Do brake boosters normally make noise? - FSB Forums
Thread Tools Display Modes
Old 07-26-2011, 03:59 PM   #1
AbandonedBronco
Big Six
AbandonedBronco's Avatar
Bronco Info: 1981 300ci 6cyl w/4bbl conversion. 4spd manual
I've heard brake boosters hiss when they are going bad, but to what degree?
Do they normally make some type of noise when you press the brakes?
Or is any type of hissing at all a sign they're going out?
Thanks
1981 & 1984. Both w/ 300 I6. Holley 465 / 600 4bbls. 31x10.5" tires. NP-435 trans. 2.5" Exhaust.
Supermotors Pics
AbandonedBronco is offline   Reply With Quote
Old 07-27-2011, 01:28 AM   #2
TheUnforgiven
No longer Kia boy
TheUnforgiven's Avatar
Bronco Info: 2005 Chevrolet Venture
a quiet "whoosh" is normal. any more than that and it's probably on its way out.
2005 Chevy Venture, not a bronco. Deal with it.
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 07-27-2011, 11:33 AM   #3
AbandonedBronco
Big Six
Okay, thanks. I wasn't sure if any noise was bad, since I was hearing some. But, it's more like a quiet 'woosh'.
Supermotors Pics
Old 07-27-2011, 05:22 PM   #4
TheUnforgiven
No longer Kia boy
you shouldn't be able to hear it with the radio on or while driving when you step on the brake.
if it is "whooshing" all the time then it is shot.
if it just does a whoosh when you hit the brakes and the surroundings are very quiet then you're fine.
Old 07-27-2011, 05:56 PM   #5
Lucky
Bronco Info: '85 Bronco, 351W, Eddie Bauer edition.
The booster was already bad in my '85 when I bought it. I had to stand on the brakes to stop, but it hissed loudly as soon as you would touch the brake pedal and would continue to hiss until you let off of the pedal. You will know it's bad when you hear it.
'85 Ford Bronco, Eddie Bauer edition, 351W, 6" lift, sitting on 35x12.5's.
Lucky is offline   Reply With Quote
Old 07-28-2011, 01:19 PM   #6
AbandonedBronco
Big Six
Thanks for the replies. Mine makes a little noise, but it's very quiet. I just wanted to be sure it was normal since I'll be doing a brake job sometime soon.
Supermotors Pics
Old 07-29-2011, 01:02 AM   #7
moosey42
Bronco Info: 1994 xlt
Yeah, you'll know for sure when you hear it.
moosey42 is offline   Reply With Quote
Old 08-15-2011, 12:46 PM   #8
20sNaRanger
20sNaRanger's Avatar
Bronco Info: 1982 Ford Bronco XLT Inline 6 300, 38 swampers, 6in suspension 2in body, 4.56 gears
or when u can't stop
Betty WILL run....
20sNaRanger is offline   Reply With Quote
Old 08-15-2011, 11:21 PM   #9
pimtool
Bronco Info: 89, 5.8, c6, manual t case
So, will a bad booster make a hard pedal or soft pedal?
Cause i have a kinda loud whooosh and a soft brake pedal, but just got the vehicle and dont know the history. Thanks.
pimtool is offline   Reply With Quote
Old 08-16-2011, 12:37 PM   #10
oregon_c350
oregon_c350's Avatar
Bronco Info: 89 Bronco XLT 351 C6 ..--.. 1990 C350 Lariat 460
Depends on how "bad" the booster. If the diaphragm just has a small leak/hole/tear it will still provide boost, but the noise will be "air" or "vacuum" escaping. Once the thing is totally shot it will not provide any boost at all, just like when you move a car without the engine started and have not vacuum left and have to stomp on the brakes with much effort.
oregon_c350 is offline   Reply With Quote
Old 08-17-2011, 08:57 PM   #11
pimtool
must have been air, a quick bleeding and they are 10 times better.
Old 02-09-2012, 11:33 AM   #12
AbandonedBronco
Big Six
Back to this.
Turns out my brake booster was bad (noise got progressively worse and the braking power was fading quickly) so I replaced it.
However, now, whenever I let off the brake, there's a slight air hissing noise. (I really only hear it when the engine's off because it's pretty quiet). Kinda like the sound you get when you have a pin prick hole in an air mattress. You can hear it, but you can't exactly tell where it's coming from.
If I press on the brake, it goes away. If I pull on the brake pedal with my foot, it goes away.
I don't think this is normal, but is it something I should worry about? If so, I'll take it back and swap it out under warranty, but don't want to mess with the whole ordeal if it's no big deal.
Supermotors Pics
Old 02-09-2012, 02:16 PM   #13
txdxrider
ahhhh..... crap!!!
txdxrider's Avatar
Bronco Info: 91 Bronco XLT 5.8 E4OD 3.55
mine was hissing - but once I rebuilt the rear brakes and installed a braided brake line it went away....
Lead follow or get OUT of the way..
91 Bronco XLT 351W 3.55 -Other toys - my co demo, 2009 Z71 Burb, 2008 VRSCDXA, 2005 Jeep Wrangler Unlimted Rubicon - My Build Thread
txdxrider is offline   Reply With Quote
Old 02-09-2012, 02:20 PM   #14
AbandonedBronco
Big Six
How would that affect the brake booster?
Either way though, my brakes are relatively new. Rears are about a year old, fronts, maybe four or five.
Supermotors Pics
You may not post replies
Forum Jump
