C6 out. NP435/ranger gear splitter IN - FSB Forums
Thread Tools Display Modes
Old 12-13-2011, 12:23 PM   #1
coltscovel
coltscovel's Avatar
I am pooling parts for this swap. i am not a auto trans guy and i totally like having a gear splitter (had one on a 72 dodge dart). does anyone know when the clutches were switched from linkage to hydralic? i want to run a hydralic for syplicity. and i dont think my 84 bronco has the frame brackets to run the linkage. also what will need to be done with the nutral safty switch. i just want it dissabled so i can reach in the window and turn the key. and i am retro fitting a remote start on soon and not having the safty switch will be nice. thanks ahead of time.
truck- 84 bronco 300 six C6 auto NP208
coltscovel is offline   Reply With Quote
Old 12-13-2011, 12:29 PM   #2
kemicalburns
Never Done
kemicalburns's Avatar
your rear driveshaft is going to be crazy short. why not swap in a manual ZF 5 speed tranny.
For Sale - 94 XLT 357/E4OD Trans-go stage II
6" Stage II ProComp,35" BFG/AT 4.88 f (aussie) / r (open) / Custom Sliders, Custom bumper Warn HS9500, Edelbrock truck upper/lower,JBA headers,Custom Y pipe hi flow cat & Full 3"
kemicalburns is offline   Reply With Quote
Old 12-13-2011, 12:51 PM   #3
coltscovel
coltscovel's Avatar
that was my initial idea. basically i really like the gear splitter. alot of the highways here are weird speeds like 50mph and such where 3rd "and a half" would be perfect. i had a electronic one (gear vendors) on my old mucle car and it was great. also i like the np435. i can rebuild it and replace it for dirt cheap. the truck will be stock hight plus a 1inch body lift for tranny clearence so the rear drive line isnt that big of a deal. this truck is a daily driver and road tripper.
Old 12-13-2011, 12:53 PM   #4
coltscovel
coltscovel's Avatar
and the splitter is only 7.5 inches long. plus i am trying to figure out a way to loose some of the tailhousing of the trans. i am rebuilding a np205 to go behind it and i think i can take of a couple inches out of the middle and chop the output shaft.
Old 12-13-2011, 12:54 PM   #5
coltscovel
coltscovel's Avatar
about how long is the D shaft behind your E4?
Old 12-13-2011, 01:04 PM   #6
coltscovel
coltscovel's Avatar
(bronco graveyard measurments) My driveshaft is about 30 1/16 colapsed. the 5 speed broncos are about 25 7/8. so if i can ditch a couple inches and get the thinner transfercase (I beleave the 205 is thinner than 208) i could probley use a stock d shaft. sorry about all the random posts. kinda A.D.D and like to tangent :)
Old 12-13-2011, 04:32 PM   #7
AbandonedBronco
Big Six
AbandonedBronco's Avatar
Bronco Info: 1981 300ci 6cyl w/4bbl conversion. 4spd manual
I'm not sure of the exact year, but I have two Broncos. Both are 300s with manual transmissions.
The '81 has a mechanical clutch and the '84 has a hydraulic clutch.
The '81 can start by just reaching in the window and turning the key. The '84 requires that the clutch is held down to the floor before it'll start.
That should at least narrow your range.
1981 & 1984. Both w/ 300 I6. Holley 465 / 600 4bbls. 31x10.5" tires. NP-435 trans. 2.5" Exhaust.
Supermotors Pics
AbandonedBronco is offline   Reply With Quote
Old 12-13-2011, 07:36 PM   #8
coltscovel
coltscovel's Avatar
Great that does help. Question for you. What kind of od is in ur sig. I am looking at the ranger gear splitt er
Old 12-14-2011, 10:43 AM   #9
AbandonedBronco
Big Six
The 4spd is an SROD.
It's not the greatest transmission. The casing is aluminum and the mounting tabs that bolt it to the cross-member typically break off (both mine are broken, so the only thing holding my trans in place is that it's bolted to the engine).
No granny, and a really big gap between 2nd and 3rd.
It's taken me a lot of places, and gets pretty good gas mileage, so it's not necessarily a bad transmission, but there's a reason they only put it in Broncos for 3 years.
Supermotors Pics
Old 12-15-2011, 12:17 PM   #10
coltscovel
coltscovel's Avatar
lol. fair enough. that is the big reason for me wanting a tourqe/gear splitter. six forward speeds and i travel alot. in my 76 chevy 4x4 (shhh. its gone now) with a 4 speed to down shift from 4th to third on a hill or something was not fun. plus i will be installing my ranger with a electonic actuator that is controlled from the steering wheel with a "od" light on the dash for when its engaged. i will be able to split the gears and shift at the same time. should be a pretty cool and reliable.
Old 12-15-2011, 12:19 PM   #11
coltscovel
coltscovel's Avatar
oh and you were correct on the hydralic clutch. 85,86 had them. the previous were mechanical. my bronco was built in 83 (titled and sold as 84) so i will probley look for the stock mechanical link.
You may not post replies
Forum Jump
