Broken intake manifold bolts question - FSB Forums
Thread Tools Display Modes
Old 04-24-2012, 02:28 AM   #1
homesickalien
Noticed a coolant leak. Turns out it was at the front driver's side corner of the intake. Started taking the thing apart. Both front corner bolts were rusted through. One rear one broke and one other came out but was in bad shape. The non-corner bolts were fine. Did some searching, looks like drilling out etc is in order. My question is, is the threaded part of the bolt entirely in the head or is part of the hole in the intake threaded too? If not, can I pry/force the intake up and off or is that a losing proposition? I'd like to get the intake off first then deal with the broken bolts but I don't want to spend time trying to force it off not knowing that it is still essentially bolted to the heads...If I should be able to get it off, what techniques should I use to get it off. I've tried shaking it with my hand and there isn't any movement at all. Penetrating oil is sitting in all the bolt holes during the work week. One bolt rusted out way far down. One broke way far down, and one broke pretty high up.
Thanks for any info.
homesickalien is offline   Reply With Quote
Old 04-24-2012, 05:30 AM   #2
dgarvy
Bronco Info: 351w E4OD 33" tires finally orange work in progress
Funny I'm in the same place you are tight now. After 2 days of trying to get the manifold off via prying and lifting with no luck other than breaking the front seal. I finally got a 90 degree adaptor for my drill and will be attempting to extract the bolt on Wednesday. If that doesn't work I've read that taking off the heads and trying from the other side works well. And if that doesn't work looks like I'll be getting my Gt40s soon. Good luck to you
1990 Eddie Bauer with 351 winsor 33" 3g upgrade
dgarvy is offline   Reply With Quote
Old 04-24-2012, 06:42 AM   #3
alaskan155
alaskan155's Avatar
Bronco Info: 1988 BRONCO 5.0/AOD axle code H5
why not take a dremel to the head? its only like grade 2 or 5, grind the head down, then snap the remain bolt head off... then it will leave a piece of the studd up that you might be able to grab with channel locks, if you try to snap it, then you are going to be looking a drilling and tapping the hole...
88 Bronco(sold)
new trail rig
2000 ranger
4.0/5r55e/bw 4.10 gears 35 mt/rs
alaskan155 is offline   Reply With Quote
Old 04-24-2012, 06:48 AM   #4
alaskan155
alaskan155's Avatar
also for the op take a large flat tip screw driver/pry bar and pry up in the center of the heads/intake(i believe there is a slot there), might have to hit the scew driver with a hammmer to pop it loose. if the intake doesnt move then there is a bolt you miss or it hasent been removed in a while. also make sure the valve covers are removed as the overlap the intake
88 Bronco(sold)
new trail rig
2000 ranger
Old 04-24-2012, 08:08 AM   #5
kyleson
kyleson's Avatar
Bronco Info: 96 F150 4x4 Off-Road, 5.8, E4OD
Im not sure about these small hockey but on all the diesels I've had apart that are v8s the intake bolts are angled so the go straight into the heads. If they are not drilled out/ broken off deeper than where the head starts your gonna **** something up trying to pry it off and they they are at an angle.
86 F350 XLT Lariat 4x4, power everything, AC, C6, 3.55, 265/75R16 STT on 16x8 Mojave's.
97 F350 XLT 4x4, 7.3, built E4OD, AFE Big Boost, GTP38R, IC, 17 HPOP, bellowed up pipes, efuel, 120v IDM, 160/100's, PHP Phoenix, 4" MBRP, 305/70R16 STT on 16x10 Eagles, over 400/800 to the wheels.
kyleson is offline   Reply With Quote
Old 04-24-2012, 08:27 AM   #6
CBboots
CBboots's Avatar
Bronco Info: 79 Custom, 460, C6
You have some of the bolts out, can't you get a flashlight and see if the intake is threaded (I don't think it is)? Everytime I mess with heads/intakes I end up breaking the bolts.....most people that are smart (not me of course) use heat on the bolts prior to taking them out. If I was doing your project, I'd go ahead and snap the corner bolts off as you already have some broken. I'd then pull the heads (probably breaking more bolts) and take them to a machine shop. Heads can always use rebuilds/upgrades and you don't have to worry about drilling and tapping (if you're concerned about doing it yourself). Both then again I'm lazy.....something about working smarter not harder?
My 79 build http://www.fullsizebronco.com/forum/...d.php?t=207864 - Aluminum 3-core radiator, Mallory 85 HEI conversion distributor, High Angle Driveline One Tons front and rear, JBFAB Twin stick shifter kit, True trac differentials front and rear, Yukon 4.56 gears front and rear, Moser Extreme 31 spline rear axles, Borgeson adjustable steering shaft and rag joint, 95 amp 3G alternator, Fireguy/RJM Tech upgraded headlight harness, and a ton of other crap!
CBboots is offline   Reply With Quote
Old 04-24-2012, 10:07 AM   #7
87Roughneck
87Roughneck's Avatar
Bronco Info: '87 Bronco Custom; 300cid EFI w/ 3" exhaust; 35" Goodyear Wrangler Kevlar MTRs on 15x8; 2.5" lift
You didn't say which engine you have, but assuming that it's a 302 or 351... yes, the bolts go straight up, and no, there is no threaded section in the intake itself. The manifold can be raided straight up off of the engine past the broken bolts, but you have to go up evenly- front to back and side to side- if there is more than one broken bolt. Otherwise it will jam against one bolt as you try to pry it off another.
Be careful if you jam a screwdriver or prybar between the block and manifold- the manifold is aluminum, and it can be damaged fairly easily.
87Roughneck is offline   Reply With Quote
Old 04-24-2012, 11:46 AM   #8
homesickalien
Yeah it's a 351. Forgot to mention that. I think one bolt is broken probably right at the merger between the head and intake. The other two seem like they rusted out and are probably just down in the head.
Old 04-24-2012, 11:50 AM   #9
homesickalien
I have all the bolts out (except for the broken parts...). The ones at the corner were so rusted there is not much to see in the hole regarding whether the intake part is threaded. I will look in the interior holes. I guess they are probably exactly the same. Just thought I'd ask as I assume a ton of people have done this before and I never have. I just wanted a confirmation before trying to get them out and having a facepalm moment.
Old 04-24-2012, 11:53 AM   #10
homesickalien
Thumbs up Thanks!
Thanks for the tips guys. I'm going to give it a go this weekend. I'll let you know how it goes.
Old 04-24-2012, 01:29 PM   #11
JKossarides
JKossarides's Avatar
PB Blaster should do the trick for soaking rusted bolts on a manifold, back in 08 I over tightened the temp guage sending unit and cracked it right in the threading and it was pissing out coolant, found 92 5.0 manifold in the JY but had to have the knock sensor hole drilled out so it was a $125.00 PITA mistake.
Take your time ~
Old 04-24-2012, 09:54 PM   #12
ponyboy79
ponyboy79's Avatar
Bronco Info: 79 bronco ranger xlt
If any of the broken bolts are sticking up u might try a bolt out set. If not then id try drilling and use an e-z out before drilling and tapping.
ponyboy79 is offline   Reply With Quote
Old 04-30-2012, 01:31 PM   #13
homesickalien
Only one has anything sticking any amount out (in the back). I tried drilling and ez-out on the one where it at least broke flat above the cylinder head. I got nothing except the feeling I was about to break the ez-out so I stopped. There is nothing much left to the bolt but to drill it out at this point. Unfortunately I wasn't perfectly on center either so I'm not sure exactly how to correctly do this without going into the head on one side but only the remains of the bolt on the other.
This sucks. It's like the metal of the bolt just infused itself into the cylinder heads. There was absolutely no indication of that bolt coming out. Maybe I'll have better luck on #2.
Old 04-30-2012, 01:58 PM   #14
broncoflorida
Bronco Info: 87FSB, 302 020 over ,3g alt, GT40 heads, Exp intake , Bassani Exhaust and 24" Magnaflow muffler
in my experience removing broken studs is a pain. If the heads where off or you where doing a overall, I would say take the heads in and let your machine job handle. It will come out cheaper and they are better suit for removing studs.
Whatever you do, use some no-serizure paste on the corner intake bolts at minimum. Good luck, I don't want to be in your shoes and more so if it's the rear of the engine.
broncoflorida is offline   Reply With Quote
Old 05-01-2012, 12:37 PM   #15
homesickalien
The heads are still in the car and I hope to leave them in there because, well mostly because I have not taken them out before and I'd have to take both out since I have broken bolts in both heads.
Let's just assume that I have to drill the entire bolt out. Is it a problem to just drill the hole out to the next size up which I guess would be 3/8? I would try to get it at 5/16 but since I was off center, I think I'm going to start drilling out the threads on one side and still have bolt material left on the other.
You may not post replies
Forum Jump
