#1 |
iTrader: (0) Bronco Info: '94 XLT 302 /ZF5 speed /33"s/Custom Rock Sliders/Limited Slip Rear/Lead Foot/8000#Winch
OK so my Mazda M5OD manual trans started to hum and wherr and become hard to get into reverse and first gear,vibrate between 4th and 5th(OD) gear......and to think it only has 201,683.0 miles on it....
....and when I'm wheeling, I beat the hell out of it....so it's finally worn out. ![]() I did the due dillegence and found a good company to buy a rebuilt ZF5 transmission from...... ....decent price.....decent shipping price....the correct ZF trans... ...so I bought it.I started my install today.....I will post pics after I get it completely installed and let you know if I have any problems. ![]() Stay tuned....
I wrench on it because I have to....
| Sponsored Links | |||
Advertisement | |||
#2 | |
iTrader: (0) Bronco Info: 5.8 m5od 33" cooper STT removed sway bars msd ignition, MAF swap with open filter, SAS, M15000
w s o m e d u d e
BIG BABIES!!! |
#3 |
I used to know this stuff
yo,
It would be goo to post the install in the Tech Section; I have some Install LINKs in my site @ http://www.broncolinks.com/index.php?index=55 such as (Hot Links for all are there) S5-42 Swap from E4OD in a 95 Source: by Broncobabe (Miss Kitten) S5-42 Swap from E4OD in a 93 Source: by lifeizhard102205 at FSB S5-42 Swap from E4OD Parts List in a 94 Source: by Franklin (Jeff) at FSB S5-42 Shifter Parts Diagram Source: by Steve83 S5-42 (7003) Parts Break-Out Diagram, Service Tips & Troubleshooting Guide; 07-03B-17 1994 Econoline / F-150, F-250, F-350 / Bronco / F-Super Duty Powertrain, Drivertrain Aug 1993 S5-42 Troubleshooting Guide TSB 90-15-11 for 87-91 BRONCO, F & E Series Source: by Ford S5-42 (7003) Disc, Pressure Plate & Slave Cylinder Replacement & Parts Break-Out Diagram in 96 Bronco & F-150, F-250, F-350, F-Super Duty Chassis Cabin 96 Bronco & F-150, F-250, F-350, F-Super Duty Chassis Cab Source: by Ford S5-42 Tips; "...There are three rubber plugs on top of the transmission that leak fluid only when the truck is in motion so when parked there will be no tell tail signs of a leak. You can replace the plugs yourself or take it to the dealer and have them check it for fluid lose and replace the faulty plugs but it's not cheap. Thing is, the seals are going to fail and if caught to lateas in my case cost you a bundle. Another set back for theback yard mechanic is the bleeding of the slave cylinder. If not done exactly correct your clutch will not work no matter how much you bleed it. Bleeding the slave cylinder, which is inside the transmission and not on the outside like older ones, relies more on gravity to bleed and not pumping. It's just a big pain in the ass actually and it will test your patience. Source: by WooleyBugger at wooleysrant.blogspot.com ZF S5-47 Diagnosis & Testing,Overview & Parts Break-Out Diagram, Service Tips & Troubleshooting Guide Source: by ZF ZF, all ZF Loctite Sealant Usage TSB 94-17-13 for Vehicles Built From 2/2/94 GL!
96 XL 5.0 E4OD, Man Xfer/Hubs USN (Ret) & MIL/DoD Contingency Planner (ret) THANKS to ALL WHO SERVE! my broncolinks.com was "disturbed"; but some sections are archived @ http://web.archive.org/web/201209211....com/index.php |
#4 |
Thanks Miesk5,
I needed the fluid chart to verify which Mercon fluid to put in my ZF!!! thanks for the links!!
#5 |
yw,
GL and hope to see the pics & narrative soon so I can include it in my site for others to use.
#7 |
![]() Join Date: May 2007
iTrader: (1) Bronco Info: 95 302 5spd 4.56 w/Detroit in the back 33" tires, warn winch and Custom Soft Top
I have wanted to see this write up for a while as I am sure to have this problem sometime. But I only have 118k on mine. So I can hope, not sure if I am hoping to need to replace or to keep the M05. I would love to see a round scale pricing as well.
#9 |
AKA: Butthead
iTrader: (0) Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
Burque's are just that way. LOL
![]() ------------------------- Ol'Jo, you gonna use an engine hoist? ![]() I made the mistake of putting the rear chain too far back and it bumped into the sheet metal at the rear and had to move it forward while-trying to lift it and so did a sloppy job of moving it. Next time I'll put the rear chain that far back like it is there, except behind the drain plug. See it? :) It's obvious as anything while dropping one but not as obvious when lifting a different model into place. LOL :) Also do yourself a big favor and make a set of these, made mine in '79... ![]() 7/16" coarse thread ~6" long, you don't need to dog nose 'em like I did. ![]() See one in action up there? The ZF slid up to there with a simple push of a foot, no wrestling it into place trying to get it to line up etc. Pins work great while pulling one by yourself too. I made another about a 1/2" shorter that I haven't used yet. Do that. Make 'em about a 1/2" different in length. Gonna make another short one and give a set to my son, he's got a '75 F250 "farm truck" going for the fun of it, that was given to me for parts. With an engine hoist and those pins, it's an easy one man operation! Alvin in AZ |
#10 |
iTrader: (11) Bronco Info: 93 Bronco Custom
I'm interested to hear how you like the shift feel and ratios of the M5R2 vs the ZF.
http://www.mohavebattery.com/ |
#11 |
iTrader: (9) Bronco Info: 94 Bronco 351 ZF5 4inch Procomp lift 33's basani Y mostly rebuilt...
I have the ZF in my bronco now and had the m5 in a 4.0 ranger. I can tell you this the only feeling that is even close between the two is the shift knob. First gear is only good for crawling. To much of a jump between 1st and 2nd to use regularly. So now you have three speed with overdrive. I drive a lot of city type driving. Once moving with a 351w, 33's and 3.54's I am in 3rd and 4th lot from 15-60mph until the roads open up. The ranger I could use a lot more of the gears because they were closer together. My engine doesn't care if lug it down below 1000 rpm and accellerate. It is not a performance feeling trans, it is a truck tranny.
77 Scout SSII 460 c6/np205 Dana 60/14blt H2 wheels 36 Irok radials |
#12 |
AKA: Butthead
x2 :)
I test drove a Bronco 300i6 with the Mazda and felt like 1st was too low and 2nd too high when starting from a stop. :/ With the ZF, 2nd is a little too high with 32" tires and 3.55 gearing and 351w even with the cam timing advanced 4 degrees. YMMV on that one? I snugged up my ZF inside to make it as tight as I could while I had it apart and still it feels like a car transmission shifter compared to my T18 in the '75 F150. But, the ZF shifts slower than the T18 IME. Guessing that's because the ZF's got bigger+heavier gears in it. Don't remember actually -liking- the Mazda in any way! LOL :) Anyone that wants to snug up the shifter on a ZF let me know, I worked out a couple things that took some time to figure out. You'll need it off there first, too hard to describe otherwise. ------------------------- I just plain ol' needed the ZF's pattern, it's the same as my T18 I've had since I was 22. Cars needing the left and up to start, messes me up kinda. Alvin in AZ |
#13 |
From what your telling me I want to put one of my extra M5R2s in my F250 behind the 5.9 instead of a ZF.
#15 | |
I have three M5R2s right now. One is in my 93 Bronco, and the other two are spares since I only get about a year of use out of them the way I use my Bronco.
#18 |
iTrader: (0) Bronco Info: 95 ford bronco, 5.0L V8, M5OD trans, manual BW 1356, Warn Premium hubs
my m50d is junk and its behind a 302. Its been rebuilt once befor at least i think cause theres a plate attached to the bell housing, and the trucks only got 125k on it. Im hoping it lasts untill the new year, then its zf swap time for me.
#19 |
My issue has been with the re builders work so far. I bought my Bronco with a bad trans due to an oil leak. I had it rebuilt and 40K later the forks gave way from not being replaced. Nothing has ever gone "boom" and my motor is not stock. I run 35" tires, 9", Detroit, and have destroyed a 9" case, two drivelines, and a ring+pinion.
If my new roller 351w is too much for it I will go to a custom viperized T-56 setup. The ZF gear ratios just don't suit my use of the truck. I hear it's loud too which will make longer drives even less bearable.
#20 |
I've only had my 351 in for a year, but I do wheel in pretty good when I get a call out for search and rescue
BIG BABIES!!! |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
