Pre-bent brake lines? - FSB Forums
Thread Tools Display Modes
Old 06-11-2004, 12:18 PM   #1
arcane
arcane's Avatar
I'm looking for a set of pre-bent brake lines for my '91 10.25 rear axle, anybody know where to find some? I'm just looking for the quick way out...I'll bend up my own if necessary
'83 XLT, D60 Leaf Sprung Front, 10.25, 40x17.50x16.5, 521
'87 EB, D44, 8.8, 35x15.50x15, 302
'96 XLT, stock
arcane is offline   Reply With Quote
Old 06-11-2004, 02:13 PM   #2
norcalbmxer
Bronco Info: 86
junkyard
norcalbmxer is offline   Reply With Quote
Old 06-12-2004, 09:13 AM   #3
Zebrafive
Try Inline Tube 586-532-1338, or Classic Tubes 716-759-1800
Zebrafive is offline   Reply With Quote
Old 06-14-2004, 09:52 AM   #4
stangmata
WTF,O
stangmata's Avatar
Bronco Info: Bronco-less
Bend your own. It's really easy.
stangmata is offline   Reply With Quote
Old 06-14-2004, 04:38 PM   #5
TxTaurus74
TxTaurus74's Avatar
Bronco Info: 95 Bronco 351W w/ D60 Front & Sterling Rear
This might be a dumb question so dont flame, but is there like a little tube bender you can buy to bend them or are they soft enough to do it with your hands and some basic tools?
My Bronco!
TxTaurus74 is offline   Reply With Quote
Old 06-14-2004, 04:43 PM   #6
Lonestar_Bronco
Welcome to the jungle
Lonestar_Bronco's Avatar
Bronco Info: '78 with a tailgate
You can bend them by hand, but you must be careful not to kink the tubing. You can wrap it around anything round to get a nice curve (pipes, baseball bats, jars, etc.). However, a cheap, yet effective, tubing bender can be purchased at a parts store for under five dollars.
Lonestar Bronco on Supermotors.org
Lonestar_Bronco is offline   Reply With Quote
Old 06-15-2004, 09:05 AM   #7
stangmata
WTF,O
stangmata's Avatar
A tube bender makes for nice bends.
I used my knee, palm, foot, thumb etc to bend mine. A lot of them a bent with just my hands. The hardest part is the flaring. It's different on either end...at least it was on mine. Buy a flaring tool....it will make life much easier.
Old 06-15-2004, 10:06 AM   #8
Sixlitre
Practicing Infidel
Sixlitre's Avatar
Bronco Info: 86 Eddie Bauer; EFI 5.0 liter, AOD, optimized ignition system, external tranny filter, urethane bush
Yeah there's several styles of bender you can get
Ask for a fuel line tube bender, as that's what most places call them. I have one, but now that I can get my brake lines with that spring already wound around them mine's gathering dust on the shelf, as they bend perfectly by hand with that spring wound line.
Did a pile of severe bends to replace the cailper to union lines over my TTB and never had to use the bender once;
Check the rest out here;
http://www.superford.org/registry/ve...=17981#content
BTW
Do the front to rear brake line and those ones I did over the TTB while you're under there. They cost like $2-$5 each and are relatively easy to get to at home in the garage.
Just imagine how $crewed you'd be if they let go on the trail or some far from home hwy (and you in your zoot suit with the wife).
The one that goes back to front has a very different sized fitting that goes on the front part. I just bought a 20" line and cut the end off one side, ditched one fitting, slipped the old fitting onto the line and had a buddy double flare that end of the line for me, then bent away.
Preventative maintenance that's the key to owning older machinery !
Sixlitre
My Superford site
http://www.superford.org/registry/vehicles/detail.php?id=4970&s=17328#content
Sixlitre is offline   Reply With Quote
You may not post replies
Forum Jump
