ignition switch or actuating rod? - FSB Forums
Thread Tools Display Modes
Old 06-19-2012, 11:05 PM   #1
dougc767
Bronco Info: 1991 EB 5.8l, 1995 xlt 5.8, 1995 EB 5.8
'95 bronco. The ignition switch will crank the engine and turn it on, but when you rotate the switch back to off it's free wheelin', no resistance, and doesnt turn the engine off. Is it the cylinder barrel, actuating rod, or something else? I haven't taken anything apart yet, wanted the expert opinions and prior experiences beforehand. Thanks.
dougc767 is offline   Reply With Quote
Old 06-20-2012, 08:59 AM   #2
472SCJ
472SCJ's Avatar
Bronco Info: 78 Bronco,472 Super CobraJet,C6 3500 stall,39.5 Super Swampers, 5:14 Ratio
I would remove the actual ign. swicth from the lower part of the colunm and start checking things from there, remove the switch and see how the actuating rod moves out of the switch, with turning the key and without
472SCJ is offline   Reply With Quote
Old 06-20-2012, 09:22 AM   #3
Pennywiserawker
Pennywiserawker's Avatar
Bronco Info: 95 XL Emerald Green
This happened to me 2 years ago. The actuating rod has a grove or loop that the ignition switch goes through. The rod is made of plastic and the back half of the rod breaks off which had happend to me. I took the two torx bolts out that hold the IS in and just push the little rod that comes out of the top of it. If that seems primative to you it may be time to wire in a push button start which there are multiple thread here at FSB that will help you through it. I just havent got around to doing so. Im almost possitive that the same problem has happened to you. If the the push button doesnt sound like a good idea then you may have to buy a new column at the JY.
Built 351 w/GT40 heads, E-fan, Flowtech ceramic coated shorty headers, Bassani y-pipe, single chamber 3" muffler,10.25" rear, ZF 5spd, 16.5" chrome wagon wheels, 37"x 12.50" Goodyear Wrangler M/T OZ tires, 6" lift ProComp rear leafs, Front Leaf D60 SAS Front bumper build in progress!
Pennywiserawker is offline   Reply With Quote
Old 06-20-2012, 09:56 AM   #4
miesk5
I used to know this stuff
miesk5's Avatar
yo,
Actuator Rod Pics (Upper & Lower); 92-96 w/Ford Part Numbers
Source: by http://www.steeringcolumnservices.co...-actuators.php
Actuator (upper)
This white plastic ignition actuator gear with teeth often breaks prevents you from starting or shutting off the vehicle with the ignition key. The ignition rack actuator failure if often misdiagnosed as a ignition lock or ignition switch problem.
Actuator (lower)
OEM # F2DZ 3E723 A
Fits Makes: Ford Cars & Trucks
Fits Years: 1992-2008
$28.63
This white plastic ignition actuator is the lower actuator on most Ford cars and trucks. This piece is actually what joins with the ignition switch to start the car. It is pushed by the ignition lock cyliner and upper rack gear.
Our Part # RACK06
OEM # F0DZ 3E715 A
$32.08
Removal in a 95 w/Tilt; "...Symptoms of the problem before tearing into the steering column was that I could start the truck, but not shut it off. The key was easily turned without any “normal” resistance/spring to it and all accessories had power with the key in any position. The rest is pretty simple though. All reverse of installation..."
Source: by KC200787 at http://fullsizebronco.com/forum/showthread.php?t=181708
USN (Ret) & MIL/DoD Contingency Planner (ret)
THANKS to ALL WHO SERVE!
my broncolinks.com was "disturbed"; but some sections are archived @ http://web.archive.org/web/201209211....com/index.php
Old 06-20-2012, 10:33 AM   #5
dougc767
Wow! I read thru the process of tearing down the column to access those 2 ignition actuators. Think I'll reserve a weekend or 2 for that process. Thanks miesk5, thats the same symptom as what I have.
Old 06-20-2012, 09:57 PM   #6
dougc767
Curious to know if that entailed pulling half the dash and steering wheel. Is it accessible from underneath? Thanks.
Old 07-01-2012, 10:54 PM   #7
dougc767
That was pretty involved. I followed the links Miesk5 added in post #4 and they were very informative. I ordered from steeringcolumnservices.co and received the parts I needed. They offered a short cut to replacing the upper actuator, and reluctantly, I followed it. I'll be replacing it again sooner or later, hopefully the latter. But it's fixed! Now that I've taken it apart for the first time and put it back together, I'd recommend replacing it the proper way. Just take alot of pics while disassembling. Hats off to Steve83 as well, he's got the s#%t in his signature thing, just need to click and search. You can re-assemble a whole bronco from his links.
Old 07-02-2012, 08:49 AM   #8
miesk5
miesk5's Avatar
yo Doug,
Great! you saved at least $100.00 +++ by DIY
One tip is to ensure that the ign key is Not on a chain or key ring with many other keys and small knives or other items; need to avoisd it getting caught lock receiver as strg wheel is turned. Heay key chains also
There was a recall for this for 87-91 MY Broncos, F Series, etc. ; # 93V066000
Section 11-04: Steering Column 1996 F-150, F-250, F-350, Bronco, F-Super Duty Chassis Cab and Motorhome Chassis Vehicles Workshop Manual
REMOVAL AND INSTALLATION
Ignition Switch Lock Cylinder, Lock Cylinder Non-Functional
Removal
NOTE: The following procedure applies to vehicles in which the ignition lock is inoperative and the lock cylinder cannot be rotated due to a lost or broken key, unknown key number, or a cap that has been damaged or broken to the extent that the lock cylinder cannot be rotated.
Disconnect battery ground cable (14301).
Remove steering wheel (3600).
Using channel lock pliers or vise grip pliers, twist cap until it separates from the ignition switch lock cylinder (11582).
Using a 3/8-inch diameter drill, drill down middle of ignition lock key slot approximately 44mm (1-3/4 inch) until ignition switch lock cylinder breaks loose from breakaway base of ignition switch lock cylinder. Remove ignition switch lock cylinder and drill shavings from lock cylinder housing.
Remove retainer, bearing and gear. Thoroughly clean all drill shavings and other foreign materials from casting.
Carefully inspect lock cylinder housing for damage from the above operation. If damage is apparent, lock cylinder housing must be replaced.
Installation
Replace lock cylinder housing, if damaged.
Install gear, bearing and retainer.
Install trim and electrical parts.
Install new ignition switch lock cylinder.
Install steering wheel.
NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more for the powertrain control module to relearn the strategy.
Connect battery ground cable.
Check operation of lock cylinder.
Old 07-02-2012, 05:11 PM   #9
The Ric
MORTAL KOMBAAAAAAATTT!!!!
The Ric's Avatar
Bronco Info: 88 EB custom dents, and rust.
hey if its the rod, check the tech write-up section. there is an awesome write up on this
Not to sure what to put in my signature anymore.
1988 Ford Bronco EB - 2010 Chevy Malibu - 2009 Cannondale Six5 - 2013 FELT F75X
The Ric is offline   Reply With Quote
Old 07-02-2012, 07:36 PM   #10
dougc767
Yes, thats the one I referenced. However, when I ordered the parts the company sent directions as well, but their's were for a short cut that entailed altering the rod. Like I said earlier, it wasn't the correct way to fix it, but I did it anyway and will be regretting it sooner or later.
Old 11-28-2012, 04:35 PM   #11
4NIC8R
4NIC8R's Avatar
Bronco Info: 91 Silver Anniversary
Going to necro here and ask a similar question; lock, rod, or switch,
I can turn the key in the lock and it will go into the "run" position and the lights come on, but no start. It does not spring back and there are no indents for each key postion, just turns. The lock position works and will lock the wheel.
1991 SA
5.8L, E4OD, BW1356
217,000 miles and rolling
Second... and Fourth Owner!
4NIC8R is offline   Reply With Quote
Old 11-29-2012, 07:43 PM   #12
4NIC8R
4NIC8R's Avatar
....bump
Anyone? A little help would be appreciated before I start tearing it apart.
1991 SA
5.8L, E4OD, BW1356
Old 11-29-2012, 09:28 PM   #13
80bronc
Originally Posted by miesk5 View Post
yo,
Actuator (upper)
Actuator (lower)
OEM # F2DZ 3E723 A
$28.63
Our Part # RACK06
OEM # F0DZ 3E715 A
$32.08
Definately sounds like the problem your having, I had a similar issue on my truck
80bronc is offline   Reply With Quote
Old 11-29-2012, 11:55 PM   #14
dougc767
It's that plastic actuator rod that's behind the ignition tumbler (where you put the key in), it connects to another plastic piece deep inside the steering column. I'm not a pro mechanic, but it was doable to replace. Like I mentioned earlier, I should've replaced it correctly instead of the shortcut way that the instructions led me into. I think I bought the replacement from "Ignition Actuators" or something like that, and they included the shortcut instructions. It's still working fine for the time being, but not so sure for the long haul. Be careful with that damn tilt spring! Wear eye protection and teach that thing lesson! I know a few curse words, but my wife never heard so many outside the bedroom. :) Good luck, you can do it!
Old 11-30-2012, 10:19 AM   #15
4NIC8R
4NIC8R's Avatar
Thanks!
1991 SA
5.8L, E4OD, BW1356
You may not post replies
Forum Jump
