Keep blowing my turn signal fuse - FSB Forums
Thread Tools Display Modes
Old 06-09-2011, 01:56 PM   #1
AbandonedBronco
Big Six
AbandonedBronco's Avatar
Bronco Info: 1981 300ci 6cyl w/4bbl conversion. 4spd manual
Hi all,
I'm suddenly running into a frustrating issue. I'm not sure what's causing it, but the fuse for my turn signals (not the flasher) keeps blowing.
I'm not sure what's causing it, and they'll work for a while, but then suddenly....no turn signals. I'll pull the fuse to look and it's blown.
Any ideas? I've had this truck for nearly 7 years and have never had any electrical issues, so I'm not too well versed in tracking them down.
So far, though, I can't find any one thing that causes it. Tried turning on and off various different systems, like the door lights, windshield wipers, starting it, turning it off, etc. Ie. systems that randomly change. Nothing seems to do anything.
Then, I'll just suddenly notice while driving....they've stopped working again and the fuse is blown.
Thoughts?
1981 & 1984. Both w/ 300 I6. Holley 465 / 600 4bbls. 31x10.5" tires. NP-435 trans. 2.5" Exhaust.
Supermotors Pics
AbandonedBronco is offline   Reply With Quote
Old 06-09-2011, 01:59 PM   #2
socal82bronco
socal82bronco's Avatar
Bronco Info: 82 351w
i had the same problem with my 82, mine was trailer wiring was all jacked. had all kinds of expose wires cleaned them up and works fine
socal82bronco is offline   Reply With Quote
Old 06-09-2011, 02:02 PM   #3
AbandonedBronco
Big Six
Thanks, I'll be sure to check those. Maybe a wire wore through.
Supermotors Pics
Old 06-09-2011, 02:05 PM   #4
86fn150
86fn150's Avatar
on my 86 the turn fuse kept blowing but it was the hazard switch that caused the problem.small plastic cover on side of switch kept shorting out against wheel
86fn150 is offline   Reply With Quote
Old 06-09-2011, 08:14 PM   #5
AbandonedBronco
Big Six
I checked my trailer wiring (it's only about a year old) and it was tip top. Not sure what to check on my hazard switch, but on that point, the hazard lights still work. Just not the individual L/R.
Thoughts?
Supermotors Pics
Old 06-09-2011, 09:03 PM   #6
socal82bronco
Take the lights offf and check your connections see if there anything exposed. does it happen as soon as you turn your signal on?
Old 06-09-2011, 09:24 PM   #7
Redwagon
rolling Rolling ROLLING....
Bronco Info: 93 Cherokee
have you replaced any bulbs lately? I have seen where guys use the wrong ones and create shorts.
Tim
Newest token Jeep owner....
Redwagon is offline   Reply With Quote
Old 06-10-2011, 01:56 AM   #8
Jasonhughes2009
I scrape on both sides
Jasonhughes2009's Avatar
Bronco Info: another rig that runs on crapoline
disconnect your trailer wiring all together just to double check that, id put my money on the multifunction switch though, i had the same kind of problem
1991, fresh 5.0, OBA, 6 inch lift, 9 inch rear, 5.13s. detroit rear aussie front, 37" pitbull rockers, beadlocks. e4od
Originally Posted by tonyroc14 View Post
If only I could have 6 of his 32 inches!
Jasonhughes2009 is offline   Reply With Quote
Old 06-10-2011, 10:53 AM   #9
AbandonedBronco
Big Six
The only thing I've done in the last few weeks was pulled the instrument cluster out to look at some information printed on the back of it. It just has the one big plug (which I've since double checked to be sure it was in securely). Other than that, this issue has come out of the blue. No working on wiring, changing bulbs, etc.
I also can't pinpoint when it happens. The signals will work for a day or so, and then I'll just notice that they're not coming on. Fuse blown. There isn't anything I've found that I can do that results in immediate fuse blowing.
The trailer wiring is a simple four prong plug, and the connections are all good.
Which switch are you referring to?
Supermotors Pics
Old 06-10-2011, 11:32 AM   #10
Jasonhughes2009
Under the drivers side dash. Looks like a sort of 1/3 of a circle... If you can't find it I'll get a picture later
Old 06-10-2011, 04:50 PM   #11
ad5mb
I had the same problem. replaced the fuse with a 20 amp 120VAC circuit breaker. works fine, lasts a long time, has very few moving parts.
ad5mb is offline   Reply With Quote
Old 06-10-2011, 04:57 PM   #12
AbandonedBronco
Big Six
I'm not sure what switch you're talking about. What switch is it? (Not necessarily what it looks like.)
Hope it doesn't come to that. I'd rather track down what's causing it first.
Supermotors Pics
Old 06-10-2011, 08:11 PM   #13
Mikey350
Bronco Info: '96 Black 302 XLT - '94 Green 351 E. B. both have E4OD, 3.55 axles, 31 10.50x15
The multifunction switch referred to in post #8 is the combination turn signal/windshield wiper, etc. switch.
Mikey350 is online now   Reply With Quote
Old 06-10-2011, 08:22 PM   #14
AbandonedBronco
Big Six
The 80-86 is a bit different and those are all independent of each other.
There's two pull knobs on the dash. One's the headlights and dome light. The other is the windshield wipers.
The highbeam switch is on the floor.
And the turn signal switch/lever is on the column.
I *think* they're all independent systems and have different fuses.
Supermotors Pics
Old 06-17-2011, 10:21 AM   #15
AbandonedBronco
Big Six
Hi everyone.
Any more ideas? Are there any systematic ways I can go about tracking this down? Could anything have happened when I removed and reinstalled the instrument cluster? (I've confirmed it's fully plugged in, but still).
I'm not further to solving this and still have no turn signals.
Supermotors Pics
Old 06-17-2011, 12:32 PM   #16
miesk5
miesk5's Avatar
yo AB,
Brake, Turn, Hazard Lights Inoperative, Similar to 80-91 Bronco & F-Series;"...have a friend stand behind your truck and when you are pressing the brake pedal move the turn signal arm ever so slightly, if the brake like comes on, your switch is shorted out and must be replaced..."
Source: by Ford via miesk5 at Ford Bronco Zone Forums
Only other thing I can recommend now is to pull connectors and use a meter to rest for shorts on each conductor using the only diagram I have right now;
Turn, Tail, Brake, Head Light, Hazard & Ignition Wiring Diagram for 84 Bronco & F-Series (partial); "...Similar to 80-91 Bronco & F-Series..."
Source: by Steve83 (Steve, That dirty old truck) at http://www.supermotors.net/clubs/sup...media/714912_1
Turn Signal Switch Connector Location in Parts Break-Out Diagram in an 83; similar to 80-91
Source: by Seabronc (Rosie, Fred W) at http://broncozone.com/index.php?app=...attach_id=3014
USN & DoD Planner (ret)
THANKS to ALL WHO SERVE!
Old 06-28-2011, 02:20 PM   #17
SoCal09
Bronco Info: 1989 Boss 302
I actually had the same problem occur when I was messing with my alarm system one day. I have a 95 and I use emty fuse areas within my inner fuse panel to power my alarm. Anyway, I had grounded out a different fuse on accident and this caused my turn signals not to work, while my hazards still worked.
Are you saying your blowing the round fuse? Mine was never actually blown, so make sure you don't have a wire grounded somewhere.
I'm at work so I hope I wrote that clearly, just my .02
SoCal09 is offline   Reply With Quote
Old 06-28-2011, 07:07 PM   #18
Demonio Irelandes
Demonio Irelandes's Avatar
Bronco Info: 85 Bronco: 351W/C6/NP208 - D60/Corp14/41" IROKs
The wire runs from the dash area to the back of the truck, and if it's anything like mine was, it's inside the frame rail under the truck. It could have gotten snagged on something or the outer jacket could have been rubbed off because your trans mount is wasted and every time you punch it from a standing stop you move the wiring harness just a little bit.
Get an ohm meter/multi meter and and some 14 gauge wire and check resistance. If it's high then you've likely got an intermittent short somewhere and that's why it works for a while then blows.
Demonio Irelandes is offline   Reply With Quote
Old 06-29-2011, 08:54 AM   #19
AbandonedBronco
Big Six
It's actually the 15amp fuse in the fuse panel that keeps blowing.
However, someone at the parts store suggested that since the fuse for the turn signals keeps blowing but the hazards still work, that a 'quick and easy' check would be to swap the big round flasher fuses to see if a dying turn signal flasher keeps blowing the fuse.
I tried it and it's been about four days and my fuse hasn't blown again.
Hopefully it'll stay that way. If so, I'll just buy a new flasher.
The tabs on my transmission have broken off, so it's not even held down anymore. So yeah....it probably moves around.
If the above doesn't work, I'll check the wiring under the truck.
Supermotors Pics
Old 08-30-2011, 08:49 PM   #20
stonepaw913
car ramrod
stonepaw913's Avatar
Bronco Info: 88, 302, AOD, currently f***ed. Now driving a Chebby Astro
So, have you stopped blowing fuses? Mine has started doing this recently, and I was interested to see if that solved you problem.
Originally Posted by SigEpBlue View Post
Stupid people make life irritating, but only until Karma comes around to smack 'em upside the head.
Originally Posted by Spazmo View Post
fvck fuel get midgets
stonepaw913 is offline   Reply With Quote
You may not post replies
Forum Jump
