Power Steering Gear Box - FSB Forums
Thread Tools Display Modes
Old 05-23-2011, 11:40 PM   #1
ProComper93Bronco
ProComper93Bronco's Avatar
Bronco Info: 93 Bronco, 4 inch lift, 33x12.50r15 tire, MSD ignition, K&N Cold Air Intake, Flowmaster Exhaust
Today i woke up started my 93 FSB 351w and she was meowing at me thirsty for some power steering fluid i looked at my hoses nothing was coming out and when i looked at my gear box i noticed there was a noticeable leak coming from my gear box seal where it connects to my drop pitman arm my first question is how many seals are in my gear box and should i just replace that bottom seal or replace all of them?
ProComper93Bronco is offline   Reply With Quote
Old 05-24-2011, 12:03 AM   #2
landshark99
Too many broncos!
landshark99's Avatar
Bronco Info: 1969 and 1976 Broncos
You can pick up a power steering box rebuild kit for about $60 and rebuild it yourself and it will be as good as new.. otherwise its probably not worth tearing apart for one seal... if you can even get just one seal...
other option just go pick one up at he junk yard from a F150 or Bronco...
landshark99 is offline   Reply With Quote
Old 05-24-2011, 12:16 AM   #3
ProComper93Bronco
they have just the one seal for sale but i would rather not have to do that since its my daily driver
Old 05-24-2011, 01:22 AM   #4
TheUnforgiven
Huh Huh vanzercool
TheUnforgiven's Avatar
Bronco Info: 2005 Chevrolet Venture, 1997 Acura TL
get a Redhead gearbox and be done with it.
2005 Chevy Venture. 1997 Acura TL. $500 beater.
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 05-24-2011, 07:51 AM   #5
Ewgoetz
Ewgoetz's Avatar
Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs, 200,010Miles
+1
Ewgoetz is offline   Reply With Quote
Old 05-27-2011, 12:20 AM   #6
Daves 88'
Daves 88''s Avatar
Bronco Info: 1988 Bronco XLT,302, Tow package w/ limited slip, cat back exhaust, on 31's
I got quoted $150.00 to replace the top seal in my gearbox at a steering shop.
And he saw that the horse was good: Former Fire Bronco
Originally Posted by wcm413 View Post
I can see the nuts now , the rod was in the way before . Thanks ,Bill
Daves 88' is offline   Reply With Quote
Old 05-27-2011, 02:05 PM   #7
bigblue87bronco
bigblue87bronco's Avatar
Bronco Info: 1994 F-150 extended cab short bed, 4" lift, 35" BFG mud terrains
I've done both. Re-building the box takes some time. Plus you have to put the gears back in just right because they wear in a certain way. 99% of the time you are driving straight so your gears wear in that pattern...if you don't align them just right it will cause your truck to pull one way or the other. Just the other day I replaced my steering box in my F-150. Got a used one for $25. Just to help you in your search for a used box the same box came in 80-96 Broncos and F-150s, F-250, F-350, F-450, some Rangers, Bronco IIs, Explorers, Ford Vans, Mazda 2300, 3400, 4000, and Navajos. It was slim pickings at my local salvage yard and I had a choice between a 91 Explorer box and a 94 Ranger. The Ranger box felt tighter and I figured that since it was out of a 2wd 94 Ranger standard cab and the truck appeared to be completely stock, it probably didn't live a very hard life.
Originally Posted by MajSuckelton View Post
No. It's your Box, rag, or tie rods. That or your box is on the rag in which case you don't want to stick your rod in it.
bigblue87bronco is offline   Reply With Quote
Old 05-27-2011, 04:11 PM   #8
dezracer
Bronco Info: 90 Bronco, 351,E4OD,4:11,Locked F&R,35s,Fiberglass hood&fenders,6"susp3"body
In my opinion send the box and pump to Lee Mfg. in Sun Valley to have them do it right. 1-818-768-0371. They are the best, just had my box and pump done 375
dezracer is offline   Reply With Quote
Old 05-27-2011, 05:30 PM   #9
CWbronco
CWbronco's Avatar
Bronco Info: 95 xlt, 302, 37's, 4.56's, D44 SAS, 10.25 FF
you paid that much? i paid round $250 and change for my redhead. great box, works perfect. most members will say the same.
EDIT: i see you said pump also, that makes more sense.
Build
SAS
FOTM Oct. 2012
CWbronco is offline   Reply With Quote
Old 05-27-2011, 10:02 PM   #10
lifeizhard102205
lifeizhard102205's Avatar
Bronco Info: 1993 EB 351W, SAS'd 44, 37" Hummvee tires, 10.25 rear, smittybilt 12k winch homemade mount
wow, a new stock one from auto zone is $145 and a redhead is like $250-$270. why pay over $100-$230 more for a rebuild?
lifeizhard102205 is offline   Reply With Quote
Old 05-28-2011, 04:08 AM   #11
cajunrebel
Chillin on the Gulf Coast
cajunrebel's Avatar
Bronco Info: Blue 89' EB 5.0, E4OD, OBDII, Mass Air, Saginaw, Hydroboost, 3G alt
Because a Autozone power steering box is most likely just a resealed worn box that will be really sloppy very quickly. Look on Redhead's website and talk with them if you are not convinced. They take rebuilding boxes to a whole other level from other companies. When I replace my box I will be getting mine from them.
cajunrebel is offline   Reply With Quote
Old 05-28-2011, 04:44 AM   #12
Bennelton
Bennelton's Avatar
Bronco Info: 86 Bronco 351/5.8L 385hp Ford Racing Crate Motor, 32" BFG AT's, soft top and some other stuff.
redhead x infinaty squared
1986 Bronco Eddie Bauer 5.8L
https://www.supermotors.net/19921
Bennelton is offline   Reply With Quote
Old 05-28-2011, 11:37 AM   #13
Seattle FSB
Seattle FSB's Avatar
Bronco Info: 1990 EB FSB, MAF, 6.7L, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
A while back, I looked very closely on how to rebuild my steering box. After much research, I came to the conclusion that the complexity of the rebuild required me to be self-limiting. Hence forth, I have a newer Red Head, which was a relatively easy install.
Cheers to those who can do a quality steering box rebuild...
1990 Bronco, MAF, 408 Stroker, Level 10 E4OD, Currie F9+, Electric Boost Brakes, lots more...
Seattle FSB is offline   Reply With Quote
Old 05-28-2011, 11:50 AM   #14
cmotsvt
Ive had good luck with the parts store reman ones.
Most have a warranty I think, no more trouble than it is to replace one I wouldnt care having to redo it 2-3y. later.
cmotsvt is offline   Reply With Quote
Old 06-02-2011, 01:05 PM   #15
cjwchoppers
cjwchoppers's Avatar
Bronco Info: 1994 5.8 e40d 6in lft 35's m/t whls Custom bumbers.banks 3in stnls exh.edelbrock int.bassani headers
Just ordered my RedHead steering box about an hour ago.
One thing I learned on this forum is that most everything has been tried and tested and it is easier to learn from the experiences people have had here than to fight it and go through it and trying the wrong way myself.
cjwchoppers is offline   Reply With Quote
Old 06-02-2011, 02:20 PM   #16
catsnw
A broke kid with a bronco
catsnw's Avatar
Bronco Info: 1995 EB bronco 5.8, auto, true duals, k&n intake, 3G alternator, 12 front lights (more to come!)
Don't you have to call them to order or can you do it online?
Originally Posted by 88LiftdBronco View Post
So what you're saying is, that when you see a penis you think of another guy?
٩(●̮̮)۶
catsnw is offline   Reply With Quote
Old 06-02-2011, 03:02 PM   #17
cjwchoppers
you have to call.
I called them put me on hold got prices they took my info and the whole order took less than 5 minutes
Old 06-02-2011, 07:50 PM   #18
Robdamedic
Any contact info for Redhead?? Thanks much
Robdamedic is offline   Reply With Quote
Old 06-02-2011, 08:22 PM   #19
jobei
Bronco Info: 87 Eddie 302 EFI AOD on 33"s
Wink
Redheadsteeringgears.com
Or just google redhead steering. Worked for me.
jobei is offline   Reply With Quote
Old 06-08-2011, 01:01 AM   #20
ProComper93Bronco
are you serious its just on seal its the drop pitman arm seal and you telling me instead of just replacing it i gotta buy a new one
You may not post replies
Forum Jump
