#1 |
clatter sound when going up hill
hey guys, so my bronco (95 302 e4od) has this problem where it makes a clattering sound during acceleration in 3rd and 4th gear. it is most noticeable while going up hill and sounds like my cylinders are knocking all at once. (ive never heard that but id say thats what it would sound like). thing is it only makes this noise when i accelerate and after i let off the gas it stops. also will do it a little bit if i floor it from a start. recent oil change, cleaned iac, cleaned air filter, new pcv valve, new fan clutch, also noticed it does it more often with the ac on. also does it at around 45 after the cruising motor speed slows it will do it and gets louder if i try to accelerate without taking my foot off the gas first. please help! also sounds like its coming from in front of and to the right of the driver seat.
| Sponsored Links | |||
Advertisement | |||
#2 |
wouldnt you like to have
iTrader: (1) Bronco Info: 91 bronco 5.8 e40d
its called "spark knock", Id suggest a tune up if not a recent one done.
also might be a good time to check your timing if you know how, and have a timing light. finally if you dont want do any of this, just buy premium gas next time its really really low, that will also take care of it.
"If you think education is expensive, try ignorance". "Lifes tough, put on a helmet. Turn off the computer, and go outside"
#3 | |
iTrader: (0) Bronco Info: 1995 Bronco XLT, 302 5.0 L V8, complete with dashboard hula girl
1995 5.0 Liter 302 V8 Bronco XLT Added on: Gibson Exhaust, Westin powder coated running bars, 'Mexican Blanket' seat covers, Pioneer speakers, Alpine head unit, XM Radio Onyx reciever, freshly shampooed carpets, dashboard hula girl, surf wax air freshener...
#4 |
just replaced all my plugs maybe 300 miles ago, fresh oil change, wires are a year old, distributor is 2 yrs old, pulled codes came up with 172 - HEGO shows system always lean. 211-PIP circuit fault 212- loss of IDM input to PCM or spout grounded 334 - EGR closed voltage higher than expected. any of that help? ill try the premium today.
#5 |
also timing is dead on, checked that yesterday.
#6 |
also the engine in my truck is out of a 91 grand marquis, im still using all the same accessories except the water pump. will any of this be the problem?
#7 |
#8 |
Pull codes on that bad boy and see if it is reporting anything.
#9 |
already pulled codes, their up there. it is 10degrees btc
#10 |
My bad, didn't read the post fully...
#11 |
the code reguarding the pip would be a good reason your having this issue.
#12 |
what would cause it? distributor? coil? should i upgrade to msd dist/coil?
#13 |
iTrader: (0) Bronco Info: 1990, XLT, 302 remanufactured engine, AOD
I would be getting on this too...it could be your ICM, Crank position sensor, or camshaft position sensor according to what I have been reading in other forums and threads...also, check out the spout grounded possibility...
My Nevada outdoor blog |
#14 |
i put premium in it and the noise went away, put some mid grade in it and its back.. maybe fuel pressure problem? brand new fuel filter.
#15 | |
iTrader: (1) Bronco Info: 1996 Black 302 XLT - 1994 Green 351 E. B. both have E4OD, 3.55 axles, 31 10.50x15
Fuel delivery and fuel pressure would not be affected by premium versus regular.
"The simplest solution is usually the best solution" - Occam's Razor "The significant problems we face cannot be solved at the same level of thinking we were at when we created them." - Albert Einstein |
#16 |
iTrader: (0) Bronco Info: '90 Eddie Bauer 33x12.5 r15 302
You need to be sure that you disconnect the SPOUT connector when you check your ignition timing, but with those codes I'd pull my ignition control module and have it tested.
#17 |
![]() Join Date: May 2007
iTrader: (4) Bronco Info: 1990 EB FSB, MAF, 6.7L, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
With the codes you have, I would focus on PIP/ICM. See this link: Throttle Position Sensor Testing, Replacement and Adjustment
1990 Bronco, MAF, 408 Stroker, Level 10 E4OD, Currie F9+, Electric Boost Brakes, lots more...
#18 |
Hey Seattle FSB,
I think that you linked to the wrong page. I'm thinking that this one would be better for checking the ICM :) http://www.fullsizebronco.com/forum/...05&postcount=9 |
#19 |
#20 |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
