Aftermarket/Decent tranny cooler - FSB Forums
Thread Tools Display Modes
Old 03-24-2012, 07:57 PM   #1
TheRedneckDrummer
TheRedneckDrummer's Avatar
Bronco Info: 88 Bronco Custom. Stock with 33 BFG Mud Terrians... But im not planning on keeping it stock
My stock one is leaking pretty bad. Should I just install another stock one orrr whats your guys's opinions?
Its the skinny one on the right
TheRedneckDrummer is offline   Reply With Quote
Old 03-24-2012, 08:16 PM   #2
Ewgoetz
Ewgoetz's Avatar
Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs,172,000Miles
Depends how much work your willing to do. Go with a stock one and its bolt in. Go with a aftermarket larger one than you will ahve to fab some brackets up to make it fit. A bigger aftermarket one would be better.
"hold my beer and watch this"
Hydroboost walkthrought
My Build Thread!! II
My Build Thread!! - retired
Ewgoetz is online now   Reply With Quote
Old 03-25-2012, 12:21 AM   #3
351w500
Unforgiven's Pet
351w500's Avatar
Bronco Info: '90 xlt 351w E40D Truetrac I GOT ROLLER ROCKERS !
The B&M Supercooler is a fine trans cooler.
351w500 is offline   Reply With Quote
Old 03-25-2012, 12:31 AM   #4
Seattle FSB
Seattle FSB's Avatar
Bronco Info: 1990 EB FSB, MAF, 6.7L, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
That is what I am using, a B&M Racing 29,200 BTU Transmission Oil Cooler (11x11x1.5)(PN 70274). Add in a Perma-Cool Remote Transmission Oil Filter Mount (PN 10678) and a WIX Transmission Fluid Filter (PN 51622) why you are at it.
1990 Bronco, MAF, 408 Stroker, Level 10 E4OD, Currie F9+, Electric Boost Brakes, lots more...
Seattle FSB is offline   Reply With Quote
Old 03-25-2012, 12:33 AM   #5
Steve83
Steve83's Avatar
Stacked-plate coolers are the best. Get a stock one from a newer truck in the JY if you don't want to drop the loot for a new aftermarket.
Old 03-25-2012, 01:55 AM   #6
TheRedneckDrummer
Any good dealers or brands in mind?
And SeattleFSB, how much did those run you up if you dont mind me askin
Old 03-25-2012, 02:11 AM   #7
Seattle FSB
The cooler is about $93.00 and the filter mount is about $60.00. See Summit, Jegs, B&M or Perma-Cool. The oil hose is specific or spend the money and go braided stainless steel like I did.
Old 03-25-2012, 11:39 PM   #8
TheRedneckDrummer
How much better is the B&M Supercooler over a stock one? 50 bucks isnt bad and Im interested in it
Old 03-26-2012, 01:02 AM   #9
Steve83
Steve83's Avatar
Not enough to notice. If you're towing the truck's max trailer weight through Death Valley in June with the cruise set at 80mph, you probably still couldn't measure a difference in the 2 coolers' performance.
Old 03-26-2012, 02:59 AM   #10
GetBent4x4
Bronco Info: Brick Nose on 15x10s/32s with leveling coils
Seattle, did you upgrade to 3/8ths lines all the way back to the e4od. I have the same parts waitting to go on a rig, but I don't know if I want to bottle neck the 1/2" cooler and 3/8" t-stat/filter on a 5/16th line. If you upgraded to 3/8ths lines, did you have to put 5/16" fittings for the e4od and radiator onto the new lines, is that possible or did you use some kind of adapter?
Thanks bud.
GetBent4x4 is offline   Reply With Quote
Old 03-26-2012, 04:34 AM   #11
Seattle FSB
Sort of. All are -6 AN lines which are equivalent to 3/8". Everything is using adapter fittings to -6 AN as they make a better connection. There is almost any kind of hydraulic adapter fitting you can think of available. See this link: BillaVista Tech Garage Plumbing Bible
E4OD Feed and Return
Perma-Cool Filter Adapter
B&M Transmission Cooler
Radiator Transmission Cooler
-6 AN Stainless Steel Hydraulic Lines
Old 03-26-2012, 02:03 PM   #12
TheRedneckDrummer
Interesting... Thanks Steve
Old 03-27-2012, 05:59 PM   #13
GetBent4x4
Thanks bud, bookmarked. I need to get this truck done!!
Old 03-27-2012, 06:53 PM   #14
DNBELOWBRONCO
DNBELOWBRONCO's Avatar
Bronco Info: '96, 5.8, 4.56, Rancho 4", 35's, Thorleys, Warn 8274, 5100's, 160 3G, Sag, 10.25, E-fan, Projectors
Hey Seattle-How did you attach the lines as they went along the body? Do they have special retainers or fasteners? I replaced my hard lines but just went with standard rubber transmission hose. I have the stock trans plate cooler and a Perma-cool aux filter too... -Kevin-
DON'T GIVE UP PUSH THE PEDAL ON THE RIGHT JUST A LITTLE BIT HARDER DNBELOWBRONCO www.supermotors.net/17883 "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind" -Dr. Seuss-
DNBELOWBRONCO is offline   Reply With Quote
Old 12-01-2012, 03:42 AM   #15
cajunrebel
Chillin on the Gulf Coast
cajunrebel's Avatar
Bronco Info: Blue 89' 5.0, E4OD, OBDII, Mass Air, Saginaw/hydroboost, 3G alt
These clamps do very well with the lines that SeattleFSB used for his transmission. Those lines are common on the fighter jets as are the clamps.
cajunrebel is offline   Reply With Quote
Old 12-01-2012, 02:03 PM   #16
Seattle FSB
Thats what I used, along with a couple of zip ties.
Old 12-01-2012, 05:25 PM   #17
psychlopath
Student of life, man.
psychlopath's Avatar
Bronco Info: 1979 Freewheel'n, PowrLok, ARB, OBA, and anything else I can cram in
That Bill Vista...sure knows how to cut 'n paste info.
I <3 FAR 43.
psychlopath is online now   Reply With Quote
Old 05-09-2013, 08:09 PM   #18
USAFBELL10
USAFBELL10's Avatar
Location: Currently: Kirtland AFB Albuquerque/ From: Houston, TX
those clamps are called adel clamps we use them a lot in the aviation field to keep fuel lines fron chaffing. I am pretty sure you can find them most places but theres a name for you.
1995 Eddie Bauer Bronco, 5.8L, 6in Lift, 35/12.50/15 Goodyear MT/R's, Trac Loc Limited Slip, Extended Radius Arms, Rear Traction Bars, Warn Premium Locking Hubs, Ranch Hand Bumpers
USAFBELL10 is offline   Reply With Quote
You may not post replies
Forum Jump
