did magnaflow ever fix the 5.8 y pipe? - FSB Forums
Thread Tools Display Modes
Old 06-29-2012, 06:02 PM   #1
marnefist
marnefist's Avatar
Bronco Info: 1995 EB 351W, E4OD, 213k, more rust than truck.
I was wondering if anyone knew if it was safe to order the 93312 y w/cat? I ask because awhile back they were shipping the 5.0 pipe with the 93312 part number for the 5.8.
Thanks!
marnefist is offline   Reply With Quote
Old 06-29-2012, 06:20 PM   #2
bronco6696
Bronco Info: 93 bronco 5.8 cherry bomb glasspacks
Try it. Im not sure but i just installed a dynomax straight pipe kit and it sounds nasty!!
bronco6696 is offline   Reply With Quote
Old 06-30-2012, 06:41 PM   #3
marnefist
marnefist's Avatar
Think i'll go for it and order through advance, that way I can return it if it doesn't fit.
Old 07-01-2012, 10:33 PM   #4
Backyard Kustomz
Backyard Kustomz's Avatar
Bronco Info: 95 eddie bauer 351w DD/ 95 jeep on 35" pitbulls
i work at advance and if it is FDO and shipping is applied. you will not recieve the amount forshipping when you return just so your aware.
95 FSB eddie bauer/ 3"body lift/ 33" BFGall terrians/4:10/ MY DD
95 Jeep Wrangler/ 4" BDS suspension/ 1" body lift/ BTF tube fenders/ Ford 8.8 LSD/D30 lockright(building Waggy 44)/ SYE and Double cardian Driveshaft/ front stinger/ rear BK tire Carrier/ 35"pitbull Rockers/ 2.5 L low output/ MY TOY
Backyard Kustomz is offline   Reply With Quote
Old 11-19-2012, 11:11 PM   #5
marnefist
marnefist's Avatar
I am sorry I forgot all about this. I meant to follow up but got side tracked with other issues.
magnaflow/bosal Y pipe still does not fit the 5.8l. even with the correct part number for the 5.8, they are shipping y pipes for the 5.0. even though magnaflow customer support claims to have fixed the issue or outright denies the issue, apparently there are still plenty of boxes on shelves with the wrong part in them.
for us 5.8 guys its either bassani or fab it up yourself.
Old 11-20-2012, 03:50 PM   #6
kemicalburns
Never Done
kemicalburns's Avatar
any reputable exhaust shop should be able to build you a custom y pipe that is very comparable. i had mine built and it was done very well.
94 XLT 357/E4OD Trans-go stage II
6" Stage II ProComp,35x12.50BFG/AT
4.88 f (aussie) / r (open) / Custom Sliders
JBA headers,Custom Y pipe hi flow cat & Full 3"
kemicalburns is offline   Reply With Quote
You may not post replies
Forum Jump
