2 E4OD transmissions and still same PROBLEM - FSB Forums
Thread Tools Display Modes
Old 02-15-2012, 08:45 PM   #1
92_chaser
92_chaser's Avatar
Bronco Info: 1992 Bronco 4x4. Race Build
7 Months and going guys. Heres what I have replaced since my Bronco went into limp mode:
#1 Transmission:
VSS
MLPS (New Connector)
3 Solenoid packs
1 Solenoid Harness
3 PSOM (Speedometer Cluster)
1 ECU (Computer
Replaced all fuses
All New Fluid and Filter
After buying all these things, and checking every WIRE in the harness, Bronco will still not shift out of low gear. NOW....
I bought another Transmission Rebuild from a '93 thinking It was last option....
Nope! still will not shift on its own. The odds of all these parts Ive replaced and the people I have talked too is astronimical! You would have better odds at winning the lottery.
Still get the same codes, 624, 638. EPC circuit low, transmission temp out of range. My OD does not work either. Was blinking, but now does nothing. Any one else know what to check? Im thinking there is a cross somewhere in the wiring thats grounding out my solenoid pack?
92_chaser is offline   Reply With Quote
Old 02-15-2012, 08:46 PM   #2
92_chaser
92_chaser's Avatar
Believe me, a c6 is coming very soon, I hate these e4od transmissions
Old 02-15-2012, 09:29 PM   #3
catsnw
A broke kid with a bronco
catsnw's Avatar
Bronco Info: 1995 EB bronco 5.8, auto, true duals, k&n intake, 3G alternator, 12 front lights (more to come!)
Does the speedo work?
Originally Posted by 88LiftdBronco View Post
So what you're saying is, that when you see a penis you think of another guy?
٩(●̮̮)۶
catsnw is offline   Reply With Quote
Old 02-15-2012, 09:30 PM   #4
92_chaser
92_chaser's Avatar
Yes sir
Old 02-15-2012, 09:33 PM   #5
92_chaser
92_chaser's Avatar
2k worth of stuff and not one part has fixed or changed its symptoms
Old 02-16-2012, 01:11 AM   #6
fire bronco
fire bronco's Avatar
Bronco Info: Bright F'in Yellow retired fire department chief buggy with 351
did you make sure your tranny cooler is working/flushed. Maybe it got some gunk in there and screwing things up? Change the temp sensor if there is one, get the cooler and tranny completely flushed (not just fluid changed). Or get rid of the stock cooler and put in an aftermarket one. Maybe use a high end oil like Royal purple. Expensive, but I put that in my tranny and it made a world of difference, better milage, better shifting, and probably runs cools. Also, (the most annoying part) trace all the wiring and make sure none of it is rubbing raw anywhere from frame/body contact. Make sure all pins on connectors are fully seated. Since you replaced all those things and still have issues, I'd bet it's a wiring issue.. I'm guessing you're not replacing all the vehicle wiring in all this...it's the only thing not changed
94 bronco w/ 351, 3.55 gears, 33x12.5x15 procomp a/t, msd blaster ss coil, msd cap/rotor, KN gen 2 intake, Napa performance wires, e3 plugs, 4" Rancho lift, much more to come when $$$ comes around
fire bronco is offline   Reply With Quote
Old 02-16-2012, 02:23 AM   #7
92_chaser
92_chaser's Avatar
Yea I forgot to mention I flushed the trans lines allready too.
If its the wiring do you know where to buy whole harnesses besides pick n pull?
I looked on rockauto.com but they didn't have a transmission harnesses
Old 02-16-2012, 01:11 PM   #8
kemicalburns
Never Done
kemicalburns's Avatar
arent the solenoid packs and associated wiring pinned different from 92-93
For Sale - 94 XLT 357/E4OD Trans-go stage II
6" Stage II ProComp,35x12.50BFG/AT
4.88 f (aussie) / r (open) / Custom Sliders
JBA headers,Custom Y pipe hi flow cat & Full 3"
kemicalburns is offline   Reply With Quote
Old 02-16-2012, 01:31 PM   #9
jermil01
Charlie doesn't surf!!
jermil01's Avatar
Bronco Info: 1992 xlt, 351EFI, .040, E4OD, D44 SAS w/Trutrac,Detroit locked 8.8, MAF conv, Tweecer tuned
This definitely sounds like it's wiring related..I had something similar come up when I swapped a '95 engine harness into my '92. did you change the engine harness on your rig?
check out post #117 in my MAF conversion thread. I cover every single bit of wiring for the E4OD in this. Might be useful.
http://www.fullsizebronco.com/forum/...=196630&page=6
Vote 4 Top 4x4 Site!!!
jermil01 is offline   Reply With Quote
Old 02-16-2012, 02:23 PM   #10
TheUnforgiven
No longer Kia boy
TheUnforgiven's Avatar
Bronco Info: 2005 Chevrolet Venture
have you ever thought that maybe the EEC itself is at fault?
2005 Chevy Venture, not a bronco. Deal with it.
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 02-16-2012, 07:00 PM   #11
TS 90F150
Bronco Info: 1990 F150, 5.8 w/GT40X heads, Lightning intake, E4OD
If you look closely, says he has replaced it already.
tim
TS 90F150 is offline   Reply With Quote
Old 02-16-2012, 10:15 PM   #12
drialec
does it need to be re-learned?? are the e40d that bad?? and how hard is the c6 swap??
drialec is offline   Reply With Quote
Old 02-16-2012, 10:16 PM   #13
Shadofax
Owned 19yrs, now for 20
Shadofax's Avatar
Bronco Info: 95XLT351 E4OD SAS 44/ARB/Alloy shafts-joints. D60 rear/Detroit. 4wheel disc,37" MTR Kevlar, 4.56etc.
I know a lot of folks insist on diagnosing and fixing problems on their own, but with all the time and parts you've thrown at it, wouldn't it have made sense to bring it to a dealer and pay them to diagnose and then decide if you want them to do the work or take it back and do it yourself?
______________________
Click my supermotors link for tech on TCase, SAS, OBA, Soft Top, Overhead Console, Stock bumper Winch install, much more..:
http://www.supermotors.net/registry/628
Shadofax is offline   Reply With Quote
Old 02-16-2012, 11:47 PM   #14
92_chaser
92_chaser's Avatar
I took it to two different shops who couldn't tell me what's wrong. I'm on the brink of c6
Old 02-16-2012, 11:48 PM   #15
92_chaser
92_chaser's Avatar
The only two things I havnt replaced are the tps sensor and map sensor
Old 02-17-2012, 12:08 AM   #16
reptillikus
ate lug
reptillikus's Avatar
Bronco Info: 88ish bronco(?)/96 F250; both with D60s
Neither a bad TPS sensor nor MAP sensor will cause this problem, so we dont have to worry about those.
Ok lets start from the beginning, see if theres a clue weve missed.
You said the fist transmission went into limp mode. What was wrong with it that it went into limp mode (what was it doing/not doing, what codes, etc)? Im assuming you replaced the solenoid packs with it in, but when it still didnt shift, you dropped the trans and swapped it out?
So now here we are with a second trans installed, and it is the exact same problem as the first? Does it go into first & reverse? If you shift from 1 to 2, will it upshift to 2nd? How about when its in D?
reptillikus is offline   Reply With Quote
Old 02-17-2012, 01:09 AM   #17
Shadofax
Shadofax's Avatar
How can you be thinking C6 with no OD?
Old 02-17-2012, 01:26 AM   #18
Red91XLT
It's all about Winning.
Red91XLT's Avatar
Bronco Info: half a bronco
This.
Did you maintain records of any codes pulled during the course of this issue?
if you have a GOOD replacement E4OD in place, I urge you to retain it and continue trouble shooting this issue.
as Jermil said, it sounds wiring related. Do NOT give up hope. Although, feel free to sell some things you've already bought or replaced to offset your costs.
'91 XLT-totaled
Originally Posted by Gacknar View Post
This is not a Democracy, it is a Broncocracy
Originally Posted by Redwagon View Post
You do realize that you just reported the new owner of FSB?
-James
Red91XLT is offline   Reply With Quote
Old 02-17-2012, 01:54 AM   #19
TheUnforgiven
No longer Kia boy
tim
good Lord i fail.
Old 02-17-2012, 02:10 AM   #20
92_chaser
92_chaser's Avatar
Yes all gears are working. P R N D 1 2. When I go to D it will not get out of low/ 1st gear. Since 6 months I keep getting the same codes 624 and 638. 3 different solenoid packs. I'm asking is there anything else I'm over looking before I get a transmission harness replacement.
You may not post replies
Forum Jump
