5.0 & 5.8 Fuel Rail spacing ? - FSB Forums
Thread Tools Display Modes
Old 08-02-2012, 07:44 AM   #1
CrazyBRONCOguy
SOD BUSTERS Member
CrazyBRONCOguy's Avatar
Bronco Info: Which One?
Anyone know the differance in width for the fuel rails between a 302 and 351? as in accros the intake, perpindicular to the heads. I am looking at getting a fuel rail kit and there are more 5.0 kits then 5.8 kits. Was going to get a 5.0 kit and make the lines longer to work on the 5.8 intake.
The SVO book I have says the intakes are 2.25 different. I was unsure if that applied to the fuel injector holes as well.
'92 Eddie Bauer- C6/208 swap, Roller 357W, MAF, RJM Harness, BlueOvalChips SCT Tune
'78 Custom- 4" Superflex Lift, Mild 460, 8 Point Cage, 4.10 Gears, 35" MTZ's
'96 F250- Tow Rig, 460, E4OD Punisher Valve Body, Triple Piler Gauges
'92 F150- 2wd, Winter Beater, 3.73's, 5.0
'79 F250- 2wd, Farm Truck, Waiting Restoration
'03 SVT Focus- Daily Driver, OZ Wheels, 6 Spd
'86 Mustang- Fastback, SOHC 4.6L Swap Project
CrazyBRONCOguy is offline   Reply With Quote
Old 08-02-2012, 11:20 AM   #2
kyleson
kyleson's Avatar
Bronco Info: 96 F150 4x4 Off-Road, 5.8, E4OD
That would probably be about right. The rails themselves would be the same, if you go with a kit that's AN lines and cut yourself it shouldn't be bad.
96 F150 XLT Off Road RCLB, 5.8, E4OD, 3.55LS F/R, BDS leveling coils, 15x10 black steels with 33x12.50, Magnaflow y to 3 inch side exit w/ thrush welded, homemade MIL Eliminator, Six Liter Tune, BajaHID projectors, in-dash CB, 12" pioneer w/ 1000 watt amp.
kyleson is offline   Reply With Quote
Old 08-02-2012, 11:24 AM   #3
magnumpi
Wrenching for a Livin'
magnumpi's Avatar
Bronco Info: '85 Ford Bronco XLT.
On my 5.8 i just bought edelbrock rails and stuck in some pipe thread adapters to AN/JIC fittings and made up a short crossover hose. Had pirtek do the new fuel supply, and return lines and a short line from the rail to the pressure regulator.
My SuperFord
'85 Bronco......
Welded 14 bolt, HPKingpin D60 w/ lockright, ZF5, NP205, 4.88 gears, SMPFI 393 w/ EDIS(gufx strat), Chevy 52s Front, Inboarded Chevy 63s Rear, DOM heim steering, DOM cage, Saginaw pump, 3/8" fuel system, 200amp 3G Alternator....
ASE Master Automotive Technician
ASE Master Medium/Heavy Truck Technician
magnumpi is offline   Reply With Quote
Old 08-02-2012, 12:54 PM   #4
CrazyBRONCOguy
SOD BUSTERS Member
I was thinking the same on the cut it to length kit. Russel makes one that looks like it would work well.
http://www.summitracing.com/parts/RUS-641550/
Accel also has one they say is for eithier, I dont know if the lines are extra long or what though and can't really find any good info on it.
http://www.summitracing.com/parts/ACC-77306/
Old 08-02-2012, 01:00 PM   #5
magnumpi
magnumpi's Avatar
the edelbrock one seems pricey. You can piece it together cheaper. Accel one might be a good option. you could always make up a line if its short. its simple
My SuperFord
'85 Bronco......
Old 08-02-2012, 01:09 PM   #6
CrazyBRONCOguy
SOD BUSTERS Member
Yeah the making the lines does not worry me too much. Was just looking for some input.
Thanks
Old 08-02-2012, 06:14 PM   #7
Seattle FSB
Seattle FSB's Avatar
Bronco Info: 1990 EB FSB, MAF, 6.7L, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
I recommend that you consider Professional Products Fuel Rails. Good quality for a good price. I had a problem with ECT TEE clearance, but nothing a fitting couldn't fix. 5.0L/5.8L crossover line is different length, fuel injector spacing is the same.
1990 Bronco, MAF, 408 Stroker, Level 10 E4OD, Currie F9+, Electric Boost Brakes, lots more...
Seattle FSB is online now   Reply With Quote
Old 08-06-2012, 09:08 AM   #8
CrazyBRONCOguy
SOD BUSTERS Member
I have been looking they, have a kit with all the pieces too, however I have not found much info on their regulators and that, eithier good or bad.
Old 08-06-2012, 11:06 AM   #9
Seattle FSB
My Professional Products EFI Adjustable FPR (PN 10679) works great with no issues. Along with the Holley/Walbro 255 lph In-tank Fuel Pump, Canton Racing Products CM EFI High Flow Fuel Filter and Professional Products Powerflow Fuel Rail, it holds a steady 42 psi. But it is not the only adjustable FPR out there.
Old 08-06-2012, 11:23 AM   #10
CrazyBRONCOguy
SOD BUSTERS Member
Did not know you were running one of their regulators as well. I have to look some more into their stuff.
Im more making sure my fuel system will not be the limiting factor when my new engine goes in. Would the stock pieces be sufficent, maybe, if anything these will look better.
Old 11-10-2012, 06:39 AM   #11
CrazyBRONCOguy
SOD BUSTERS Member
Ended up getting the accel kit. However I would probably get the trick flow kit if I was to get the stuff again. The Accel kit is made to put fuel injection on a car with the regulator and that at the front of the engine. I had to change some things to make it work but its fine now, and I don't think any kit would of been 100% bolt on. I did use professional products fuel line adapters to go to the stock lines.
Old 11-10-2012, 09:08 AM   #12
Seattle FSB
Pic!
Old 11-11-2012, 06:29 AM   #13
CrazyBRONCOguy
SOD BUSTERS Member
I will have to get a good one of what I ended up doing.
The stock ECT TEE piece was kept but changed a little bit for clearance on the front of mine, Im also not running a front cross over line.
You may not post replies
Forum Jump
