heater hose diagram - FSB Forums
Thread Tools Display Modes
Old 11-05-2011, 12:47 AM   #1
broncosaurus rex
Bronco Info: 90 broncosaurus
heater hose diagram
I bought new heater hoses, I have no heater hoses hooked up at all and have no idea where to connect to. Can't find diagram anywhere . Help
broncosaurus rex is offline   Reply With Quote
Old 11-05-2011, 07:13 AM   #2
Ewgoetz
Ewgoetz's Avatar
Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs, 200,010Miles
I dont have a diagram, Here's a pic of my PS engine bay. Should be prety similar to yours, for routing the heater hose.
Ewgoetz is offline   Reply With Quote
Old 11-05-2011, 10:20 AM   #3
miesk5
miesk5's Avatar
yo,
Nice pic Ewgoetz!
Here is the flow from Ford;
To heater core is hose on driver's side @ core tubes
From is on Passeneger side
this is the 96 Workshop Manual info;
5.0L (302 CID) MFI Engine (Heater Hose Routing Same Without A/C)
see diagram
1 � Existing Screw (Part of Cowl Panel)
2 19D734 A/C Manifold and Tube
3 9D930 Wiring Assembly
4 N805334-S2 Bolt � Manifold to Compressor (1 Req'd)
5 19D629 Compressor and Clutch Assembly
6 � Heated Throttle Body System (Part of 9E926)
7 390761-S100 Clamp
8 18472 Heater Water Hose (2 Req'd)
9 19850 A/C Evaporator Housing
10 18A586 Wiring Assembly
11 19N704 Clip (2 Req'd)
12 � Tag � A/C Service Instructions (Part of Suction Accumulator/Drier)
13 19835 Condenser to Evaporator Tube
14 376240-S100 Hose Clamp (2 Req'd)
15 8548 Water Bypass Tube
16 � Existing Screw
(Part of 8146)
17 8146 Fan Shroud
18 � U-Nuts (Part of 8146)
19 8005 Radiator
& by Chilton
USN & DoD Planner (ret)
THANKS to ALL WHO SERVE!
Old 11-05-2011, 10:25 AM   #4
miesk5
miesk5's Avatar
yo, May as well insert the 96 5.8 diagram too;
Item Part Number Description
1 � Existing Screw (Part of Cowl Top Outer Panel)
3 19N704 A/C Compressor Hose Clip
4 � Dipstick (Part of 6007)
5 9D930 Fuel Charging Wiring
6 19703 A/C Compressor
7 19618 A/C Evaporator Temperature Control Thermostat
10 19B679 A/C Hose Clamp (2 Req'd)
11 � Wiring (Part of 14401)
12 376240-S100 Hose Clamp (2 Req'd)
13 8146 Fan Shroud
14 19835 Condenser to Evaporator Tube
15 � U-Nuts (Part of 8146)
16 9E799 Speed Control Vacuum Reservoir
17 � Tag � A/C Service Instructions (Part of 19C808)
18 8005 Radiator
Old 11-05-2011, 01:41 PM   #5
JKossarides
JKossarides's Avatar
Looking at the picture at that unbelievable pristine engine compartment ...lol lol....the "return line" hose, left firewall hole goes to the water pump and the "inline" hose, right firewall hole goes underneath the fuel injection plenum eventually to the lower intake manifold, can't quite see.
If they're hooked up in correctly you won''t have any heat and the temp guage reading may be off.
Good Luck ~
Old 11-05-2011, 03:23 PM   #6
Jasonhughes2009
I scrape on both sides
Jasonhughes2009's Avatar
Bronco Info: another rig that runs on crapoline
what is that?
1991, fresh 5.0, OBA, 6 inch lift, 9 inch rear, 5.13s. detroit rear aussie front, 37" pitbull rockers, beadlocks. e4od
Originally Posted by tonyroc14 View Post
If only I could have 6 of his 32 inches!
Jasonhughes2009 is offline   Reply With Quote
Old 11-05-2011, 03:37 PM   #7
Seattle FSB
Seattle FSB's Avatar
Bronco Info: 1990 EB FSB, MAF, 6.7L, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
Vacuum Reservoir. Ford Part #9E453. Plastic instead of a can.
1990 Bronco, MAF, 408 Stroker, Level 10 E4OD, Currie F9+, Electric Boost Brakes, lots more...
Seattle FSB is offline   Reply With Quote
Old 11-05-2011, 07:42 PM   #8
Bruno2
Bronco Info: 1987 Full size 351 Windsor lots of power mods C6 beefed up BW 1356
How about an 87 5.8 Diagram?
Bruno2 is offline   Reply With Quote
Old 11-05-2011, 10:10 PM   #9
broncosaurus rex
Thanks ... Ur engine looks like showroom condition.
Old 11-06-2011, 08:12 AM   #10
snookgetter
snookgetter's Avatar
Bronco Info: 93 EB 302 94 EB 351
I see lots of these plastic vaccum cans at the JY,any advantage to these over the metal ones?
93 EB 5.0, BFG KM2's, E4OD, manual BW1356, 160 amp 3G, Warn manuals
94 EB 5.8, E4OD, push-button BW1356, Warn manuals
snookgetter is offline   Reply With Quote
Old 11-06-2011, 08:24 AM   #11
justin
BRONCO WIZARD
justin's Avatar
Bronco Info: 96 XLT/5.0/E4OD
Plastic doesn't rust.
You have enemies? Good. That means you've stood up for something, sometime in your life.
-Winston Churchill
justin is online now   Reply With Quote
Old 11-06-2011, 08:36 AM   #12
miesk5
miesk5's Avatar
yo BRUNO,
87 heater hose routing 5.8efi
"...Reversing the heater core hoses (8) AT THE HEATER CORE will not cause any problems, and may help remove debris from the heater core. To bypass a leaking heater core, disconnect the supply (lower, hot) hose at the engine and the outlet (with T) at the heater core. Loop the hose still attached to the engine back to the open nipple. Set the remaining hose out of the way..."
by Steve83 (Steve, That dirty old truck) at http://www.supermotors.net/clubs/sup...y/media/512252
Old 11-06-2011, 12:23 PM   #13
Bruno2
Thanks Miesk5 I was wondering which one went to the HC and which one went to the WP. I guess it doesnt matter. I suppose it doent matter which WP connection I put the bypass hose on and which WP connection I put the HC line on either.
Old 11-06-2011, 02:55 PM   #14
KHCO67
KHCO67's Avatar
Bronco Info: 1990 Bronco Custom. V8 5.0
AND....I think it looks better than a 1980 travel size Folgers coffee can with the sticker removed ;-)
KHCO67 is offline   Reply With Quote
Old 12-07-2011, 01:04 AM   #15
homesickalien
Cooling System parts question
I was going to use that beautiful engine bay picture to post a parts question but I'm not allowed to create new threads yet. Apologies, as I'm not trying to threadjack. I'm overhauling my cooling system because I just bought a 95 Bronco and the hoses need replacement. One of the hoses has the ends of the line all chewed up from the worm clamps being overtightened at both ends, but the only reference to it in the manual that I see is that it is called the "heater water bypass hose" and has no part number. It attaches right under the overflow tank tube in my car and I guess it's only on E4OD versions. I need to get a new one or replace the tubing on either side. Is there a part number for this? The middle portion of the line is metal and is clamped onto the radiator. Thanks!
homesickalien is offline   Reply With Quote
Old 12-07-2011, 01:44 AM   #16
Bruno2
Should be just called a bypass hose. There shouldnt be anything permanently attached to the radiator. There should be some lines attached to the tranny going into the radiator for heating purposes , but , they should have threaded fittings .
Old 12-07-2011, 11:38 AM   #17
miesk5
miesk5's Avatar
yo homesickalien,
Belt & Hose Parts Catalog, Bronco/Ford truck & all Fords w/Ford Part Numbers, Illustrations & Cross Ref
Source: by ford http://www.fordinstallersupport.com/...s/belthose.pdf
32 MB pdf..
Page 115
HOSE
INSTALLATION MOLDED/
DESCRIPTION BULK
8 Cylinder 5.0L (302)
Hose Water By-Pass Super Cooling Pkg KM-2993
Hose Water By-Pass KM-3057
Crankcase Vent . KCV-120
Cooling Systems ...... KM-2923
Cooling Systems; Upper .......... KM-2921
Water Heater Hose; Return ....... KH-263
Water Heater Hose; Return ... KH-208
8 Cylinder 5.8L (351)
(H) Hose Water By-Pass Super Cooling Pkg ........ KM-2993
(H) Hose Water By-Pass ........... KM-3057
(H) Crankcase Vent ... KCV-121
(H) 4 Spd Crankcase Vent ........ KCV-100
(H) Cooling Systems ......... KM-2924
(H) Cooling Systems ....... KM-2921
(H) Water Heater Hose; Return .......... KH-267
Have to ensure that the Ford short version part numbers apply to youe Engine type... and if you have super cooling package
Throttle Body Coolant Line From Radiator to Throttle Body; Ford part number; "F2TZ8555B (20" mounting tabs) (2 core radiators);...in another post he wrote; ; 20" would be a 2 core radiator; 24" would be for a 1 core radiator"
Source: by Need4racin (The 90 Bronco, Dean) at http://fullsizebronco.com/forum/showthread.php?t=156267
Next is by Ford @ http://www.fordparts.com/Commerce/Ca...=Bronco#Search
Water Pump By-Pass Tube
5.0L; E4OD - std. cooling; 24'' between mounting brackets
5.0L; E4OD - Super cooling pkg.; 20'' between mounting brackets
click "View Image"
Old 12-12-2011, 12:57 AM   #18
homesickalien
miesk5, Thanks! That's the part I was looking for.
Old 12-12-2011, 01:25 AM   #19
TheUnforgiven
Huh Huh vanzercool
TheUnforgiven's Avatar
Bronco Info: 2005 Chevrolet Venture, 1997 Acura TL
^^^ you have one of the more creative screen-names i have seen in a long time.
2005 Chevy Venture. 1997 Acura TL. $500 beater.
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 12-12-2011, 08:01 AM   #20
miesk5
miesk5's Avatar
yo, YW
I think that the F2TZ8555B unit is almost gone according to the obsolete Ford part sites I use;
http://www.rearcounter.com
F2TZ-8555-B Availability: Currently Out of Stock
HOSE - WATER INLET Condition: New OEM / NOS (New Old Stock)
at http://www.rearcounter.com/
F2TZ-8555-A-parts Availability: 1 found at 1 seller
Description: HOSE - WATER INLET
Condition:New OEM / NOS (New Old Stock)
PiFordparts.com
Farmers Branch, TX
at
http://www.partsvoice.com/
F2TZ8555A
Lincoln Lacy Motors
Malden, MO 63863
Updated Nov 24, 2011 Email dealer Dealer Contact Info
Palmetto Ford Truck
Miami, FL 33166
Dealer Website
Updated Dec 11, 2011 Email dealer Dealer Contact Info
305-592-3673 1
Bowden Ford Lincoln Mercury Co
Alice, TX 78332
361-664-9541
1
Central Ford
VEGA ALTA, PR 00692
F2TZ8555B none
http://www.greensalescompany.com neither pn in stock
You may not post replies
Forum Jump
