#1 |
![]() Join Date: Mar 2009
iTrader: (1) Bronco Info: 92 Factory Original 300 I6 M5OD Manual Custom. 3 seats, AC and a radio. That's It. Not even Carpet.
Can Clutch Switch(M5OD) mimic dead Battery problem?
OK, for the past few weeks, I've had to depress the clutch a couple if times to get the Bronco to crank. I would depress the clutch, turn the key and nothing would happen. All I would get was hearing the fuel pump pressurize the system. I would keep the key turned, press the clutch again and it would crank right up.
Yesterday, I got to spend a couple of hours waiting for a tow truck. I got in the Bronco after a short drive and pressed the clutch, turned the key and nothing. Pressed the clutch again and Nothing. Pressed it again and NOTHING!!!! ![]() ![]() This isn't how I wanted to spend my one day off. OK, so I am speculating it has something to do with the switch/contact in the clutch pedal that makes it mandatory to press in the clutch to crank the engine. I noticed a couple of times when I tried to crank the engine and pressed the clutch in with the key turned that the RPM needle bounced hard, maybe up to 4K or higher. It was a quick movement and had I not been looking at it, would have never seen it. the whole thing is acting like a dead battery except that the radio, lights and everything else work fine. I tried jump starting it with the Ram and still nothing happened. No clicking, no turning over of the engine, nothing except the lights got a little brighter when it was hooked up to the Ram. Any possibility of it also being the Starter solenoid instead? What's the best way for me to start looking/testing instead of just throwing parts at it? No corrosion on the battery to speak of. I really haven't had a chance to start looking into it yet but will hopefully if I am off on July4th. Thanks All.
JTMcD. We sleep Peaceful in our beds because Rough Men stand ready in the night to visit violence upon those who would do us harm............George Orwell The object of life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting, 'Holy Shit, What a Ride!!! -- Mavis Leyrer MY A/C Vacuum leak repair http://fullsizebronco.com/forum/showthread.php?t=175808 |
| Sponsored Links | |||
Advertisement | |||
#2 |
Salt blows goats for fun
![]() Join Date: Aug 2004
iTrader: (8) Bronco Info: 2006 Kia Spectra
Yes since the clutch interlock IS a starter interlock, it can keep the starter from engaging when you turn the key if it malfunctions.
The tach jumping is strange though. never heard of that one. ![]() it could be the starter relay, but since the issue would be dependent upon the clutch being hit a couple times, i would start there. bypass the clutch interlock and see what happens, it's only a couple wires. how, i am not exactly sure. off topic: you couldn't find a couple of dudes to push the truck so you could pop-start it?
2006 Kia Spectra 4 banger/5 speed. I enjoy the cawk. "Kids, they see the good in everything and through their eyes, they open ours." - Hank Davis |
#3 |
Naw. You would think being at a Lowe's, there would be plenty of people there to help. Just didn't feel like asking at that time of day. Besides, we have towing and roadside assist on our insurance. Might as well use it.
There was another Bronco I saw there with Wisconsin plates and the guy just looked at me and shook his head as he drove by. The F'er........
#4 |
iTrader: (98) Bronco Info: '83 VIN & title on '93 frame/body w/'95 4.9L & EB paint
All the Clutch Pedal Position switch does (to the starter circuit) is interrupt power between the ig.sw. and the starter relay when the CPP doesn't indicate the pedal is FULLY depressed. That might be because your carpet is folded down behind the pedal, preventing you from fully depressing it; or because the switch is maladjusted, and doesn't indicate the actual position; or because the switch is bad. To find out, remove the switch (slide the catch plate back and it falls off the rod), and operate it manually while testing continuity (Ohms, diode) between the proper terminals.
If it passes, check for 12V on the #1 R/LB wire with the key in START. If that passes, the fault may be in the starter relay. Jumper from the large REAR post to the small post; it should click solidly, and the starter should immediately engage the engine. If not, the fault is in the starter. |
#5 |
#6 |
iTrader: (1) Bronco Info: 1995 5.0, mass air, converted to manual M5OD, XL, former Navy vehicle.
All Broncos are wired for the clutch switch. When an automatic is installed, they have a plug they put in the clutch switch socket of the wiring loom. Go to a junk yard and pull this plastic plug out of an automatic truck. Put it in the plug of your truck, and it completes the starting circuit, eliminating that switch. All you'll have to remember is to put your trans in neutral before starting, and you'll avoid another "Nanny State" device to protect you from yourself ;~)
#7 | |
In other words: fix it right - don't install the wrong part. |
#8 | |
#10 |
thank you
#11 | |
Interesting, I converted to stick, don't know if there's a MAF computer for this application, and the only codes I've ever had are in regards to not getting signals from the auto tranny. Otherwise, runs great passes smog with a wide margin.
#12 |
Stupid question. Which contacts do I need to check? I don't have Cruise control so I know #3 isn't necessary. #1&2 are obvious but where do I run to ground? Is it grounded off the body of the switch itself? ON the pin out, it gives the numbers 408, 32, 511. Do I need to know what these reference? Have I told you how glad I am you're back?
#13 |
iTrader: (1) Bronco Info: 1996 Black 302 XLT - 1994 Green 351 E. B. both have E4OD, 3.55 axles, 31 10.50x15
This might be a little late to the party, but here's the CPP schematics from the '94 EVTM, it might help. ('92 should be the same)
Good Luck! ![]() http://www.supermotors.net/registry/media/874104_1 ![]() http://www.supermotors.net/registry/media/874093_1
"The simplest solution is usually the best solution" - Occam's Razor "The significant problems we face cannot be solved at the same level of thinking we were at when we created them." - Albert Einstein |
#14 |
S%$& - duplicate post
#15 | ||
#16 |
![]() Join Date: Oct 2010
iTrader: (8) Bronco Info: 94 C150, 351/zf,5"lift,35" xterains,flow40, mac headers,sag swap, elec fan, 4WDB
Just a heads up if the clutch switch, ignition actuating rod or the silinoid on the fender ever fails on you- put the truck in neutral, put the ebrake on, pop the hood and jump the two big terminals on the fender mounted silinoid with anything metal. If its not the starter it will fire right up, no need for a tow truck next time.
![]() Visit my build thread- http://www.fullsizebronco.com/forum/...d.php?t=211825 |
#17 |
I tried the jumper trick and it acted like a dead battery. Tried jump starting it with the Ram and still nothing. I'll take the starter off Sunday when I'm off and get it tested.
#18 |
Well, got the starter out and took it to Advance to get tested. Not only did it fail, it shorted out bad enough it caused the breaker in the store the machine was plugged into to trip. I picked up a new remanned one with the lifetime warranty using the discount codes and saved about $50(including core).
Interesting note I discovered. Apparently Ford changed from the spade connector to a sealed hard wired connection so I have to cut/splice/heat shrink the new connection.
#19 |
OK, got the Starer replaced , now another question....
OK, Replaced the starter. Took about 40 minutes total time from removal to reinstall. It cranks much quieter now. Much more than I remember it ever doing.
I do have to hit the clutch twice to gt it to crank though. If I have the clutch pressed and turn the key, nothing happens. I leave the key turned and press the clutch again and it cranks like a new Bronco. Could the clutch switch maybe have caused the problem with the starter? Either way, I have a lifetime warranty on it so I won't be out anything but a few minutes. But, if it could, I may as well replace the CPP switch also just to save some future grief. The starter solenoid was replaced a couple of years ago when I though that was a problem, only to find out the Neg- cable was nearly corroded through.
#20 |
i'd go to the junkyard and get another clutch interlock switch.
you are the first time i've ever heard about one failing, in any type of vehicle, ever.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
