#1 |
iTrader: (3) Bronco Info: 1988 XLT 5.0l w/AOD & Rebuilt BW1356
Codes 63, 98 and idle adjustment
Okay I'm looking for a little confirmation on my situation.
I have a '88 302 that has been throwing KOER codes of 63 and 98. I also had a stalling at idle issue. While looking into my stalling issue I found my idle set screw broken off leaving the butterflies fully closed at idle. Well I removed the broken set screw and replaced it with a new one. I then set the idle to 700 rpm's with the IAC unplugged. After researching I now realize I should have been setting the idle around 400 rpm's - 600 rpm's. Well after setting the idle to 700 and plugging the IAC back up (and clearing the codes) I took it for a test drive. The truck was idling high (around 1000 - 1100 rpm's). So after about 30 miles I pulled over and re-adjusted the idle down. During the first 30 miles no CEL at all. So I drove another 10 miles or so with the adjusted idle and the CEL started to flash. It flashed for a bit then just stayed on. I continued home and checked the codes and codes 63 and 98 came up again. So after researching I have came to the conclusion (If I am grasping this correctly!) that the idle setting plays a part in how the TP sensor works/reacts. Correct? Is this why I had no CEL while the idle was set higher? And when I adjusted the idle lower the TP sensor then was out of range throwing the code 63 and consequently code 98. Does this all seem reasonable? If so then all I should need to do is go and reset the idle to a max of 600 rpm's with the IAC unplugged and I should be good to go. Right? Please say yes!! LOL!Anyways.............let me know if I am totally of base here of if this is correct. Thanks!
| Sponsored Links | |||
Advertisement | |||
#2 |
iTrader: (0) Bronco Info: 2004 6.8L Excursion 4x4
Yes there is interaction between the idle stop screw and the TPS closed throttle signal value. If you have to turn the idle screw down so far the TPS is below 0.6 VDC then there is a problem. The typical cause of a high idle RPM is a vacuum leak. I think the vacuum leak induced high idle is your root issue here. Adjusting the throttle stop screw to a value below 0.6VDC is masking the true problem.
#3 | |
I may not have been clear in my previous post. I had to replace my idle stop screw due to it being sheared off. So I had to set my reset my idle stop. And the first time I adjusted the idle I had it to high (1000 - 1100 rpm's). Then I adjusted it to low and the CEL came on. So now I need to re-adjust it to the normal range. I will definitely look for any vacuum leaks as well. I did find the two vacuum lines going into the TB intake cracked at the ends. So I just cut them down to where there was no cracks and re-attached. Thanks again!
#4 | |
The Anti Yam!
![]() ![]() Join Date: Oct 2003
iTrader: (4) Bronco Info: 86 Bronco XLT 357w/AOD
Did you check and adjust the TPS after installing the new idle set screw and setting the idle?
Do you have an E4OD tranny? Where those codes KOEO or CM?
86 Bronco - 357W/AOD - 6" suspension lift, 3" body lift - 38" TSL Radials - 456:1 Gears Sequential Multiport Mass-Air Fuel Injection from a 93 Mustang GT My SuperMotors Site - My Engine ![]() The Greatest Thread on FSB Last edited by Gacknar; 08-09-2011 at 01:05 PM. |
#5 | |
I think it is the stock tranny but I haven't really looked into it yet. Key on/Engine off was code 63. Key on/Engine on was codes 63 and 98. |
#6 |
I used to know this stuff
DTC 63 in KOEO Throttle Position Sensor (TPS) below minimum 0.6 volts. Suspect open TP sensor, or grounded, check harness
DTC 63 in KOER TPS ckt has intermittently failed below minimum 0.6 volts DTC 98 in KOEO/ CM Electronic pressure control driver open in EEC (E4OD). DTC 98 in KOER Vehicle did not pass Key On Engine Off (KOEO) test; Rerun KOEO and fix whatever you find there Hard fault present; "...Failure Mode Effects Management (FMEM) FMEM is an alternate system strategy in the PCM designed to maintain vehicle operation should one or more sensor inputs fail. When a sensor input is perceived to be out-of-limits by the PCM, an alternative strategy will be initiated. The PCM will substitute a fixed in-limit sensor value and will continue to monitor the faulty sensor input. If the faulty sensor operates within limits, the PCM will return to the normal engine running strategy. Engine Running DTC 98 or 998 will be displayed when FMEM is in effect. The Malfunction Indicator Lamp (MIL)/Message will remain on when FMEM is in effect. The MIL will come on while the engine is operating in Failure Mode Effects Management (FMEM) or Hardware Limited Operation Strategy (HLOS) modes. The light will stay on for at least 10 seconds, then stay on as long as the fault causing it is present. If the MIL flashes quickly (less than 10 seconds), the MIL circuit should be checked for concerns. Refer to «Quick Test». In FMEM mode, the PCM is receiving a sensor signal that is outside the limits set by the calibration strategy. In this mode, the PCM uses an alternate engine control strategy to maintain reasonable vehicle operation in spite of the fault. The DTC associated with this fault is stored in Keep Alive Memory (KAM). If the fault is no longer present, the light will turn off and the vehicle will return to the normal vehicle strategy. The DTC stored when the light was on is kept in Continuous Memory for the next 80 warm-up cycles (40 cycles on some applications) and then erased. This Continuous Memory DTC can be accessed by running the Key On Engine Off Self-Test..."
96 XL 5.0 E4OD, Man Xfer/Hubs USN (Ret) & MIL/DoD Contingency Planner (ret) THANKS to ALL WHO SERVE! my broncolinks.com was "disturbed"; but some sections are archived @ http://web.archive.org/web/201209211....com/index.php |
#7 | |
The Anti Yam!
Your TPS is giving a reading to the EEC that is less than what it should get with the throttle closed (0.9v) Either it is miss adjusted, the sensor is bad, or you have a wiring problem. 98 KOER = Electronic pressure control driver open in EEC (E4OD) Is your transmission an E4OD (P-R-N-D-2-1 with a push button overdrive)? Was it in park when you ran the KOER test?
86 Bronco - 357W/AOD - 6" suspension lift, 3" body lift - 38" TSL Radials - 456:1 Gears Sequential Multiport Mass-Air Fuel Injection from a 93 Mustang GT My SuperMotors Site - My Engine ![]() The Greatest Thread on FSB |
#8 | |
#9 | |
And my trans does not have a push button overdrive. And yes it was in park when I ran the test. |
#10 |
The Anti Yam!
Do not worry about 98 at this point, concentrate on 63.
#12 |
The Anti Yam!
Correct, You either have an AOD or C-6.
86 Bronco - 357W/AOD - 6" suspension lift, 3" body lift - 38" TSL Radials - 456:1 Gears Sequential Multiport Mass-Air Fuel Injection from a 93 Mustang GT My SuperMotors Site - My Engine ![]() The Greatest Thread on FSB Last edited by Gacknar; 08-10-2011 at 01:26 PM. |
#14 | |
The Anti Yam!
P-R-N-OD-D-1 = AOD Stock AOD's can be a little weak and clunky, but not overly so. C-6's are tough as nails but have no overdrive.
#15 | |
I am still having issues with the code 63. My only symptoms (that I notice) are stalling at start up. When the engine gets warmed up it idles around 650 rpms and nice and steady. I did check and I am getting 5 volts to the TPS connector but I have not back probed it yet. I had a thought I want to run past all of you. Is it possible that the wiring harness side plug is faulty? I have had this code since I bought the truck and began trying to eliminate it. I had a shop install a new TPS and still get the code. So I removed it a re-installed it thinking they did not have it aligned correctly and still get the code. So I am thinking it has something to do with the wiring or plug on the harness side. Any thoughts? And would the stalling out at start up be the only symptoms from a code 63 (Throttle Position Sensor (TPS) below minimum 0.6 volts)? I'm hoping to get this resolved this coming weekend. So any suggestions on what to try or look for would be greatly appreciated. I almost forgot. Is it possible to buy a plug for the wiring harness side? If so any links to where would be appreciated as well!!
#16 |
yo more on DTC 63 in KOEO Throttle Position Sensor (TPS) below minimum 0.6 volts
DH4 CHECK VREF CIRCUIT VOLTAGE; Key off. l TP sensor disconnected. Key on, engine off. Measure voltage between VREF circuit and SIG RTN circuit at the TP sensor vehicle harness connector. Is voltage between 4.0 and 6.0 volts? Yes, REPLACE TP sensor. RERUN Quick Test. No, Key off. RECONNECT all components. GO to Pinpoint Test Step C1. C1 CHECK VEHICLE BATTERY POWER CIRCUIT; Key off. Disconnect Powertrain Control Module (PCM). Inspect for damaged or pushed out pins, corrosion, loose wires, etc. Service as necessary. Install breakout box and connect PCM to breakout box. Key on, engine off. Measure voltage between Test Pin 37 at the breakout box and SIG RTN circuit in the Data Link Connector (DLC). Note voltage. Measure voltage across battery terminals. Note voltage. Are both voltages greater than 10.5 volts, and are both voltages within 1.0 volt of each other? Yes, GO to C2. No Key Off, RECONNECT sensor (if applicable). GO to B1 I don't have the B2 nor C2, yet. BOB test pins numbersp are most often same as EEC pins numbers
#17 |
yo,
EEC Wiring Diagram in 87-89 Bronco & F series (Mitchell) Source: by equivalent (Beetlejuice) at SuperMotors.net EEC Connector Pin Diagram & Overview Source: by Fireguy50 (Ryan M) at fordfuelinjection.com EEC Connector Pin Outs, Bronco & Ford Truck & Van: 4.9, 460, 5.0, 5.8; miesk5 Note, see his Connector Pin Diagram Link above) Source: by Ryan M (Fireguy50) at http://fordfuelinjection.com/truckpinouts.html
#18 |
![]() Join Date: Jan 2011
iTrader: (0) Bronco Info: 1989 Bronco XLT. 4" ProComp lift
I will throw my two cents in here for what it is worth. I was having the same issue on my 351 and was throwing the 63 code. It wasnt until I replaced both the TPS and Fuel Pressure regulator that I was able to clear the codes and oddly enough, pass smog...
#19 |
Thanks for all the info. miesk5! I'm going to try and trouble shoot this this weekend.
mouzer 1: Thanks for your input as well. I have considered the fact that I may have got a faulty TPS from NAPA. But I'm not sure how to tell for sure. Unfortunately I do not have a known good one to switch it out with. And I have already replaced the fuel regulator. |
#20 | |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
