Sharp left turn-steering wheel jerks back and forth. '89 - FSB Forums
Thread Tools Display Modes
Old 02-01-2012, 11:27 PM   #1
TNT89Bronco
How did I get 6 Rigs??
Bronco Info: '79 351M NP435 and '78 Custom 400M C6 w/sliding windows
This morning, when making a left hand U-turn, I noticed that when I had the steering wheel cranked all the way to the left, the steering wheel jerked back and forth, like I was driving over a bunch of little curbs or something. Like it was being forced to the right a little, and then snap back to the left real quick. It was kind of weird, because it had never done that before. This is a stock rig, and it seems to drive fine otherwise (steering is a little loose, but nothing major).
I had someone hop in and do the same thing, and they felt it. I watched the front wheels, and they didn't seem to jerk or make any noise.
What should I do to try and determine what is wrong? Any ideas?
Like I said...stock, no lift or oversized tires.
'79 Bronco 351M 4 Speed Custom.
'79 Bronco. 400 C6 Custom w/AC.
'78 F250 400 Custom 4x4
'78 F250 460 C6 Camper Special
Check out my '79 Restoration Project...http://www.fullsizebronco.com/forum/...d.php?t=203050
TNT89Bronco is offline   Reply With Quote
Old 02-02-2012, 12:43 AM   #2
alhefner
Bronco Info: 1990, XLT, 302 remanufactured engine, AOD
That's your power steering. Check the fluid level first but there is a possibility that the proportioning valve is a bit iffy...there are other things that can cause it but I would start there...
My Nevada outdoor blog
alhefner is offline   Reply With Quote
Old 02-02-2012, 01:05 AM   #3
TNT89Bronco
Ok, I will check, but this was a very strong jerk, and not a small shake.
Old 02-02-2012, 01:12 AM   #4
Jasonhughes2009
I scrape on both sides
Jasonhughes2009's Avatar
Bronco Info: 91 ish
4x4 engaged for any reason on accident?
but yeah, check fluid in pump and if that doesnt help i might look into the gearbox
1991, fresh 5.0, OBA, 6 inch lift, 9 inch rear, 5.13s. detroit rear aussie front, 37" pitbull rockers, beadlocks. e4od
Originally Posted by tonyroc14 View Post
If only I could have 6 of his 32 inches!
Jasonhughes2009 is offline   Reply With Quote
Old 02-02-2012, 01:13 AM   #5
alhefner
I've had the same issue, on other vehicles, and yep, the power steering can really jerk your wheel hard when you are close to maxing out the turn...It can just about jerk the steering wheel out of your hand.
Old 02-02-2012, 11:29 AM   #6
Mike4xdriver
Mike4xdriver's Avatar
Bronco Info: 91' F-150 I-6, Auto, 4x4
Make sure to check your axle shaft Ujoints. If you have one that is seizing up it could cause this problem.
91' F150 Reg Cab LB, I-6, Auto, 4x4, 65K miles.
Mike4xdriver is offline   Reply With Quote
Old 02-02-2012, 12:26 PM   #7
Gacknar
The Anti Yam!
Gacknar's Avatar
Bronco Info: 86 Bronco XLT 357w/AOD
You have a hub locked.
Do you have auto's or manuals?
86 Bronco - 357W/AOD - 6" suspension lift, 3" body lift - 38" TSL Radials - 456:1 Gears
Sequential Multiport Mass-Air Fuel Injection from a 93 Mustang GT
My SuperMotors Site - My Engine
The Greatest Thread on FSB
Gacknar is offline   Reply With Quote
Old 02-03-2012, 10:14 AM   #8
TNT89Bronco
I have manual hubs, and that was the first thing I checked. Not locked. Fluid level good.
Old 02-03-2012, 10:20 AM   #9
Gacknar
The Anti Yam!
Gacknar's Avatar
Originally Posted by TNT89Bronco View Post
Not locked.
Not locked as in you spun the driveshaft and made sure both steering u joints spun confirming the hubs where unlocked?
Or not locked as in you looked at the hubs and the dial says free so they must be unlocked, because a hub could never fail locked?
Old 02-03-2012, 10:35 AM   #10
Glayd
Glayd's Avatar
Bronco Info: 1989 XLT, 351W, C6 and 1994 XLT, 351W with E4OD
yep Gacknar may be right. I had the same thing going on with my 89. Hub said free but I couldnt rotate the steering ujoint. Replaced the hubs with warn hubs and no more problem. It was the manual lock that wasn't disengaging when you turned it to free. That would be worth checking into.
Poopy Pants: "Kid, we all own Broncos here, every last one of us Bronco owners is poor. Get used to it."
Glayd is offline   Reply With Quote
You may not post replies
Forum Jump
