Temp gauge stuck on cold??? ECT?? - FSB Forums
Thread Tools Display Modes
Old 08-17-2012, 02:23 AM   #1
therobvolta
therobvolta's Avatar
Bronco Info: 1992 Ford Bronco 5.0. Art Carr Shifter, Cold Air Intake, Cherry Bomb
My temp gauge is stuck at cold no matter how long I drive. I have driven over 2 hours and it is still stuck at cold. Yesterday I took a test light and plugged it into to wire that goes to the coolant temp sensor and it went up on the gauge in my dash. So I assumed it was the coolant temp sensor (the one next to the distributor) So I replaced it, well this did not fix my problem.
The other day when I had the tubes that connect to the air box off of the throttle body, I seen that my ECT sensor was broken....the one with the two prongs.... It was not even connected. So I connected it but it is just hanging on there and I dont think it is really working right. Sometimes when I start it it takes a real long time to fire up.....so here is my question......
Would a bad ect sensor cause this? Do I need a new thermostat? I know I need a new fan clutch because it is sloppy. But if i needed a new thermostat wouldent it be stuck at high?? Any help would be appreciated thank you in advance...
therobvolta is offline   Reply With Quote
Old 08-17-2012, 03:11 AM   #2
Mikey350
Bronco Info: '96 Black 302 XLT - '94 Green 351 E. B. both have E4OD, 3.55 axles, 31 10.50x15
Did you/have you pulled codes? Having the ECT unplugged will give you a code, but not a CEL if I remember correctly.
Maybe you got a bad temp sensor, as your gauge works. You can test the new temp (dash temp) sensor with a soldering iron, plug in the sensor (one wire), and heat it (the end that goes into the manifold water passage), also ground the sender (a jumper cable on the threads will work) if the dash gauge works when you used a test light or when you ground it, but not when installed, the dash gauge and the wiring to it should be good.
Did you use a bunch of thread tape on the threads? The sender gets it ground through it's threads. Don't overtighten it, it has tapered threads, the tighter it gets, the bigger it gets, until you overtighten it and crack the intake manifold.
Last edited by Mikey350; 08-17-2012 at 04:24 PM. Reason: Added info about grounding and thread tape
Mikey350 is offline   Reply With Quote
Old 08-17-2012, 10:48 AM   #3
therobvolta
I replaced the temp sensor. And plugged the test light into the temp sensor plug and the gauge worked. I pulled the codes. But I don't have an obd1 reader so it's just the check engine light blinks. And I can't figure them out.
http://www.youtube.com/watch?v=xH7Zq...e_gdata_player
Sent from my iPhone using Autoguide
Old 08-17-2012, 02:33 PM   #4
mike91
Bronco Info: 1991 EB 5.0 auto E4OD bought new in 1990
most of the time, a thermostat will stick open and not allow the coolant to get up to temp. Mine was doing the same thing and it was the thermostat.
mike91 is offline   Reply With Quote
Old 08-17-2012, 02:44 PM   #5
Ewgoetz
Ewgoetz's Avatar
Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs, 200,010Miles
start off fixing the things that you know are broke. I would fix the ect connector and change out the ect sensor as well while your in there.
Ewgoetz is offline   Reply With Quote
Old 08-17-2012, 04:14 PM   #6
JKossarides
JKossarides's Avatar
X2 ^
The ECT = engine cooling temp sensor http://www.oreillyauto.com/site/c/de...e+temp+sensor+ is a fuel manager at cold start and normal operation so any isssues with it could actually prevent starting, you'll notice the harness side connector "unsnaps" and comes apart like an Off Road weather pack style so you can either go to the JY and find one el cheapo or buy a pigtail at the auto store for a bit more $$$, unsnap and resnap assuming there's no damage to the wries leads. http://www.oreillyauto.com/site/c/de...e+temp+sensor+
If you replaced the "brass style" http://www.oreillyauto.com/site/c/de...e+temp+sensor+ temp guage sending unit and it the needle is still off then it's either a voltage issues thru the lead wire or the dash gauge is fubar which can be replaced with a mechanical gauge for better accuracy....
After running the engine, the top radiator hose should be hot indicating the thermostat is working correctly otherwise it's either in backwards or fubar and if replaced get the correct OEM degree, mine's a 195* and make sure the radiator cap is also in good shape...
Good Luck ~
Old 08-17-2012, 07:07 PM   #7
87Roughneck
87Roughneck's Avatar
Bronco Info: '87 Bronco Custom; 300cid EFI w/ 3" exhaust; 35" Goodyear Wrangler Kevlar MTRs on 15x8; 2.5" lift
A '92 Bronco has two (2) coolant temp sensors- one for the computer, and one for the gauge.
The sensor for the computer has two wires, one green and red, the other gray and red.
The sensor for the gauge is a single wire, colored red and white.
If you take the wire off of the gauge sensor and ground it (the wire, not the sensor)- which is what you did with the test light, if you had it hooked to a ground- the gauge should move to its max hot reading. If it does, the circuit and gauge should be fine. Check the ground at the sensor body by doing a voltage drop test to the battery. It should read "0.00", or pretty damn close. You may have a bad sensor out of the box; it happens more than you might think.
If I remember correctly, temp does not effect fuel trim until the vehicle is in closed-loop, but I would still fix that two-wire sensor and connector that's broken, anyway. Temp is one of the biggest inputs for fuel trim, and with that sensor disconnected your gas mileage is probably in the toilet.
Oh, and my wife is from Appleton, too.
"I'll try to be nicer if you'll stop being an idiot."
Originally Posted by Steve83 View Post
Is he STILL arguing this? I put him on my ignore list years ago, so I don't have to read his ranting.
Originally Posted by TheUnforgiven View Post
Years? He's only been here since February of this year.
87Rougneck knows his shit, even though he can be a dick. I'd listen to him.
87Roughneck is offline   Reply With Quote
Old 08-17-2012, 08:40 PM   #8
scld1354
scld1354's Avatar
Bronco Info: 93 XLT, 5.8, E4OD, SAG swap, converted from auto locking to manual locking hubs
Check to see if the PO removed the T-stat
Check out my Supermotors page for parts for sale.
scld1354 is offline   Reply With Quote
Old 08-18-2012, 01:37 AM   #9
therobvolta
I appreciate all of your help.. APPLETON in the house!
The top coolant hose gets hot. When I tested the wire for the temp sensor it didnt MAX out the gauge it just brought it to about half way. I guess I will fix the ect sensor and see where I am at.
Thank you so much everybody. I truly love this forum.
Old 08-18-2012, 01:42 AM   #10
therobvolta
Originally Posted by JKossarides View Post
X2 ^
Good Luck ~
Thank you!
Old 08-18-2012, 03:20 PM   #11
JKossarides
Your welcome Brother, hope you get it all sorted out.....
Old 08-22-2012, 06:24 PM   #12
87Roughneck
If the gauge only went to half with a good ground on the wire, the problem isn't with the sensor, it's with the circuit and/or the gauge itself. That gauge should be pegged to the hot side with that wire grounded.
Old 08-23-2012, 01:24 AM   #13
therobvolta
Yeah, I replaced the ect sensor now too with no luck :( I guess it MUST be the gauge
Old 08-27-2012, 02:19 AM   #14
smptx
Bronco Info: 89 FSB 5.0L 4AOD Eddie Bauer
I replaced my idiot temp/oil pressure gauge with a mechanical - more trustworthy.
smptx is offline   Reply With Quote
Old 11-03-2014, 06:31 PM   #15
schufflerbot
schufflerbot's Avatar
Bronco Info: 1992 Eddie Bauer 4x4 with 302
necromancing this thread as i'm having the same issue. can someone point out where the ECT sensor is? i replaced the coolant temp sensor (the one near the distributor) and it didn't change anything. my dash gauge will move ever so slightly (maybe a millimeter) when engine is at operating temperature but won't go above that. setting the heater on full heat and 'vent' blows hot air, so i'm assuming the engine temp is where it should be.
is the dash gauge going out a common issue?
FYI - mine is a 1992 with the 5.0
thanks in advance!
1992 Eddie Bauer 6" lift on 35s
check out my awesome videos!
schufflerbot is offline   Reply With Quote
Old 11-03-2014, 06:39 PM   #16
sackman9975
"living life"
sackman9975's Avatar
Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
The ECT sensor is located above the thermostat housing on the intake. However, this has nothing to do with your gauge problem. Ground out the wire to the sendor near the distributor and see if the gauge pegs hot. If it does not, your gauge is at fault.
~ Scott ~ My Tech write ups:
How to properly set the timing on a 302 or 351
Harmonic Balancer Crankshaft bolt removal
How to press rotors without taking them to a machine shop
~E303 w/Flowmaster 40 & 3inch exhaust rumble ~ 215k & counting. ~
~ Bronco owner/Driver/Mechanic/Enthusiast for 23 years ~
sackman9975 is offline   Reply With Quote
Old 11-03-2014, 06:43 PM   #17
Seattle FSB
Seattle FSB's Avatar
Bronco Info: 1990 EB FSB, MAF, 6.7L, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
The ECT Sensor has nothing to do with your dash gauge, the single wire Engine Coolant Temperature "Sender" does. With the Key On-Engine off, remove the single wire and touch it to ground. If the gauge pegs to the right, replace the "Sender". If it does not, replace the gauge.
1990 Bronco, MAF, 408 Stroker, Level 10 E4OD, Currie F9+, Electric Boost Brakes, lots more...
Seattle FSB is offline   Reply With Quote
Old 11-03-2014, 06:58 PM   #18
GvilleBKO
GvilleBKO's Avatar
Bronco Info: '90 EB w/ '96 gt40 5.0, AOD, electric TC, 3.55 TTB/8.8
thanks in advance!
The coolant temperature sensor is located in the distribution "tee", in the front- left area of the intake manifold (standing in front of truck). The TB coolant hose, and one of the heater hoses share this junction. The CTS has NOTHING to do with the gauge. It provides info to the computer.
The temperature sending unit is behind and to the right of the distributor in the intake manifold (standing in front of truck). This sender is exclusively for the gauge.
You need to follow the diagnostics already mentioned in this thread to determine your problem, but its kinda sounding like the gauge is the problem for you as well.
As far as the gauges going bad being a "common" problem I wouldnt know, but remember, the gauge is over 20 years old. Things get old and die.
"If you ain't first, you're last" - Reese Bobby
GvilleBKO is offline   Reply With Quote
Old 11-03-2014, 07:04 PM   #19
schufflerbot
outstanding, thank you guys so much!! i'll check this tonight and determine where the issue is.
Old 11-03-2014, 07:19 PM   #20
schufflerbot
well, that was easy! gauge pegged to the right immediately, will be replacing the ECT sender tomorrow morning! woohoo!!!
y'all rock.
You may not post replies
Forum Jump
