usually it's just store to store not internet but their price would have cost me $160.22 out the door but either way you can't loose....I saved $42.30...
Try using Redline "water wetter" to help reduce internal corrosion and lower ambient and cylinder temp....costs $10.00
Good Luck ~
Old 05-17-2011, 06:04 PM   #9
YaKnow
Does anyone have or know of any experiences with the AutoZone Spectre brand? The four row is about $150 and has a lifetime warranty?
Old 05-17-2011, 08:56 PM   #10
alaskan155
alaskan155's Avatar
Bronco Info: 1988 BRONCO 5.0/AOD axle code H5
i got the spectra on my 88, it had 2 outputs for the overflow tank, but i fixed that with a plastic T and extra hose and its working 100%, same with the spectra fuel tank i got, both on rock auto.definitely buy them again.
88 Bronco
worn out 5.0/AOD/BW1356man., 4.10 gears with 8.8 l/s
211k miles/ 15mpg
35s stock/ no sway bars
alaskan155 is offline   Reply With Quote
Old 05-18-2011, 05:39 PM   #11
koren04
koren04's Avatar
Did you have to replace and of the brackets or bolts associated with the radiator? The entire lower portion of my radiator is rusted all to hell, including the lower support. I'm worried that stuff is gonna start snaping when i touch it with a wrench!
Old 05-18-2011, 07:39 PM   #12
Alvin in AZ
AKA: Butthead
start snapping when i touch it with a wrench!
Holy crapola dude. :/
You got sea air there in San Jose or is your Bronco from the rust belt?
That thing ain't gonna be worth squat in the Phoenix area, sorry to say. :/
Put a wreckin' yard radiator in it if you insist on driving it to Phoenix. ;)
IMO, don't spend anymore money on it than you absolutely got to.
This is what a '91 Arizona Bronco looks like underneath...
...get yourself one just like it after you get here? LOL :)
Butthead in AZ
Old 05-19-2011, 02:02 AM   #13
koren04
koren04's Avatar
I got it from a guy that lived on the coast and didnt take care of it. Wait till you see the pics. Ugh.
Old 05-19-2011, 04:12 AM   #14
alaskan155
alaskan155's Avatar
mine came with a new hardware pack only used the 4 original bolts
2 for the fan shroud and 2 for the radiator, the radiator came with all new clips, wish i would have noticed the bag at the bottom of the box before i installed it using the old clips though
88 Bronco
211k miles/ 15mpg
Old 05-19-2011, 02:08 PM   #15
Black Shark
Black Shark's Avatar
Bronco Info: 1996 Eddie Bauer
That one is the exact same look an demisions as mine although I don't know if it's the same brand. I installed a mechanical water temp guage on mine and it runs 195-205 always. Even with A/C on all day driving in 100 degree texas heat with 100% humidity still always stays in that temp range. I don't even think I've seen it hit 206.
2 core 3 core 4 core doesn't matter what does matter is the overall thickness of your radiator. The thicker it is, better it cools period.
1996 EB 6in lift - 1994 cobra 505rwhp 651rwtq - 2006 c230 - 2003 R1 - 1999 Taurus black for sale pm me
Black Shark is offline   Reply With Quote
You may not post replies
Forum Jump
